I just purcahsed the GoPro7 Hero Black but now having issues getting the 4K 60FPS to show up in Adobe After effects. It just loads up audio with a black playback screen.
Most of the alternatives seem to involve re-encoding the video file from H.265 down to H.264 and in that process you only end up with 30fps?
What is it that others are doing to achieve 4K 60fps in their editing process. I certainly can’t afford $20US a month to join adobe cloud.
I have an older version of Adobe After Effects, but wondering what else I can try?
Is there any way to end up with H.624 but still have over 30fps @ 4K when dealing with 4K 60FPS HEVC??
Handbrake uses variable frame rate by default when re-encoding video to make its output more compact. If you want to maintain the original framerate then you must open the "Video" tab, change the Framerate (FPS) setting to "Same as Source", and tick the "Constant Framerate" radio button (assuming the original frame rate is constant).
Edit video files in HEVC h.265 codec 60fps & to save in original format
By Wilson Lee in forum EditingReplies: 2Last Post: 27th Nov 2018, 05:24 -
Only Edge browser could play 8K 60FPS HEVC, other browsers & players crased
By Stears555 in forum Software PlayingReplies: 20Last Post: 12th Nov 2017, 15:36 -
MPEG2 capture software for 720p@60fps?
By texas1 in forum Capturing and VCRReplies: 70Last Post: 27th Oct 2017, 00:00 -
Convert x265 4k to 60fps
By raumi19 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2017, 09:49 -
RX 480 isn't capable of decoding HEVC 4K 60fps 4:4:4
By nesvariigi in forum Software PlayingReplies: 2Last Post: 7th Dec 2016, 21:00
