Hi guys!
I'm stuck here with ideas: I have an .m4a audio part loaded to a project and when I split it at a certain point, the audio suddenly contains the content of another audio object in the project. It works normal with all other audio objects in the project...
File path is fine and the options in the property window seems to be the same like with all other audio objects.
here you see the part before....
[Attachment 52598 - Click to enlarge]
... and after splitting
[Attachment 52599 - Click to enlarge]
I'd appreciate your help a lot,
cheers!
.. I just had to find out that it also happens with videos. Always when the split off peace is very small. Nobody experienced this before?
Split video into segments, now how to save as separate files? VSDC
By teamodave in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2020, 11:43 -
VSDC - Unable to Crop or Split Video (blue screen overlay on menu)
By cooker6583 in forum EditingReplies: 0Last Post: 11th Mar 2019, 10:09 -
How do you remove audio from videos using VSDC?
By Amber25 in forum EditingReplies: 1Last Post: 28th Jun 2016, 03:00 -
VSDC cuttting Video and Audio together
By Kobaltauge in forum EditingReplies: 0Last Post: 8th Nov 2015, 08:04 -
VSDC Split-Screen and merge videos
By SimBeam in forum EditingReplies: 3Last Post: 18th May 2015, 16:22
