  1. ok got a problem TMPGEnc
    i am converting an avi to mpeg-1 so i can burn to cd ..it is one long file about 1:39mins long ..so i tried using the source range to divide it into two 49:00 min segments..1st segment is just fine...now trying to do the second segment...i went in and changed the start frame to the end frame value of the 1st clip and moved the end frame to the end of the movie...well it is starting the video right where i want it,,but starting the audio back at the beginning of the movie...does anyone know a quick answer to a setting i am missing or a way to resolve this ...??
  2. Encode to one large Mpeg file in one go, then use TmpGenc MPEG tools to cut this file into two. This should work.
  3. was already in the process of trying that ...thanks that does work..
