Hi there!
Total newbie here. I am having issues trying to move small clips to different layers. When the clip is long enough, a little hand appears if you hover over the clip, which then you can grab and move to another layer.
But if the clip is short, no hand appears, and if you cut and paste, it paste it on a new layer, not the layer you want it to go to. Any ideas?
Thanks for reading!
Hey landoe,
yes it is a bit cumbersome in vdsc to work on a small scale. If you want to split and move short parts that are around 1sec make sure too zoom in as much as possible (+ symbol on the left in the timeline window). That should make the part wide enough for the hand cursour to appear.
Good luck!
Edit a Sprite in VSDC
By detachedaz in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2020, 21:17 -
MPC- Can I edit Clip Properties?
By smike in forum EditingReplies: 2Last Post: 26th Apr 2019, 09:27 -
VSDC ~ How to load Audio and Video Tracks, but only Edit the Video
By u2rcrazybaby in forum EditingReplies: 0Last Post: 5th Sep 2017, 18:37 -
cut video clip using VSDC; tutorial must have left something out
By arcy in forum EditingReplies: 4Last Post: 11th Feb 2016, 12:03 -
How to Edit Lots of Small Sections from Blu-Ray Movie (Like DVDRemake)
By lind777 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Jan 2016, 09:41
