Hi,
If you were to take a 10Bit BT.2020 video that contains HDR metadata (SMPTE 2084, 2086, 2094 etc.) and convert it to 10Bit BT.2020 without the HDR metadata, will the colours remain the same? I believe that the HDR metadata is used by the display to adjust the light intensities or something along those lines to produce varying colours. And 10bit allows for 1024 shades per colour channel and since the source material is in 10bit BT.2020 to begin with, the colours should still be preserved. I'm just unsure about the effects of the HDR metadata because I feel that the video should still look really good without the HDR metadata.
Any insight would be greatly appreciated.
I did some additional research and learned that the 10bit BT.2020 video uses the WCG. Since HDR and WCG are different, if I remove the HDR metadata, I will still get the nice colours that come with the BT.2020 colour space but the luminance aspect and the brightness of the image won't come through so the video will still look different.
tone mapping should be applied during the conversion to get not so dull colors.
How to play 10bit videos and be sure to get true 10bit color on the screen?
By flashandpan007 in forum Software PlayingReplies: 6Last Post: 7th Apr 2017, 19:02 -
Re-encoding Bluray content with x265 10bit
By leghorn in forum Video ConversionReplies: 4Last Post: 12th Mar 2017, 08:30 -
If do not watch 4k hdr content, is it still worth buying a 4k hdr display o
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 19th Sep 2016, 21:03 -
FFMPEG x265 10bit and virtualdub x265 10bit settings
By lilycarolyn in forum Video ConversionReplies: 11Last Post: 6th Jun 2016, 14:44 -
How do I convert 1080p 10bit mkv's to 720p 10bit?
By fighuass in forum Video ConversionReplies: 6Last Post: 19th Nov 2015, 02:34
