I'm making blu ray with Adobe Encore, when the app finish, I make a new .M2TS with tsMuxer using the original video, because the original is 900 mb and the adobe encore is 2,3 GB and the quality is worst than the original instead the big size, not the one who adobe encore make, when I replace them and changing the info in BDEdit, with PowerDVD or VLC there is no problem but when I burn them and try them in my Blu Ray player, the video is black, all is working except the video. What should I do? I put here the info from the original file and the one who Adobe Encore encoded.
Original:
Format : Matroska
Format version : Version 4
File size : 1 016 MiB
Duration : 23 min 42 s
Overall bit rate : 5 995 kb/s
Encoded date : UTC 2020-03-18 15:51:44
Writing application : mkvmerge v44.0.0 ('Domino') 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Attachments : Acto SemiBold.otf / AeonisLTPro-BoldCondensed.otf / AeonisLTPro-Condensed.otf / AntennaComp-Black_1.otf / Antenna-Medium.otf / Appetite.ttf / Archive-Reg.otf / calibri_1.ttf / calibrib_4.ttf / candarab_0.ttf / CommieSans-Medium_0.ttf / cronos13b_0.ttf / Geog-Bold.otf / IwaOMinPro-Bd-Fate_0.ttf / KozGoPr6N-Bold.otf / KozMinPro-Bold.otf / Lato-Bla.ttf / nyala.TTF / pakenham rg.ttf
Video
Format : AVC
Format profile : High@L5
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 4 547 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.091
Stream size : 771 MiB (76%)
Writing library : x264 core 148 r2638 7599210
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : Japanese
Default : Yes
Forced : No
Adobe Encore:
Format : BDAV
Format/Info : Blu-ray Video
File size : 2,38 GiB
Overall bit rate : 14,4 Mb/s
Maximum Overall bit rate : 48,0 Mb/s
Vídeo
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Sí
Format settings, Reference frames : 4 fotogramas
Codec ID : 27
Bit rate mode : Variable
Bit rate : 13,6 Mb/s
Maximum bit rate : 15,0 Mb/s
Width : 1 920 píxeles
Height : 1 080 píxeles
Frame rate : 23,976 (24000/1001) FPS
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Progresivo
Bits/(Pixel*Frame) : 0.274
Stream size : 2,25 GiB (95%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Results 1 to 9 of 9
Adobe Encore creates a Blu-Ray compliant stream. Your original stream obviously isn't Blu-Ray compatible. VLC and PowerDVD are much more forgiving than a standalone player.
If you don't replace the stream that Encore creates, I'm betting it will play fine on your BR player. -
I'm using BD Rebuilder to try to use the original mkv files, but it doesn't seems to works, there is any way to replace the adobe encore video for the mkv original?
But I supose that if the Adobe Encore encode works, there will be a way to re encode to make it work, I tried handbrake to re encode and works but don't know which exactly parameters use to not lose a lot of quality and not make a 3 GB file like encore
If you want a smaller file size, you can change the bitrate of the encoding preset within Encore.
Choose one of the presets under Blu-ray Transcode Settings.
Certain encoders like TMPGenc and Adobe Media Encoder can make Blu-Ray compatible streams. It can be done (I'm told) in ffmpeg or handbrake -- but you'll have to do a lot of experimenting and still may not succeed. -
Any re-encode involves quality loss. You should probably test a short segment at different settings and see what you consider acceptable.
For more detail you might want to click on "What Is" on the header of this site and choose Blu Ray. (https://www.videohelp.com/hd) There are some good links within the page you get to.
Replacing subtitle tracks on Blu-Ray discs??
By LinkingHeartZ in forum SubtitleReplies: 10Last Post: 27th Aug 2019, 11:46 -
Lossless Editing of M2TS from Blu-ray?
By Sheriff Hobbes in forum EditingReplies: 4Last Post: 3rd Feb 2019, 07:25 -
MKV to m2ts (Blu Ray) conversion
By Damirko1981 in forum Video ConversionReplies: 20Last Post: 30th Dec 2018, 02:17 -
Unable to convert M2TS to Blu-ray ISO
By jacc.sparro in forum Blu-ray RippingReplies: 1Last Post: 27th Dec 2017, 23:37 -
Having trouble creating Blu-Ray disk (.M2TS --> BDMV)
By shadough in forum Authoring (Blu-ray)Replies: 5Last Post: 19th Aug 2016, 10:39
