Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
    Apr 2020
    Germany
    I have just been asked to begin recording lectures at the university my husband works at. I need to invest in a new wifi-ready camera and have been looking at the Sony FDR-AX33, which has come down significantly in price and seems to have all the features I would need.
    HOWEVER I don't know whether I can do what I need to do with that camera--recording 90-min lectures and posting them to the Internet (university online-learning platform).
    Does anyone have experience with this? I would appreciate help
    THANK YOU,
    janet
    Apr 2020
    Germany
    I think I've just answered my own question (downloaded the user manual--duh...)
    The maximum continuous recordable time of a movie is about 13 hours.
    When an AVCHD movie file exceeds 2 GB, the next movie file is created automatically.
    When an MP4 movie file exceeds 4 GB, the next movie file is created automatically.
    **Still would love to hear from any of you who use this camera!
  3. I've recorded close to three hours at a time on those cameras. 90 minutes is no problem.
    When you load the entire file structure of your card into any decent NLE (Premiere, Avid, Vegas Pro) it will stitch the 2GB files together seamlessly.
    You must talk to your university IT department about this.
    And that's what they're paid for.
    FAQs: Best Blank Discs ē Best TBCs ē Best VCRs for capture ē Restore VHS
  5. Member Cornucopia's Avatar
    As someone who has that EXACT job right now, I can say:
    what is the best camera you have? do you want to use that cam to record with? what is your budget?
    most of the profs at my university do not want to layout for a whole lot, so are willing to accept a slight reduction in quality by using a webcam and going straight into the computer.
    Of those, right off the top I'd suggest a Logitech Brio as a fixed-perspective unit. ~$200USD, but prices vary a good bit up and down.
    Then, you can record into OBS, Premiere, Panopto, most any vid app that accepts webcams.
    And get a SEPARATE mic (lav or headset), so you can optimize the positioning - a cam is almost never the optimal place for a mic.
    You can get good ones, wired & wireless, from Shure, Samson, Sennheiser, etc. and some prettty good headsets from Logitech as well.,
    Including some that are straight to USB, if that's the way you want to go.
    Lastly, I would strongly NOT recommend you try to do it all in one long go (you'll get winded, and you probably would want a better take). Do shorter clips - 5-10-20-30 min. and then edit them together and export (at highest quality that your presentation platform will allow).
    And lordsmurf was correct - check w your IT/AV dept.
