Hello dear friends,
I'm bugfixing a tool, that among other things allows to play and cut mpeg videos, the cutting is performed using ffmpeg. I have a number of test videos that can be divided in good and bad ones. The good ones dont do any troubles when displaying or cutting. The bad ones can be played (tried ffplay, vlc and wmp), but when cutting them with ffmpeg, the resulting videos show all kinds of errors - from remaining black while playing to cannot being opened at all. Yet VLC can cut those bad videos just fine and the results are fine videos by the themselves.
The cutting is happening with the following ffmpeg command: ffmpeg -nostdin -y -loglevel info -i in.mpeg -ss h:MM: ss -to h:MM: ss -vcodec copy -copyts out.mpeg
Also let me add that I'm very new to video stuff, so I dont always understand what I'm doing.
What I have tried so far:
- I have tried various combinations of ffmpeg arguments (-ss / -to / -c:v libx264 and many more in different orders). None of the arguments and combinations have provided good cutting results.
- I have used ffprobe on the bad videos and cutting results. Here i found some interesting hints. All the bad videos have only one stream (0:0) while the good ones have two to three streams. Also "ffprobe video.mpg -show_format" says for bad videos "nb_streams=1 ...format_name=mpegvideo format_long_name=raw MPEG video..." and for the good videos "nb_streams=2...format_name=mpeg format_long_name=MPEG-PS (MPEG-2 Program Stream)"
- I have tried some other tools like VLC, windows media player and MediaInfo. VLC is cutting realy awsome. Its cutting results can be played just perfect with any other player.
My question:
- Do you know of ffmpeg cutting arguments that allow to obtain same perfect results as VLC?
- Can you tell me why my bad videos are causing the troubles? What makes them worse than the good ones?
I will gladly provide you with further info.
Thanks in advance.
				Results 1 to 17 of 17
	Try ffmpeg.exe -y -i in.mpeg -ss HH:MM:SS -to HH:MM:SS -c:v copy -c:a copy out.mpg Last edited by ProWo; 3rd Apr 2020 at 04:27.
	Many thank for the quick response ProWo. Here are the results:
 C:\Folder>ffplay.exe in.mpg
 ffplay version git-2020-04-01-afa5e38 Copyright (c) 2003-2020 the FFmpeg developers
 built with gcc 9.3.1 (GCC) 20200328
 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf
 libavutil 56. 42.102 / 56. 42.102
 libavcodec 58. 77.101 / 58. 77.101
 libavformat 58. 42.100 / 58. 42.100
 libavdevice 58. 9.103 / 58. 9.103
 libavfilter 7. 77.101 / 7. 77.101
 libswscale 5. 6.101 / 5. 6.101
 libswresample 3. 6.100 / 3. 6.100
 libpostproc 55. 6.100 / 55. 6.100
 [mpegvideo @ 0000020d3de18fc0] Estimating duration from bitrate, this may be inaccurate
 Input #0, mpegvideo, from 'in.mpg':
 Duration: 00:01:04.12, bitrate: 4000 kb/s
 Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], 4000 kb/s, 25 fps, 25 tbr, 1200k tbn, 50 tbc
 Side data:
 cpb: bitrate max/min/avg: 4000000/0/0 buffer size: 1835008 vbv_delay: N/A
 4.49 M-V: 0.000 fd= 0 aq= 0KB vq= 503KB sq= 0B f=0/0
 <in.mpeg is played>
 C:\Folder>ffmpeg.exe -y -i in.mpg -ss 0:00:05 -to 0:00:25 -c:v copy -c:a copy out.mpg
 ffmpeg version git-2020-04-01-afa5e38 Copyright (c) 2000-2020 the FFmpeg developers
 [mpegvideo @ 00000248ae2eb900] Estimating duration from bitrate, this may be inaccurate
 Side data:
 Output #0, mpeg, to 'out.mpg':
 Metadata:
 encoder : Lavf58.42.100
 Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], q=2-31, 4000 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc
 Side data:
 Stream mapping:
 Stream #0:0 -> #0:0 (copy)
 Press [q] to stop, [?] for help
 [mpeg @ 00000248ae2f43c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
 frame= 495 fps=0.0 q=-1.0 Lsize= 9700kB time=00:00:19.96 bitrate=3981.1kbits/s speed=1.25e+03x
 video:9662kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.392299%
 C:\Folder>ffplay.exe out.mpg
 [mpeg @ 000001c4be1c9080] probed stream 0 failedB sq= 0B f=0/0
 [mpeg @ 000001c4be1c9080] Could not find codec parameters for stream 0 (Video: none, none): unknown codec
 Consider increasing the value for the 'analyzeduration' and 'probesize' options
 Input #0, mpeg, from 'out.mpg':
 Duration: 00:00:19.76, start: 0.540000, bitrate: 4021 kb/s
 Stream #0:0[0x1e0]: Video: none, none, 25 tbr, 90k tbnB f=0/0
 No decoder could be found for codec none
 Failed to open file 'out.mpg' or configure filtergraph
 <out.mpeg is not played>
	Try first without cutting (for test only): ffmpeg.exe -y -i in.mpeg -c:v copy -c:a copy out.mpg. The output can be played?
	The non-cutted output is played.
 C:\Folder>ffmpeg.exe -y -i in.mpg -c:v copy -c:a copy out.mpg
 [mpegvideo @ 00000247c588b800] Estimating duration from bitrate, this may be inaccurate
 Side data:
 Metadata:
 Side data:
 Stream mapping:
 [mpeg @ 00000247c5894280] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
 frame= 1601 fps=0.0 q=-1.0 Lsize= 31428kB time=00:01:04.00 bitrate=4022.8kbits/s speed=1.49e+03x
 video:31309kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.381037%
 Input #0, mpeg, from 'out.mpg': 0KB vq= 0KB sq= 0B f=0/0
 Duration: 00:01:03.92, start: 0.580000, bitrate: 4027 kb/s
 Stream #0:0[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], 4000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
 Side data:
 3.07 M-V: 0.000 fd= 0 aq= 0KB vq= 482KB sq= 0B f=0/0
 <out.mpg is played>
	Then try ffmpeg.exe -y -fflags +genpts -i in.mpeg -ss HH:MM:SS -to HH:MM:SS -c:v copy -c:a copy out.mpg
	out.mpg is not playing
 Code:C:\Folder>ffmpeg.exe -y -fflags +genpts -i in.mpg -ss 00:00:05 -to 00:00:20 -c:v copy -c:a copy out.mpg ffmpeg version git-2020-04-01-afa5e38 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 9.3.1 (GCC) 20200328 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 42.102 / 56. 42.102 libavcodec 58. 77.101 / 58. 77.101 libavformat 58. 42.100 / 58. 42.100 libavdevice 58. 9.103 / 58. 9.103 libavfilter 7. 77.101 / 7. 77.101 libswscale 5. 6.101 / 5. 6.101 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 [mpegvideo @ 00000187199dbf40] Estimating duration from bitrate, this may be inaccurate Input #0, mpegvideo, from 'in.mpg': Duration: 00:01:04.12, bitrate: 4000 kb/s Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], 4000 kb/s, 25 fps, 25 tbr, 1200k tbn, 50 tbc Side data: cpb: bitrate max/min/avg: 4000000/0/0 buffer size: 1835008 vbv_delay: N/A Output #0, mpeg, to 'out.mpg': Metadata: encoder : Lavf58.42.100 Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], q=2-31, 4000 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc Side data: cpb: bitrate max/min/avg: 4000000/0/0 buffer size: 1835008 vbv_delay: N/A Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help frame= 370 fps=0.0 q=-1.0 Lsize= 7258kB time=00:00:14.96 bitrate=3974.4kbits/s speed=1.07e+03x video:7228kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.418553% C:\Folder>ffplay.exe out.mpg ffplay version git-2020-04-01-afa5e38 Copyright (c) 2003-2020 the FFmpeg developers built with gcc 9.3.1 (GCC) 20200328 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 42.102 / 56. 42.102 libavcodec 58. 77.101 / 58. 77.101 libavformat 58. 42.100 / 58. 42.100 libavdevice 58. 9.103 / 58. 9.103 libavfilter 7. 77.101 / 7. 77.101 libswscale 5. 6.101 / 5. 6.101 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 [mpeg @ 000001cce5029080] probed stream 0 failedB sq= 0B f=0/0 [mpeg @ 000001cce5029080] Could not find codec parameters for stream 0 (Video: none, none): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpeg, from 'out.mpg': Duration: 00:00:14.80, start: 0.620000, bitrate: 4017 kb/s Stream #0:0[0x1e0]: Video: none, none, 25 fps, 25 tbr, 90k tbn No decoder could be found for codec none Failed to open file 'out.mpg' or configure filtergraph
	OK, then try first: ffmpeg.exe -y -fflags +genpts -i in.mpeg -c:v copy -c:a copy out.mpg
 second pass: ffmpeg.exe -y -fflags +genpts -i out.mpg -ss HH:MM:SS -to HH:MM:SS -c:v copy -c:a copy newout.mpg
	newout.mpg doesn't play
 Code:C:\Folder>ffmpeg.exe -y -fflags +genpts -i in.mpg -c:v copy -c:a copy out.mpg ffmpeg version git-2020-04-01-afa5e38 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 9.3.1 (GCC) 20200328 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 42.102 / 56. 42.102 libavcodec 58. 77.101 / 58. 77.101 libavformat 58. 42.100 / 58. 42.100 libavdevice 58. 9.103 / 58. 9.103 libavfilter 7. 77.101 / 7. 77.101 libswscale 5. 6.101 / 5. 6.101 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 [mpegvideo @ 000001f72145ba40] Estimating duration from bitrate, this may be inaccurate Input #0, mpegvideo, from 'in.mpg': Duration: 00:01:04.12, bitrate: 4000 kb/s Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], 4000 kb/s, 25 fps, 25 tbr, 1200k tbn, 50 tbc Side data: cpb: bitrate max/min/avg: 4000000/0/0 buffer size: 1835008 vbv_delay: N/A Output #0, mpeg, to 'out.mpg': Metadata: encoder : Lavf58.42.100 Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], q=2-31, 4000 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc Side data: cpb: bitrate max/min/avg: 4000000/0/0 buffer size: 1835008 vbv_delay: N/A Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help frame= 1601 fps=0.0 q=-1.0 Lsize= 31432kB time=00:01:04.00 bitrate=4023.3kbits/s speed=1.28e+03x video:31309kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.393813% C:\Folder>ffmpeg.exe -y -fflags +genpts -i out.mpg -ss 00:00:05 -to 00:00:20 -c:v copy -c:a copy newout.mpg ffmpeg version git-2020-04-01-afa5e38 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 9.3.1 (GCC) 20200328 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 42.102 / 56. 42.102 libavcodec 58. 77.101 / 58. 77.101 libavformat 58. 42.100 / 58. 42.100 libavdevice 58. 9.103 / 58. 9.103 libavfilter 7. 77.101 / 7. 77.101 libswscale 5. 6.101 / 5. 6.101 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 Input #0, mpeg, from 'out.mpg': Duration: 00:01:04.04, start: 0.540000, bitrate: 4020 kb/s Stream #0:0[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], 4000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc Side data: cpb: bitrate max/min/avg: 4000000/0/0 buffer size: 1835008 vbv_delay: N/A Output #0, mpeg, to 'newout.mpg': Metadata: encoder : Lavf58.42.100 Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 352x288 [SAR 12:11 DAR 4:3], q=2-31, 4000 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc Side data: cpb: bitrate max/min/avg: 4000000/0/0 buffer size: 1835008 vbv_delay: N/A Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help frame= 371 fps=0.0 q=-1.0 Lsize= 7274kB time=00:00:14.96 bitrate=3983.2kbits/s speed=1.15e+03x video:7244kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.416329% C:\Folder>ffplay.exe newout.mpg ffplay version git-2020-04-01-afa5e38 Copyright (c) 2003-2020 the FFmpeg developers built with gcc 9.3.1 (GCC) 20200328 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 42.102 / 56. 42.102 libavcodec 58. 77.101 / 58. 77.101 libavformat 58. 42.100 / 58. 42.100 libavdevice 58. 9.103 / 58. 9.103 libavfilter 7. 77.101 / 7. 77.101 libswscale 5. 6.101 / 5. 6.101 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 [mpeg @ 0000027fb7959480] probed stream 0 failedB sq= 0B f=0/0 [mpeg @ 0000027fb7959480] Could not find codec parameters for stream 0 (Video: none, none): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpeg, from 'newout.mpg': Duration: 00:00:14.80, start: 0.620000, bitrate: 4026 kb/s Stream #0:0[0x1e0]: Video: none, none, 25 fps, 25 tbr, 90k tbn No decoder could be found for codec none Failed to open file 'newout.mpg' or configure filtergraph
	What's about ffmpeg.exe -y -ss HH:MM:SS -i in.mpeg -to HH:MM:SS -c:v copy -na copy out.mpg? Last edited by ProWo; 3rd Apr 2020 at 05:39.
	I notice you arer copying your cuts. FFMpeg will cut exactly where you tell it but if you do not cut on a key frame, the results are varied just as you describe. The results are also affected by where you place your search (-ss) , as an input or as an output. Most free cutters cut at the key frames so they almost always work. The only safe way is to cut at a key frame and be aware that if you end on a 'B' frame, ffmpeg will take 2 frames to end. That means cut at Bbp (Capital B) will end at the P frame.
 The only safe way is to cut at a Key frame. I use a CMD file to find the key frames and cut there. You can also use a AVIsynth script to show the Frame type as you play. Below is a sample player showing Frame types and the type of weird sequences you can get from an MPG file.
 Frame.mpg
 No. pts_time type
 0 0.200000 1 I
 1 0.240000 0 P
 2 0.280000 0 P
 3 0.320000 0 P
 4 0.360000 0 P
 5 0.400000 0 P
 6 0.440000 0 P
 7 0.480000 0 P
 8 0.520000 0 P
 9 0.560000 0 P
 10 0.600000 0 B
 11 0.640000 0 B
 12 0.680000 1 I
 [Attachment 52577 - Click to enlarge]
 ALSO notice there is a 0.20000 offset for first frame so that has to be determined also and this is an open GOP (B frame Preceding I frame) So this further makes it hard to determine where to cut.
 Use MediaInfo to check the type of GOP on the working ones and the non-working ones. Use FFprobe to find out what frame you are trying to cut at.
	@ProWo
 doesn't work either. But, what works is:What's about ffmpeg.exe -y -ss HH:MM:SS -i in.mpeg -to HH:MM:SS -c:v copy -na copy out.mpg?
 All i can say is that the result of this command is a cutted video that can be played with VLC, ffplay and wmp, also thumbnails can be extracted from it.Code:ffmpeg.exe -i in.mpeg -ss HH:MM:SS -to HH:MM:SS out.mpg
 I'm a bit curious as I'm sure it was one of the combinations I've tried yesterday, but whatever ... at least i got my cutted chunks now.
 Still thank you a lot for the ideas!
 @Badman1
 Yea, all this keyframe thingy can be a potential problem. Yesterday I read somewhere that curent versions of ffmpeg always takes the closest keyframe when toggled with -ss. That goes along with my personal evaluations of some cuts. I used "ffprobe video.mpeg -show_frames | findstr pict_type" to get the frame types and the few cuts I looked at, all started with an I-Frame without me taking particular of it. Also the videos have been a couple miliseconds shorter.
 My problem is solved now. And once more, thanks to ProWo and Badman1!
  ffmpeg cutting: how to get negative start time?By Luke M in forum EditingReplies: 1Last Post: 25th Jul 2018, 12:00
  FFmpeg cutting/joining findingsBy Budman1 in forum EditingReplies: 4Last Post: 11th Jul 2018, 01:25
  other video cutting softwares? or how can it be done by ffmpeg's commands?By sommers in forum Newbie / General discussionsReplies: 11Last Post: 10th Jun 2017, 00:41
  Cutting a video with FFMPEG in the same format/quality?By Unknown01 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2016, 03:14
  ffmpeg is not cutting accuratelyBy shuantsu in forum Newbie / General discussionsReplies: 11Last Post: 31st Jul 2015, 17:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
