Hello,
I recently purchased a used but seemingly good condition combi-vision tv with built in vhs player. It worked just fine for about a day when I have to give the top part of the tv a good old whacking to get the sound to work! Sometimes also, when I put a tape in, it just rejects it! And I have to try over and over again until it magically works
PLEASE HELP!
[Attachment 52569 - Click to enlarge]
	I used to have one of those years ago! But can't really help with your issue, have you tried to contact any electronics shop to ask for advice?
	You have been watching too many comedy shows where the guys would give the top of the tv a good knock to get it working.
 Chances are you damaged more than you fixed and something has worked loose. And with these units being quite old the chances of getting it repaired are quite remote with parts being non-existent.
  No display nor sound while playing the VHS playerBy TommyL in forum RestorationReplies: 17Last Post: 11th Mar 2021, 12:18
  Built-in VHS player in CRTs, image quality vs external player?By xAlienxx in forum MediaReplies: 4Last Post: 7th Mar 2019, 18:57
  Checking through VHS tapes on old player?By Master Tape in forum MediaReplies: 10Last Post: 22nd Sep 2016, 11:16
  VHS Player Audio is really low when playedBy Sir_Loin in forum Capturing and VCRReplies: 5Last Post: 20th Mar 2016, 10:47
  Does anybody have a D-VHS player that they're not using?By ArianK in forum DVD & Blu-ray RecordersReplies: 4Last Post: 4th Jan 2016, 20:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
