I am using QTGMC, and for some reason when things are in motion, I am seeing a half invisible artifact, which is a piece of the next or previous frame. Almost as if it is a piece of blending.
Here is an example.Code:QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", fpsdivisor=2, sourcematch=3)
https://slow.pics/c/GmnpMy9q
If I do not deinterlace at all, or I use TIVTC which sucks on this particular source, I do not get those artifacts.
I have tried changing multiple settings and parameters, but I have had no luck. Is this something I will just have to deal with?
Maybe try turning off the temporal denoisers. http://avisynth.nl/index.php/QTGMC#Noise_Bypass_.2F_Denoising Or switch to very slow for better temporal denoising.
I tried both of those. It does not seem to fixing it for me.
Perhaps someone can suggest a better deinterlacing setting for TFM? The TIVTC/TFM has a lot of leftover artifacts.
tfm(order=1).tdecimate(mode=1,hybrid=0)
Here is a sample video.
https://mega.nz/file/xxQklQBC#QRe7KTtvqEdKwEN4umpr78fsY0ly_ncgyDgICZ3gDMkLast edited by killerteengohan; 2nd Apr 2020 at 11:48.
I get a lot of this when I try TIVTC
(Image removed)Last edited by killerteengohan; 2nd Apr 2020 at 23:35.
If you are out of options, I would also try going back to an older version like 3.32 (~2015). http://forum.doom9.org/showthread.php?t=156028 I have not done any tests personally but in the past years I've had the hunch that QTGMC has gotten worse over the years with artifacts.
3.32 is actually the one I am using.
I just decided I'll live with it. I spent a good 3 hours trying tons of combinations of settings and nothing I tried stopped it. When the video is on motion, you don't even see the artifacts. You have to know about them, be looking for them, or pause at just the right time to even see them on playback, so I'll live with it.
I got tfm with clip2 to work, and it didn't have the artifacts, but I went with the QTGMC and thought it looked better overall.
tfm(order=1, clip2=QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", FPSDivisor=2, sourcematch=3, tr1=2, tr2=2, NoiseTR=2), cthresh=4, mi=31)
Thanks for the suggestions though.
Help: Intensity Pro 4k - Interlaced Source = Motion Artifacts
By videobackup in forum Capturing and VCRReplies: 10Last Post: 30th Mar 2020, 22:05 -
Youtube encoder artifacts specific to 2D motion graphics?
By chconnor in forum Video Streaming DownloadingReplies: 0Last Post: 27th Jun 2019, 17:28 -
I think this just needs QTGMC...
By pooksahib in forum Video ConversionReplies: 2Last Post: 30th May 2019, 03:12 -
QTGMC deinterlacing
By Katherine1 in forum RestorationReplies: 2Last Post: 10th Feb 2019, 10:02 -
Help with QTGMC?
By attackworld in forum EditingReplies: 3Last Post: 26th Nov 2018, 21:57
