A video file I have stutters no matter what player I play it with, and mediainfo says it has a constant framerate of 29.97, while in reality it often dips below that. There are however some parts which run smoothly. Is there any software to fix this, detecting the stutters (which are nearby frames that contain the same information), deleting all but one of them, and interpolating to the previous and next frame to increase smoothness? Or just the deleting frames part, and transforming it into a variable framerate file.
Here's a sample of the video: https://youtu.be/LXU3wu7rJLg
The beginning is pretty bad, but starting at around 0:13 it starts being smoother (with some hiccups)
Looks like a bad capture. Try using different software the next time you try to capture, and spend some time "tuning" the capture software.
The gaps in that video are way too large (too many frames missing) to be fixed. -
Oh this is not my capture, I found it online, it's an old VHS transfer it seems. But thanks. It's a shame that it can't be recovered :/
Video streams stutters in Firefox, Vivaldi, Opera but not in Chrome?
By rv93 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2019, 06:40 -
OPPO 203 , VP9 4K stutters for some reason but H.264 4K is ok
By s8n in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th Mar 2018, 15:45 -
intact MPEG-PS file stutters upon playback and won't (fvcking) decode
By tennet in forum Newbie / General discussionsReplies: 16Last Post: 29th Aug 2016, 00:14 -
Se7en (VC-1) stutters using BD-Rebuilder 50.11 to encode
By PatrickBatman in forum Blu-ray RippingReplies: 5Last Post: 11th May 2016, 08:36 -
[SOLVED] 720p60 video stutters when playing
By white_snake in forum Software PlayingReplies: 31Last Post: 20th Feb 2016, 10:55
