  1. I am looking at this WebCam and it says it is 1080 P but I want to know this?
    What is the Frame Rate?
    What is the Audio FREQ. and Bit Rate?
    https://www.amazon.com/gp/product/B07MVY1H9V/ref=ox_sc_act_title_1?smid=A3J517XUK5V6EJ&psc=1
  2. Member Cornucopia's Avatar
    Cam: As per numerous sources (ebay, reviews, unboxing), 30fps.
    Mic: doesn't say anywhere. Likely samplerate options are 44.1kHz and 48kHz, similarly, likely bitrates are up to ~256kbps per channel.
    However, my impression from reviews is that the audio is mediocre. Guessing it probably has freq. response up to ~12-15kHz, and down to ~180Hz. It is using omni dynamic mics in a near-coincident stereo pair, so the imaging isn't going to be great, and there will be more ambience/less directionality than optimal for webcams. It likely is using digital NR to compensate - not the best tactic.
