Hi all,
Audible is giving away access to kid's stories while the schools are closed, wanted to download so I don't need to stream it every time and I could take the audio with me if I go off line.
The link is https://stories.audible.com/start-listen
For example Winnie-the-Pooh story is at https://stories.audible.com/pdp/B002V1BPOQ?ref=adbl_ent_anon_ds_pdp_pc_cntr-0-0
I tried YouTubeDL and streamlink defaults but no luck, the URL is not recognized.
Then I tired to go by m3u8 but I get 403 Forbidden error. I tired to include referer link but that didn't work either.
Can anyone shine some light on it?Code:youtube-dl --referer="https://stories.audible.com/pdp/B002V1BPOQ?ref=adbl_ent_anon_ds_pdp_pc_cntr-0-0" "https://audiblecdns3prod-vh.akamaihd.net/i/295894/audiblewords/content/bk/blak/000838/V$252555$V/aax/bk_blak_000838_22_32.mp4/master.m3u8"
Results 1 to 13 of 13
youtube-dl worked for me. You have to get an m3u8 link from a browser's devoloper tools.
The link may change occasionally so you may need to get a fresh one.Code:youtube-dl "https://audiblecdns3prod-vh.akamaihd.net/i/295894/audiblewords/content/bk/blak/000838/V$252555$V/aax/bk_blak_000838_22_32.mp4/master.m3u8?hdnea=st=1585613430~exp=1585613490~acl=/i/295894/audiblewords/content/bk/blak/000838/V$252555$V/aax/bk_blak_000838_22_32.mp4/*~hmac=4ef97b8ddaf4c014efe35edbfccea55ab1da0e9a218806d851032342142b9884"
YouTubeDL works. Before I tried to use the link but cut the part after m3u8, stupid me.
YouTubeDL works when I put the link as "link" bit doesn't when it goes without "". I am sure there is an explanation somewhere but I couldn't find it.
Many thanks. -
Can you post the exact two youtube-dl codes ("works when I put the link as "link" bit doesn't when it goes without").YouTubeDL works when I put the link as "link" bit doesn't when it goes without "". I am sure there is an explanation somewhere but I couldn't find it.
I can only see by exact examples.
Thank you. -
Sometimes the command line interpreter will add spaces with certain characters in a URL if there are no quotes around it.
This one worked
This one didn't workCode:youtube-dl "https://audiblecdns3prod-vh.akamaihd.net/i/295894/audiblewords/content/bk/blak/000838/V$252555$V/aax/bk_blak_000838_22_32.mp4/master.m3u8?hdnea=st=1585613430~exp=1585613490~acl=/i/295894/audiblewords/content/bk/blak/000838/V$252555$V/aax/bk_blak_000838_22_32.mp4/*~hmac=4ef97b8ddaf4c014efe35edbfccea55ab1da0e9a218806d851032342142b9884"
Code:youtube-dl https://audiblecdns3prod-vh.akamaihd.net/i/295894/audiblewords/content/bk/blak/000838/V$252555$V/aax/bk_blak_000838_22_32.mp4/master.m3u8?hdnea=st=1585613430~exp=1585613490~acl=/i/295894/audiblewords/content/bk/blak/000838/V$252555$V/aax/bk_blak_000838_22_32.mp4/*~hmac=4ef97b8ddaf4c014efe35edbfccea55ab1da0e9a218806d851032342142b9884
I tried one after another with a few seconds in between tries. -
go to developer console go to network type m3u8 you will see master.m3u8 right click on it and select copy and use it with youtube-dl ffmpeg or TVDownloader goodluck
thanks i got the link but when i try to convert it with youtube-dl this happens
and yes it is up to dateCode:\youtube-dl>youtube-dl "https://audiblecdns3prod-vh.akamaihd.net/i/295898/audiblewords/content/bk/potr/000008/V$10642821$V/files/bk_potr_000008_22_32.mp4/master.m3u8?hdnea=st=1600648313~exp=1600648373~acl=/i/295898/audiblewords/content/bk/potr/000008/V$10642821$V/files/bk_potr_000008_22_32.mp4/*~hmac=e5af70e0ff2883c04d61c3c5290ccab7f248c660c673a339efdd0bf4634ae586" [generic] *~hmac=e5af70e0ff2883c04d61c3c5290ccab7f248c660c673a339efdd0bf4634ae586: Requesting header WARNING: Could not send HEAD request to https://audiblecdns3prod-vh.akamaihd.net/i/295898/audiblewords/content/bk/potr/000008/V$10642821$V/files/bk_potr_000008_22_32.mp4/master.m3u8?hdnea=st=1600648313~exp=1600648373~acl=/i/295898/audiblewords/content/bk/potr/000008/V$10642821$V/files/bk_potr_000008_22_32.mp4/*~hmac=e5af70e0ff2883c04d61c3c5290ccab7f248c660c673a339efdd0bf4634ae586: HTTP Error 405: Method Not Allowed [generic] *~hmac=e5af70e0ff2883c04d61c3c5290ccab7f248c660c673a339efdd0bf4634ae586: Downloading webpage ERROR: Unable to download webpage: HTTP Error 403: Forbidden (caused by HTTPError()); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
Hello the link expires very fast i think +- 60 seconds so you need to get a fresh m3u8 link and download it right away get the m3u8 link and paste it in TVDownloader and it will download or use youtube-dl make sure you have ffmpeg installed example command >> youtube-dl.exe -f best "https://audiblecdns3prod-vh.akamaihd.net/i/295891/audiblewords/content/bk/schc/001459/V$3666271$V/files/bk_schc_001459_22_32.mp4/master.m3u8?hdnea=st=1600684633~exp=1600684693~acl =/i/295891/audiblewords/content/bk/schc/001459/V$3666271$V/files/bk_schc_001459_22_32.mp4/*~hmac=f0b5e96b74a2ee220fb96b3e61b18aee5f90f0399b5 9a355f895555ce671a16f" and it will download without errors tested and worked with both methods i suggest TVDownloader so you need to only provide the m3u8 link goodluck
Downloading WEBM Audio
By Teac23 in forum Video Streaming DownloadingReplies: 4Last Post: 13th Aug 2019, 04:11 -
Downloading Just Audio From Youtube
By cornemuse in forum AudioReplies: 6Last Post: 11th Aug 2019, 12:39 -
Downloading best quality audio from youtube, and in general
By getwellsam in forum AudioReplies: 7Last Post: 5th Jun 2018, 17:37 -
Seeking free conversion-downloading program, or just the best downloading
By jimmo in forum Video ConversionReplies: 6Last Post: 8th Jan 2017, 16:32 -
Making Video Audible
By ConverterCrazy in forum Newbie / General discussionsReplies: 8Last Post: 18th Aug 2015, 15:45
