Below is a part from an 'error-report' from ffmpeg
Input #0, mpegts, from 'c:\downloads\SomeVideo2019.ts':
Duration: 01:09:57.78, start: 35515.235978, bitrate: 10079 kb/s
Program 33020
Stream #0:0[0xcfb](dut): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 256 kb/s
Stream #0:1[0xcfc](GOS): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 256 kb/s (visual impaired) (descriptions)
Stream #0:2[0x149]: Unknown: none ([5][0][0][0] / 0x0005)
Stream #0:3[0xcfa](dut): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 448 kb/s
Stream #0:4[0xcfe](dut): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006)
Stream #0:5[0xcff](dut): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
Stream #0:6[0xd00](888): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
Stream #0:7[0xd01](dut,dut): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream #0:8[0xcf9]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Program 33030
Program 33050
Please note the Stream #0:6 (bold/italian).
As said, this was generated because of a wrong ffmpeg instruction.
Is there a tool to find out the subtitle streams?
It is simply by coincidence, i.e. using simply a wrong instruction that I found out the 888 number in the error report.
This number I needed for something else.
I have not found a ffmpeg parameter that does provide this information
Could not find this info in MediaInfo
Anyone has a suggestion?
Thanks.
If you open a .ts file with Subtitle Edit (File -> Open), you will get a "subtitle chooser" with preview, like this:
THANK you, THANK you very much!
Fantastic - I was really not aware of this feature.
Much, much easier than the way I was doing it:
I found out the stream (888) from error report ffmpeg
then in CCextractor I entered that number at "Page for subtitles"
[Attachment 52546 - Click to enlarge]
Again, many thanks!
Extract subtitles from MPEG-TS-file (DVB Subtitle & Teletext) using ffmpeg
By DeafYakuza in forum SubtitleReplies: 8Last Post: 13th Jun 2019, 14:40 -
multiAVCHD - How to change font size for Audio Subtitle Page ?
By VidGuy82 in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Apr 2019, 11:37 -
Extract subtitles from MPEG-TS-file (DVB Subtitle) using ffmpeg
By T-buch in forum Video ConversionReplies: 22Last Post: 12th Mar 2017, 06:19 -
Problem with Embedded DVB subtitle tracks
By criggs in forum SubtitleReplies: 3Last Post: 14th Oct 2016, 18:06 -
DVB subtitle files
By alexandretss in forum SubtitleReplies: 2Last Post: 25th Jul 2016, 07:56
