This is probably a very basic question. If I'm taking some home movies with my iphone, and I want to do some very basic editing (nothing more than trimming footage or cutting parts out of clips), what would be the best way to do that without changing the original quality very much?
I tried iMovie a little bit, but it looks like when you're all done and you export it, that is going to have a somewhat significant change depending on what options you pick. So next I tried QuickTime Player to edit. I think that might be the best option I've discovered, because you can just save the new video (rather than exporting which you can also do on QuickTime). Anyways, I thought I would just throw it out there to run this by anyone, since I don't know much about these things.
To be clear, I don't really care much whether what I am doing makes the file size larger or smaller (I noticed it did make the .mov's a little bigger after I saved in QuickTime, even if the clip became a few seconds shorter, but that doesn't matter much). All I'm trying to do is make simple cuts/trims and then keep the file as close to the original as possible with hopefully about the same quality. Unless anyone has a better suggestion, I'll probably just go ahead and save them after editing on QuickTime. Thanks.
you can try software like this, but there are no guaranties it can cut on the frame you want. gops(groups of pictures) can be up to 10 seconds long and your intended cut point may not be on an I-frame - LosslessCut
1. The bitrate of the edited video should be similar to or greater than the original mp4 video. If you drop the bitrate in the final video, quality will go down. It's simply the nature of the reencoding process.
2. Some editors can cut without reencoding the entire remaining video. This is ideal. Tmpgenc is one example. Apparently, you find QuickTime might well do this, too.
How simple would this editing be?
By GBfromtheway in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2020, 00:36 -
Need Simple Software Recommendation For Simple Editing Tasks
By Snoopy329 in forum EditingReplies: 13Last Post: 15th Feb 2020, 12:55 -
Simple Video Editing Software for a 9 Year Old?
By MikeInVT in forum EditingReplies: 5Last Post: 14th Dec 2017, 05:31 -
First time using video, simple audio editing question, thanks!
By teacherwayne in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2017, 22:45 -
Javaimagephp - Ultra simple All-in-One Video Editing studio
By rbenmass in forum EditingReplies: 0Last Post: 2nd Sep 2015, 12:25
