Hello anyone could help me how i can convert .mkv files to blu ray discs to be played in my bluray player i tried many softwares didnt work such as DVDFab , tsMuxER and multiAVCHD and ended up failing so any simple software i can use to burn these .mkv files with their subtitles to my blank bluray discs ? thanks alot
Try BD Rebuilder. The only problem I have had with MKV files and BD Rebuilder is that it won't import Dolby TrueHD from an MKV file. I think it has to do with tsMuxer not supporting Dolby TrueHD inside of MKV.
Have you tried simply burning a mkv file to a DVD-R as data and seeing if your Blu ray player supports mkv as a data file. If so you can then try it on a Blu ray blank
BD3D2MK3D: Convert 3D BDs or MKV to 3D SBS, TAB or FS MKV - Support thread
By r0lZ in forum Blu-ray RippingReplies: 562Last Post: 15th Sep 2025, 08:18 -
How to easily burn in/hardcode srt subtitles to mp4/mkv with VidCoder
By Baldrick in forum User guidesReplies: 65Last Post: 25th Jun 2024, 02:11 -
How to burn a blu-ray video disc using MKV files with these specs?
By robertazimmerman in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Apr 2019, 22:14 -
Handbrake's best settings to simply burn .srt over a .mkv
By coderkidz in forum SubtitleReplies: 3Last Post: 27th Mar 2019, 05:47 -
Customize and burn in subtitles into a mkv
By [ss]vegeta in forum SubtitleReplies: 1Last Post: 1st Dec 2016, 11:08
