I was just wondering, is there any quality difference in the output between doing a 3-pass encode and a 1-pass encode done 3 times over?
Crichton
Your river-rafting guide up sh*t creek... -
According to the cce manual and in my opinion you will have. At least at low bitrates, I mean, lower than 2000 kbps.
I'm trying out a 3-pass as we speak...
What I'm getting for an answer on this is that it's EXCELLENT to to 3 passes for a movie in CCE, but over that is usually overkill.
I hope I see fewer blocks than with TMPGEnc...
doing a 2 pass i found that i still saw some blockz on some parts (but didnt try it out on a dvd player). But doing a 3 pass (really a 4 pass, i think) no blockz, smooth as a striper'z azz, and played great.
im doing a 2 and 3 pass test on a trailer, since theres no point waiting ten hours to see tha movie, and find out i wasnt happy with the quality.
ZtR -
Yes - 3 pass on CCE would be 4-pass on TMPGEnc.
If you do 3 1-pass's on CCE, it's the same as a single 3-pass. I quite often interrupt CCE after a pass, then resume it later - just don't kill the *.vaf file that it creates. I personally have the two passes output to different files, but I'm not sure that's required for the multiple passes to work - as far as I know, all the info is in the *.vaf file. -
Vidguy
Thanx man. Yeah that's what I gathered from the manual. I just wanted to make sure someone else took it the way I did. I've never 'interrupted' CCE after a pass but I'll try it with a lil file to see if I can get it to resume
Crichton
I'm gonna go ahead and post this question here, too (since nobody seems to know the answer elsewhere)...
What settings do you use to multiplex in bbMPEG to make a non-standard (MPEG-1 VBR) VCD? NOTHING I'M DOING WORKS.
I did the video in CCE, and either that's corrupted, or my settings are batty for multiplex.
What settings should I use in bbMPEG? List everything, please... thanks!
P.S. - Tried TMPGEnc's multiplex, also doesn't work... a 585MB .m2v, and 92MB .mp2 are merging into a 603MB .mpg! And this is using both TMPGEnc AND bbMPEG! "Underflow" errors all over the place!
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
Quick AVIdemux question!
By janlafata in forum EditingReplies: 16Last Post: 17th Mar 2009, 01:19 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04
