Results 1 to 10 of 10
  1. Hi,
    i wrote a little servicing programm for Windows 10/11.
    It is lightweight and portable, for any CPU (x86, x64, ARM).
    It uses the most necessary DISM commands for the Windows Component Store; it can check, scan, analyze, clean and repair it.
    It can perform a system file check (with repair).
    It can install CAB updates.
    It displays information about offline Windows images.
    It can convert ESD to WIM images.
    It can detect the Reserved Storage Status, enable or disable it.
    Enjoy
    September 09 2024, update to v1.3.1.02
    High DPI compatible now.
    Download: https://files.videohelp.com/u/292773/Dism-gui.zip
    Jul 2008
    Old Dominion
    Cool, but I don't see a download link in the post.
  3. Originally Posted by mail2tom View Post
    corrected
  4. May 26 2020, update to v1.2.5.
    Added ResetBase switch to Component Cleanup.
    Use with caution.
  5. September 10 2020, update to v1.2.6.
    Little improvements.
  6. October 2 2020, update to v1.2.8.
    Fixed: COMSPEC problem with sfc.exe
    Added: In the ESD->WIM conversion now all contents and not only a single index can be converted.
  7. June 21 2021, update to v1.2.9.
    Added: Icon
    Improved: Little code improvements
  8. November 12 2023, update to v1.3.1.
    Little code improvements.
    Added: Warning for component cleanup.
  9. Many Thanks 👍🏻.
    Just a question! Is it possible to add an option to delete SoftwareDistribution folder after updating the OS (without needing to go for Safe Mode)?
  10. September 09 2024, update to v1.3.1.02
