Page 86 of 115
FirstFirst ... 36 76 84 85 86 87 88 96 ... LastLast
Results 2,551 to 2,580 of 3444
  1. @ProWo
    v3.4.5.08
    It is not a big deal .. FYI
    [Attachment 88594 - Click to enlarge]
  2. ATTENTION PLEASE!
    With the next nightly build (3.4.5.09), the storage mode for settings will change from PC-specific to global.
    This means that when you start the new version, your previous settings will no longer apply.
    If you want to keep your previous settings, you must proceed as follows:
    After the update, the first start window will be displayed. Close the app using the X in the top right corner.
    Open the portable.config file in a text editor, select all lines in section 1, and copy them to section 2, overwriting it.
    Then save the file.
    You can then start clever as usual.
    [Attachment 88596 - Click to enlarge]
    NB
    If you want to use earlier versions, leave section 1 in portable.config.
    Otherwise, you can also delete it.
    EDIT:
    If you want, you can adjust the portable.config now, then it will be ready for the new version.
  3. Are planning to make v.09 available soon .. ?
  4. Originally Posted by videoAI View Post
    Yep, tomorrow.
  5. Q: if we left sec#1 in, going forward, are you going to be updating both sections? or only sec #2?
    ATTENTION PLEASE!
  6. Originally Posted by videoAI View Post
    From version 3.4.5.09 only section #2.
    BTW
  7. tested to encode a few FLAC (7.1 to eac3) tracks and they never finish encoding - the timer keeps going after 100% is done and the file is never written on the disk.
  8. Originally Posted by mannequin80 View Post
    Just tested flac 7.1 to eac3 5.1 (7.1 isn't available, because the ffmpeg eac3 encoder allows max 6ch only).
    Works flawless as aspected.
    Could you post the exact steps you did?
  9. @ ProWo
    If you find some time - a tidy cut page might look something like this.
    It's in the order of what needs to be done.
    Select KF search app, the stream index, the keyframe type,
    search cut points, enter start and end time,
    add cut mark.
    [Attachment 88609 - Click to enlarge]
    EDIT: Or like that:
    [Attachment 88610 - Click to enlarge]
  10. Originally Posted by Findu View Post
    Thank you for your efforts, but I don't like it.
  11. @ProWo
    v3.4.5.09
    Deleted my old backup file to make a new one. I guess clever didn't like that ..
    Have you migrated backup settings to the Roaming profile as well? [Settings.VB$StateMachine ??]
    @ProWo you have to check index values before calling or using arrays. Programming 101.
    ************** Exception Text **************
    System.IndexOutOfRangeException: Index was outside the bounds of the array.
    at clever_FFmpeg_GUI.CL_Settings.Backup_check()
    at clever_FFmpeg_GUI.CL_Settings.VB$StateMachine_72_S tart_controls.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.ExceptionServices.ExceptionDispatch Info.Throw()
    ************** Loaded Assemblies **************
  12. @ ProWo
    v3.4.5.09 Feedback
    When you set up 09 without a portable.config, you are in a loop setting up the LUT's folder.
    No paths or folders are accepted.
    When you kill the app, you have this entry <luts_path>C:\</luts_path> in the portable.config.
    Default is <luts_path></luts_path>.
  13. @ProWo
    v3.4.5.09
    Now that the configuration settings is really portable,
    would it make sense for the backup to include the
    portable.config [to portable.bck] as well, which I assume,
    would allow restoring settings on another pc.
    [Attachment 88611 - Click to enlarge]
  14. @ ProWo
    I like the second Cut window. But don't worry if it doesn't work for you.
    Still the same restore Problem in 09. It look like that the first restore of 08 open a second instance of 09 and close the older one. At the second restore, 09 get closed first and 08 opens up. So I still have to run restore twice.
    EDIT: Replacing an old backup before doing an update works well within the app.
  15. @ ProWo
    How about moving the stream selection field a little to the left to fit the position of the field above?
    [Attachment 88613 - Click to enlarge]
  16. Originally Posted by Findu View Post
    Please be patient, I don't understand the problem.
    If you restore from 09 to 08, then 08 will start.
    With 08 started, you don't have access to the 08 backup, and you will be prompted to update to 09.
    If you do that, 09 will start and you will be offered a restore to 08.
    That works as expected for me.
  17. Originally Posted by Findu View Post
    Bug, will be fixed.
  18. Originally Posted by Findu View Post
    You're right, will be done.
  19. > Please be patient, I don't understand the problem.
    I only have a problem with the restore not working on the first try.
    In more detail:
    When I restore from 09 to 08, a second instance of 09 opens in front, than the first instance of 09 is closing, than the file rename (the renamed 08 executable) appear in the app folder.
    When I repeat the restore from 09 to 08, most of the time 09 opens.
    If the restore still fail, I close the app with rename still in the folder.
    I open 09 and do a restore to 08, 09 is closing first and 08 opens second.
    The restore always works when rename exists before I start the app and perform a restore.
  20. Setting up the LUT's folder in .10 is working. Thank you.
  21. Originally Posted by Findu View Post
    In more detail:
    Could you post your 08 backup here (I don't have it anymore) to test further?
  22. I had to zip it as I get invalid file selecting the bck
    https://forum.videohelp.com/attachment.php?attachmentid=88619&stc=1&d=1757346430
  23. Originally Posted by Findu View Post
    Thx, I have now performed 20 cycles of restore to 08 and update to 10;
    in one case, the situation you described occurred.
    I will work on the timings of the update/restore scripts and on the automatic deletion of updater.bat.
    EDIT:
    Done with 11 (However, the effect will only be noticeable with restores of >=11).
  24. Why does the "Success" message disappear so quickly? Couldn't it stay on longer or even permanently. Sometimes I leave to do something else and when I come back, I rely on that message to let me know if the job was done.
    No big deal, but does it serve any purpose other than the cool effect.
  25. Originally Posted by ProWo View Post
    nothing out of the ordinary - adding the file, applying volume and filters and then it's just doing this forever until aborted:
    [Attachment 88627 - Click to enlarge]
  26. Originally Posted by mannequin80 View Post
    Thx for the hint.
    Found the bug, is fixed now.
  27. Originally Posted by davidt1 View Post
    No. I'll leave it as it is, because that way you can see that it refers to the last action.
    If the message remains permanently displayed, a clear reference is missing.
  28. Hello ProWo,
    love your prgramm, using it since a few days a lot.
    2 things I want to ask.
    Can you add the "AC3 Decoder DRC" option for EAC3 Input Files, too?
    And maybe set the DRC default always to OFF ?
    Thanks.
  29. Originally Posted by diginoob View Post
    Will be done.
    No. because ffmpegs default is on.
    You can set it off, if you like.
    Dolby itself recommends turning it on.
  30. Originally Posted by ProWo View Post
    Will be done.
    Thanks a lot.
    This answer I expected.
