Page 74 of 115
FirstFirst ... 24 64 72 73 74 75 76 84 ... LastLast
Results 2,191 to 2,220 of 3436
  1. Can you use the same green for the notification in the bottom right corner?
    [Attachment 87819 - Click to enlarge]
    ADD:
    Overall, the colored buttons are certainly helpful.
    Add 2:
    The color of the individual buttons remains on all pages until the last task has been completed. Great.
  2. Originally Posted by Findu View Post
    No, because the notification green is the same as the action buttons color.
    But i could change the new button color.
  3. I understand. What's more important is that you can read it well.
    Two more things for Batch scan for errors:
    Shouldn't "Hardware acceleration" be called "Hardware decoding" because "-f null -" check for decoding errors.
    Since software decoding isn't a performance difficulty for a long time, you can better assess whether it's still an advantage for you, like at the "Video decoding" page.
    When you exit Join, you ask now whether any remaining files should be deleted, like in Multiplex. Why not do the same for batch tasks?
  4. Originally Posted by Findu View Post
    Will rename it to HWA decoding.
    Because batch tasks are tasks and not already created files.
    BTW
    Changed the new button color to purple.
    Will upload it tomorrow.
    EDIT:
    Uploaded.
  5. @ProWo
    Quick question: Does clever support opus Freq other than 48k? currently the drop down has only one value [48k].
  6. @ ProWo
    Great adding the purple "Streams" button.
    The button preselection has also disappeared on the "Select source page" and the "Main page". Thank you.
    The text "HWA decoding" could also be used at the "Video encoding" page. Then it is uniform.
  7. Originally Posted by videoAI View Post
    Thx for the hint. Bug.
    opus supports 8khz, 12khz, 16khz, 24khz and 48khz.
    Will be fixed soon.
    EDIT:
    Done
  8. Originally Posted by Findu View Post
    Will be done.
  9. Confirmed.
    opus issue is fixed. Tested OK.
    Thank you .. and keep up the fantastic effort.
    Will be fixed soon.
    EDIT:
    Done
  10. Testing the audio encoding:
    Sample rate values that FFmpeg supports for Opus audio: ok
    8000 Hz
    12000 Hz
    16000 Hz
    24000 Hz
    48000 Hz
    Sample rate values that FFmpeg supports for PCM audio:
    8000 Hz
    11025 Hz
    12000 Hz
    16000 Hz
    22050 Hz
    24000 Hz
    32000 Hz
    44100 Hz
    48000 Hz
    88200 Hz
    96000 Hz
    176400 Hz
    192000 Hz
    352800 Hz -- missing
    384000 Hz -- missing
    Sample rate values for true HD audio:
    88.2 kHz
    96 kHz
    176.4 kHz
    192 kHz
    352.8 kHz -- missing
    384 kHz -- missing
    Sample rate values that FFmpeg supports for Vorbis audio:
    8000 Hz -- missing
    11025 Hz -- missing
    12000 Hz -- missing
    16000 Hz -- missing
    22050 Hz -- missing
    24000 Hz
    32000 Hz
    44100 Hz
    48000 Hz
    88200 Hz -- missing
    96000 Hz -- missing
    176400 Hz -- missing
    192000 Hz -- missing
    Sample rate values that FFmpeg supports for MP3 audio:
    8000 Hz -- missing
    11025 Hz -- missing
    12000 Hz -- missing
    16000 Hz -- missing
    22050 Hz -- missing
    24000 Hz -- missing
    32000 Hz
    44100 Hz
    48000 Hz
    Sample rate values that FFmpeg supports for MP2 audio:
    8000 Hz -- missing
    11025 Hz -- missing
    12000 Hz -- missing
    16000 Hz
    22050 Hz
    24000 Hz
    32000 Hz
    44100 Hz
    48000 Hz
    Sample rate values that FFmpeg supports for FLAC audio:
    8000 Hz
    11025 Hz -- missing
    12000 Hz -- missing
    16000 Hz
    22050 Hz -- missing
    24000 Hz -- missing
    32000 Hz
    44100 Hz
    48000 Hz
    88200 Hz -- missing
    96000 Hz
    176400 Hz
    192000 Hz
    Sample rate values that FFmpeg supports for E-AC-3 audio:
    48000 Hz
    44100 Hz
    32000 Hz
    24000 Hz -- missing
    22050 Hz -- missing
    16000 Hz -- missing
    12000 Hz -- missing
    11025 Hz -- missing
    8000 Hz -- missing
    Sample rate values that FFmpeg supports for DTS audio:
    8000 Hz
    16000 Hz
    32000 Hz
    44100 Hz
    48000 Hz
    88200 Hz -- missing
    96000 Hz -- missing
    Sample rate values that FFmpeg supports for AC-3 audio: ok
    32000 Hz
    44100 Hz
    48000 Hz
    Sample rate values that FFmpeg supports for AAC audio using the aac_mf codec:
    8000 Hz -- missing
    11025 Hz
    12000 Hz -- missing
    16000 Hz
    22050 Hz
    24000 Hz
    32000 Hz
    44100 Hz
    48000 Hz
    88200 Hz -- missing
    96000 Hz
    Sample rates supported by AAC in FFmpeg are as follows:
    8000 Hz
    11025 Hz
    12000 Hz
    16000 Hz
    22050 Hz
    24000 Hz
    32000 Hz
    44100 Hz
    48000 Hz
    88200 Hz
    96000 Hz
  11. Originally Posted by videoAI View Post
    Will be added.
    384 kHz -- missing
    Not supported by ffmpeg.
    16000 Hz -- missing
    22050 Hz -- missing
    Will be added
    88200 Hz -- missing
    96000 Hz -- missing
    8000 Hz -- missing
    11025 Hz -- missing
    12000 Hz -- missing
    16000 Hz -- missing
    22050 Hz -- missing
    24000 Hz -- missing
    Will be added.
    8000 Hz -- missing
    11025 Hz -- missing
    12000 Hz -- missing
    16000 Hz -- missing
    22050 Hz -- missing
    24000 Hz -- missing
    11025 Hz -- missing
    12000 Hz -- missing
    22050 Hz -- missing
    24000 Hz -- missing
    88200 Hz -- missing
    Will be added.
    24000 Hz -- missing
    22050 Hz -- missing
    16000 Hz -- missing
    12000 Hz -- missing
    11025 Hz -- missing
    8000 Hz -- missing
    88200 Hz -- missing
    96000 Hz -- missing
    8000 Hz -- missing
    12000 Hz -- missing
    88200 Hz -- missing
  12. @ProWo
    Issue: The only resizable column that I came across is Title; but the resize works backwards [!!?].
    I think the resize functionality is very usefull, especially for Title & File Name.
    Please add resize to both columns, and kindly standardize across all related grids.
    [Attachment 87822 - Click to enlarge]
    Error message...
    This operation cannot be performed while an auto-filled column is being resized. ???
    There is no code in my app to resize a column ... []
    Did you do this manually?
  13. AAC (Advanced Audio Coding) and AAC-MF (AAC Main Profile) are both audio coding formats, but they have some key differences in terms of their design, use cases, and performance. Here's a comparison:
    Overview:
    - AAC is a standardized, lossy compression audio coding format designed to be the successor of the MP3 format.
    - It is part of the MPEG-2 and MPEG-4 specifications.
    Features:
    - Efficiency: AAC generally provides better sound quality than MP3 at the same bit rate.
    - Bit Rates: Typically ranges from 32 kbps to 320 kbps.
    - Profiles: AAC has several profiles, including Low Complexity (LC), High Efficiency (HE), and Main Profile (MF), among others.
    - Use Cases: Widely used in digital radio, streaming services, and mobile devices.
    Advantages:
    - Better compression efficiency compared to MP3.
    - Supports a wide range of bit rates and sampling frequencies.
    - Widely supported across various devices and platforms.
    Disadvantages:
    - May require more computational power for decoding compared to simpler formats like MP3.
    Overview:
    - AAC-MF is a specific profile within the AAC family, designed for applications that require high-quality audio and are not constrained by computational power.
    Features:
    - Quality: Offers high-quality audio with a focus on maintaining the fidelity of the original sound.
    - Complexity: More computationally intensive than other AAC profiles like LC.
    - Bit Rates: Typically used at higher bit rates to achieve the best quality.
    - Use Cases: Suitable for applications where audio quality is paramount, such as high-fidelity music streaming and professional audio production.
    Advantages:
    - Provides the highest quality audio within the AAC family.
    - Suitable for applications where computational resources are not a constraint.
    Disadvantages:
    - Higher computational requirements for decoding.
    - May not be as widely supported as the LC profile in some devices and platforms.
    Summary
    - AAC is a versatile and widely supported audio coding format that offers good compression efficiency and sound quality.
    - AAC-MF is a specific profile within AAC that focuses on high-quality audio at the cost of higher computational requirements.
    Choosing between AAC and AAC-MF depends on the specific needs of your application, including the required audio quality, available computational resources, and the target devices or platforms.
  14. Originally Posted by videoAI View Post
    In the grids there should be no resize option for the columns at all. I will fix this.
  15. Please don't take the resize away .. I wanted it fixed .. not removed.
    BTW, is there a reason why you're not using a dynamic grid [with sortable, resizable columns built in] like DataGridView.
    it might help us frame our expectations / requests, if you tell us a bit about the programming language you are using.
    I'm guessing it is 'winforms' ?
    In the grids there should be no resize option for the columns at all [what!! nooo]. I will fix this.
  16. Originally Posted by videoAI View Post
    Programming is not a problem, I don't want people playing around with the grids because it doesn't bring any advantage.
    The information is all there and visible, that should be enough.
  17. Competition is heating up ..
    A simple crop video feature with preview .. very interesting ..
    [Attachment 87824 - Click to enlarge]
    Screen shot from Videomass.
  18. @ProWo
    Issue: using MS Soft Keyboard, in Preview, Pressing Space doesn't Pause/Resume, while pressing P works fine. [!!?]
    Also the preview audio is very loud. please decrease the audio to ~ 70% of original. [this is a simple ffplay cmd]
    And a tiny request ..
    I am visually challenged, I can't use my laptop screen or keyboard, instead I use a large monitor, a mouse, and MS on-screen
    soft keyboard. The issue is, the soft keyboard can't be minimized, and it is always on top. using clever preview with keyboard
    keys is a challenge for me.
    [Attachment 87825 - Click to enlarge]
    I wish you would consider allowing me, and other users, to use the mouse buttons & wheel .. for example as follows:
    Left click -> Pause/Resume
    Right click -> Jump between I-frames [already implemented]
    Mouse wheel -> single frame step
    Thank you .. from all the senior citizens, elderly, and the disabled/disadvantaged out there ..
  19. Originally Posted by videoAI View Post
    Right click -> Jump between frames
    There are many problems with this request.
    1. Mouse right click is already used (to determine the position in FFplay)
    2. To reassign the left click and the mouse wheel, the normal mouse status must be changed. This requires a trigger. This could be the start of ffplay.
    3. But this is where the biggest problem arises. How to leave the changed status? The mouse cannot be used for this.
    As you can see, the matter is complicated and would cause problems, especially for other users.
  20. Please see my response ..
    [right click stays as is - no change here]
    [no need to use Left click also .. see #3]
    [you can use the wheel middle click instead for #2 (pressing the wheel down achieves this).
    Translated with DeepL.com [welcome to the AI age .. ]
    so .. it becomes like this ..
    Right click -> no change
    Left click -> no change
    Middle Mouse click / Wheel Click -> Pause/Resume
    note: The middle mouse click and the mouse wheel click are two distinct actions that can be performed with a mouse, and they serve different purposes depending on the context and the software being used.
  21. @ ProWo
    Thanks for the recent changes. They're working as intended.
    If you remember, the title column width was made adjustable because the text was sometimes too long, and you could also enter your own text here.
    Is there a way to automatically adjust the column width beyond its minimum after entering text?
    [Attachment 87826 - Click to enlarge]
    ADD:
    And could you please change the Chapters warning text so that the > symbol is removed? That would be easier for everyone to understand.
    [Attachment 87827 - Click to enlarge]
  22. Originally Posted by Findu View Post
    Fixed to fit content.
    The symbol means greater than, so it has its justification. I have replaced it with text.
  23. Originally Posted by videoAI View Post
    No way to achieve that.
    The mouse wheel handle only works if the window with this handle is active; however, the active window in the preview is the FFplay window, and no code can be implemented in this.
  24. @ProWo
    How about the 2 pending issues.
    Issue #1 using MS Soft Keyboard, in Preview, Pressing Space doesn't Pause/Resume, while pressing P works fine. [!!?]
    and
    Issue #2 The preview audio is very loud. please decrease the audio to ~ 70% of original. [this is a simple ffplay cmd]
    Dropping the request ..
  25. Originally Posted by videoAI View Post
    Tested with MS Virtual Keyboard on Windows 11 (Windows key + Ctrl + O):
    Space bar and P both work as expected. So there is no issue.
    FFplay's default volume is 100%.
    If this is too loud for you, reduce the system volume in Systray.
  26. @ ProWo
    Thank you for responding ..
    #1 Tested with MS Virtual Keyboard on Windows 11 (Windows key + Ctrl + O):
    I am still having this issue here, I will consider it "unresolved". No need for further action on your part. Thanks.
    #2 FFplay's default volume is 100%.
    Thanks for the advice, I would never have thought of it myself.
    As always keep up the good work ..
  27. @ ProWo
    The "fit content width" for the Multiplex Title column is working well.
    And thanks for changing the chaptes warning text.
    Join videos with different resolution and fps:
    You have already implemented codecs and streams indexes check for joining, but when I join two files
    1) 1356x 680, 23.976 (24000/1001) FPS, 28 min 19 s
    2) 1280 x 720, 25.000 FPS, 39 min 5 s
    The joined video (1+2) has
    Duration : 1 h 7 min (fits)
    Frame rate : 46.068 FPS
    Offset : 0,023000
    VLC plays 1 and show a black screen till 1:07, then playing 2.
    When I join 2 and 1, the joined video (2+1) has
    Duration : 2 h 6 min
    Frame rate : 13.104 FPS
    Offset : 0,022969
    VLC play 1 in connection 2 and then show a black screen till 2:06.
    For two other videos with different resolution and fps, the second video (1+2) is not displayed at all or the second (2+1) is played in slow motion.
    Other players also have problems.
    Maybe you could add columns for Resolution, Frame Rate, Sample Rate and Channels in the grid, although that is not necessary for a successful merging. This makes it easier to see whether there are differences in the parts.
  28. Originally Posted by Findu View Post
    Offset : 0,023000
    Offset : 0,022969
    Which containers did you join?
    Do the individual parts have different bit depths?
    I have tested mkv, right now:
    1) 1920 x 800, 23.976 fps, DAR 2.40, YUV 4:2:0, 8 bits
    2) 1280 x 534, 23.976 fps, DAR 2.40, YUV 4:2:0, 8 bits
    3) 1280 x 534, 25.000 fps, DAR 2.40, YUV 4:2:0, 8 bits
    4) 720 x 300, 23.976 fps, DAR 2.40, YUV 4:2:0, 8 bits
    5) 1356 x 680, 23.976 fps, DAR 1.99, YUV 4:2:0, 8 bits
    Joined in several sequences.
    Played with VLC, Windows Legacy Media Player, no problems, works as expected.
  29. I joined mp4 containers.
    All have 8 bits depth.
    ADD:
    Good hint. Muxing the mp4 parts into mkv before merging works well.
    ADD 2:
    Using fix framerate, simple remux or normal mux of the mp4 parts into mp4 containers before joining doesn't help either.
  30. @ProWo
    When you run Clever, main page has 3 buttons [open, Join, Multiplex]. if you attempted to load a damaged file,
    you get an error [This file cannot be analyzed], and 2 buttons disappear [Join, Multiplex]. when you press Ok,
    [Join] re-appears but not [Multiplex].
    [Attachment 87859 - Click to enlarge]
