Results 181 to 210 of 3437
Download the newest beta and retry.
Post a full list of all vob files of your DVD here -
Same Error with Beta.
The list is as follows:
Code:23.02.2021 19:42 <DIR> . 23.02.2021 19:42 <DIR> .. 20.10.2020 00:23 14*336 VIDEO_TS.BUP 20.10.2020 00:23 14*336 VIDEO_TS.IFO 20.10.2020 01:44 32*303*104 VIDEO_TS.VOB 20.10.2020 00:23 51*200 VTS_01_0.BUP 20.10.2020 00:23 51*200 VTS_01_0.IFO 20.10.2020 01:47 64*624*640 VTS_01_0.VOB 20.10.2020 01:48 1*073*565*696 VTS_01_1.VOB 20.10.2020 01:47 1*073*565*696 VTS_01_2.VOB 20.10.2020 01:48 1*073*565*696 VTS_01_3.VOB 20.10.2020 01:48 750*305*280 VTS_01_4.VOB
Another try. Restart your computer and retry the rip with vts_01_1.vob.
By the way, whats your OS? Windows 10? -
That gives a popup error saying "unservicable exception", Conversion of "0,235044" to "doucle" type is not proper. OR something like that, the popup is in my language, clicking on continue and the app starts analyzing video indefinitely.
Trying different DVD folder gives the same result, empty ripped file. -
@ProWo
I converted EAC3 audio to a DTS 5.1 audio file, remuxed it with MKVToolnix and playing it via VLC confirmed it was a DTS audio file 5.1 / playback on my computer (in stereo) was fine but when playing the same MKV file on my Home Theatre system caused issues with DTS audio on my T+A DD 1530 r surround decoder. I got clicking noises and the decoder switching back and forth between Dolby Prologic II and DTS. Conversion from EAC3 to AC3 worked fine so what am I doing wrong?? Attached screenshots of the way I set-up clever FFmpeg-GUI to convert EAC3 to DTS and AC3 as well as how the DTS codec played /is shown in VLC.
[Attachment 57729 - Click to enlarge]
[Attachment 57730 - Click to enlarge]
[Attachment 57731 - Click to enlarge]
btw: clever FFmeg-GUI works like a charm and is what I was looking for for some time. So thanks very much for helping us "programming illiterates". Much appreciated that at least someone is helping us out on this one.
Darkhose. -
You did nothing wrong, the settings are ok. The command line in clever FFmpeg-GUI is ok too.
I researched. There are reports of errors when playing DTS encoded by ffmpeg in DTS hardware
(see here https://forum.doom9.org/showthread.php?p=1754796#post1754796).
But it may be that the errors have been corrected in newer static builds of FFmpeg. Try again with the latest ffmpeg version.
I don't have DTS hardware, so I can't test it myself.Last edited by ProWo; 11th Mar 2021 at 09:46.
March 15, 2021 update to version 2.7.4.
Fixed: Small bugs.
Rewritten: entire DVD Rip module (unprotected DVD's only).
Improved: Duration detection, Multiplex logic, Audio codec and channel logic, many fine tunings. -
Hi ProWo, just to let you know that m4a container is disapeared from audio container pull-down.
Thanks. -
Buongiorno Prowo.
Innanzitutto grazie.
Ho notato che nella nuova versione hai tolto l'opzione "resize without cropped" ma hai lasciato solo "resized".
Se uso quella è la stessa cosa per il VOB Pal 720 x 576 passando dal rappoto di aspetto 21:9 a 16:9 ?
Non voglio tagliare l'immagine e perdere dei dettagli, ma solo allungarla.
Seconda cosa nella casella ritardo audio prima c'era il valore 42, ora è vuota.
Con media info se mi da, nel file da convertire, un ritardo audio, devo metterlo in quella casella?
E se invece l'audio è in anticipo devo mettere davanti il segno - (meno)?
Scusa per le domande che per te saranno ovvie, ma è per capire meglio.
Buon lavoro. -
You may need this feature if you want to run your aac audio with the m4a extension through extremely useful aacGain to check for clipping or add a few db to normalize using replaygain. aacGain does not accept anything other than raw mp4 or mp4a. Changing an already encoded aac file to extension mp4a manually is also rejected in aacGain.
You're welcome. I found many audio tracks get clipped in a left or right channel(or both) after normalization and aacGain saves the day or worse still is left 'quiet' after ac-3 input as there is a drop in levels and needs a bit of gain to level it up. It also can check 5.1 tracks with mp4a extension. Been using it for years on aac and mp3! Wish there was something similar(GUI)like aacGain for ogg/vorbis. Thanks.
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 09:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 02:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 11:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 07:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 00:19
