Results 1,921 to 1,950 of 3347
Adding metadata tags works exactly as described.
With Batch 0 replication, other files will also receive these tags.
Thank you for your help. -
I have checked this.
This is currently deactivated because all other 8 to 6 downmix formulas are not compatible with your downmix. I can activate the cleverNorm filter, but when it is activated, I have to deactivate all other formulas.
BTW
As far as I remember, your special downmix formula for 8 to 6 with dynaudnorm and compand should only change the FC channel, the other channels, except for ch4+ch5, should be taken over unchanged.
I took a closer look at your formula and it not only changes the FC channel, but also the other channels.
Is that intentional? -
@ ProWo
3.4.1.02 Feedback 3
Just to let you kow: The grid error message only appear if I click on the columns header Set and Default at the multiplex grid, nowhere else.
When I set the default stream at the Default column, the Title column get named Forced.
And a given title will be overwritten with Forced when you set it.
I would expect that to happen when I add the hook to the column Forced, but that did not happen.
[Attachment 87181 - Click to enlarge]
EDIT: Perhaps it is better to add “Default” or “Forced” to an existing title.Last edited by Findu; 29th May 2025 at 07:32.
Questions:
If I want to multiplex multiple files, can I drop a single file into the empty multiplex grid and click "Multiplex" and then repeat that process for each file?
Or is it still better to load each file as a source, because then more advanced checks are performed upon loading?
Is it correct that Simple Remux is only available when the grid contains only source streams? -
No, with normal mux, no.
This way you can choose simple remux and to batch. Then you can load other videos into the batch grid to replicate the simple remux.Or is it still better to load each file as a source, because then more advanced checks are performed upon loading?
ATM yes. The problem is, that simple remux cannot work with with different sources.Is it correct that Simple Remux is only available when the grid contains only source streams? -
Sorry! So what is the use of the Multiplex button on the "Select source file" page?
I often need to add subtitles to many videos. This is how I do it:
1. Right-click a video and open with Clever FFmpeg-GUI.
2. Click the main page; click the Multiplex page; then make it stay on top with another program.
3. Drag and drop the 2 subtitles I want to add; make one the default; type in the abbreviations for the language names (I wish the program can do this automatically like Mkvtoolnix); then click Multiplex
4. To do the next file: I go to the main page; go to multiplex page; make it stay on top again. The last video remains on the page.
5. This time I drag and drop a new file and 2 subtitle files together.
6. Choose the default language and type in the language names; now I need to uncheck the previous video before proceeding.
Now the page is set where it is and I can keep on going. It sounds like a lot of work but it's not.
Still is there a faster way to add subtitles to multiple files in a batch? Thanks. -
@ ProWo
when I convert the bit rate of an AAC audio stream from constant bit rate of 116k to 96k, I end up with a variable bit rate of 86.8k !!
if I load the converted file back into Clever, it shows as 86.8k.
Media info shows:
Bit rate mode : Variable
Bit rate : 86.8 kb/s
Maximum bit rate : 96.0 kb/s
Any reason why the avg bit rate isn't 96k?
and why it is turned into variable bit rate when the source was constant? -
In a batch, no.
But there is another way to speed this up.
First of all, the subtitles must have the same name as the videos.
Start clever FFmpeg-GUI.
Click on Multiplex.
Move e.g. 10 videos into the grid and then all subtitles of these videos.
Then click on None (top left) to deselect all streams.
Then click on the Filename column header; this will sort all streams by name.
Now select all streams with the same name on the left and click on Multiplex.
Keep going with the other videos (one each time).
The Multiplex page remains open until either all streams are muxed or you click on Main page. -
I just found out that I have been making some unnecessary steps. I only have to make it stay on top once. Up to step #3 is all I need to do. After multiplexing the page in now blank. I can drag and drop the video and subtitles at once and continue. Now only if the program can automatically name the languages.
Thanks for making this program.
@ProWo
Thanks for acknowledging 4 of my bugs, and fixing 2 of them so far.
Bug#5
(out of 1000 .. just kidding
I wish my default output folder to always be my my input folder, like the hundreds of software apps I use, allow me to do so easily.
The current implementation of the default output folder in Clever is awkward and not consistent.
when I open the App I want my default folder to always be my input. currently I have to always remember to change it on the
first screen. and this preference is not saved in the config file and is not retained the next time I open the app.
Second, I noticed that the selected default [source] is not used in numerous outputs during the same session. [bug?]
ex: The "scan file for errors" still outputs to the folder stored in the config file {which is not the selected source Folder}.
that goes for a lot of other actions as well, too many to list here.
The issue here is: you are not storing the input folder default selection in the config file, and not retaining the selection properly,
even within a single session, or permanently across sessions.
This is just not working !!! Please fix it.
As always, the problem is not my environment, it is the 'Clever' App ..
Many thanks for your time & effort .. -
June 03, 2025 release version 3.4.2.
Added:
Join possibility for audio files.
Option to add cuts to join list.
Multiplex button on start screen.
Change colorspace without reencoding (for h264 and hevc streams).
cleverNorm filter (with 8 to 6ch).
Compress parameter for dynaudnorm filter.
Automatic language recognition from subtitle/audio filename in mux grid.
- The language code must be embedded in brackets, g.e {eng}; admitted brackets are {[( -
Automatic language code (if present) insertion in filename with stream extraction, audio and subtitle conversion.
Fixed:
Bug with missing cut/to batch button for audio files only, in cut section.
Bug with error scan option, not working.
Bug with videostream extraction mantaining video offset (wrong behaviour).
Bug with aborting tasks (not closing ffmpeg.exe).
Bug with source audio stream frequency, not showed.
Bug with non return to start screen from mux grid, if there is no inputfile.
Bugs with audio downmix formula (for 8 to 6ch).
Bug with error if clicking on columns header in multiplex grid. (thx to VideoAI for the hint).
Bug with audio downmix channels.
Changed:
Pixelformat "auto" to "Like source".
Cosmetics on Audio- & Video encoding page.
Stream/select stream to stream index
NumericUpDown instead Textbox for closed caption index selection.
Unused processed files and batches, answer yes to mantain them, no to delete them.
Hide progressbar for Step2 + 3 (change framerate).
Simple remux option available only with streams from the same sourcefile.
Improved:
Crop use help screen.
Cosmetics with DVD rip.
Finetunig on audio downmix formulas.
----------------------------------------------------------------------------------Last edited by ProWo; 3rd Jun 2025 at 12:04.
This is your personal opinion and it's ok.
That is the intention...when I open the App I want my default folder to always be my input. currently I have to always remember to change it on the
The "Scan for errors" creates a temporary file that displays the errors at the end of the scan.Second, I noticed that the selected default [source] is not used in numerous outputs during the same session. [bug?]
This type of file always goes to the target folder.
clever FFmpeg-GUI gives you the possibility to output all outputs (except the temporary ones) to the source folder of the imported file.The issue here is: you are not storing the input folder default selection in the config file, and not retaining the selection properly,
This setting remains active until you read in a new file, but you can reactivate it afterwards.
For normal use, all outputs go to the target folder.
This is coherent; in addition, all files are then in one place and not distributed over the entire computer.
BTW:
Just as a mental game:
You have different streams from different sources in the muxgrid.
If you now want to mux, for example, the video stream of a file (located in C:\example) and the audio stream of a file (located in D:\new_source), where should the output go?Last edited by ProWo; 3rd Jun 2025 at 14:10.
Thank you so much for the latest update. Most of my wishes have been answered such as:
1. Multiplex on the main page; save me a step.
2. Automatic language name recognition.
If I can ask for a few more:
1. When muxing text subtitles to MKV, please use -c
srt instead of -c
copy
2. How about a stay on top feature?
Thanks. -
Language name for subtitle not shown with the latest update. The code for the language name are there: en;es
How Ukraine's devastating surprise attack on Russia is a game changer for global military strategy [DMa71RVpJcA].en.vtt
How Ukraine's devastating surprise attack on Russia is a game changer for global military strategy [DMa71RVpJcA].es.vtt
[Attachment 87288 - Click to enlarge]
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 10:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 03:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 12:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 08:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 01:19
