Page 64 of 112
FirstFirst ... 14 54 62 63 64 65 66 74 ... LastLast
Results 1,891 to 1,920 of 3347
  1. Originally Posted by videoAI View Post
    I gave up and deleted the file for good, but not before testing it using your latest version [3.4.1.01].
    I can confirm that the app is now able to scan the damaged mp4 file successfully [without hanging or freezing] and can produce an
    error file .. attached .. if you wish to take a look at the errors.
    I have looked at this, most of the errors are from aac decoder, but unfortunately many are also from h264 decoder.
    The video will probably not be repairable.
  2. @ ProWo
    Would it be helpful to make the four fields selectable so that the relevant streams will be marked in the grid?
    [Attachment 86933 - Click to enlarge]
    The upper check mark would only/also appear if, for example, all added streams were selected manually.
  3. so .. I finally tried the crop feature .. again .. no not the meta data crop under various [btw, the feature was my idea],
    but the actual crop feature hidden very .. very well under the video encoding screen.
    Did I crop an mp4 file successfully? yes
    Was it easy? Nooooooo
    it took me 15 mins to find the dam feature and another half an hour to crop a video clip, by trial and error.
    so many un-necessary steps, {or features ?!! }, and numbers [some I understood, but many I had no clue what the heck they do].
    so many !!!
    There got to be a better way of cropping videos.
    Nowadays, anybody can crop a video on their mobile phone in mere seconds and few clicks.
    So .. why is it so cumbersome and difficult to do it on a laptop?? especially in 2025, and with
    all the AI agents out there claiming to write flawless code?
    I have no answer .. but guys you have to up your game .. or very soon, AI will take over your jobs. Don't say I didn't warn you.
    I did however find an old gem, Mobile Media Converter
    although outdated, [and not updated any longer], this small program allowed me to crop my video clip in mere seconds.
    - right click on your loaded file, select crop
    - move the 4 sliders by mouse [or keyboard arrow keys] as shown below
    - click ok .. that's it .. seriously that's it.
    @ProWo
    1st I tried crop .. bad idea ..
  4. @ProWo
    could you please add a cancel button [or simply an X in the form upper right corner] to all your forms.
    most of your forms do not allow the user to cancel out of them.
    ex: preview, rotate, properties, etc under the video encoding screen.
    and thanks for fixing two of my bugs .. so far
    1- App version status
    2- Scan for errors
  5. Originally Posted by Findu View Post
    I don't think that would bring any real improvement.
  6. Originally Posted by videoAI View Post
    The auxiliary forms without X are there to provide additional information or to query parameters.
    In both cases, it makes no sense to simply close these forms. This is why the X is missing.
  7. Originally Posted by videoAI View Post
    so many !!!
    In most cases, using the crop function is very simple and automatic.
    Click on crop until the values on the left remain the same 2-3 times.
    Check with the preview.
    Background:
    Each time you click on crop, ffmpeg's cropdetect is executed on a different frame. This ensures that a correct value is determined.
  8. I am impressed with the muxing speed of Clever FFmpeg-GUI. Your software is sometimes 3x faster than me using ffmpeg when muxing a subtitle file to a 1080p video. I am wondering why it's much slower when I use ffmpeg. This is the command I use:
    ffmpeg -i "input.mkv" -i "sub.srt" -map 0 -map 1 -c copy -c srt -metadata:0 language=eng -disposition:0 default "output.mkv"
  9. @ProWo
    During usage, users may check out a feature to determine how it's implemented, to use it successfully at a later time.
    The current design does not allow for backing out or cancelling out of the underlying action (ex: preview).
    and your statement:
    "These 'auxiliary' forms without X are there to provide additional information or to query parameters", is not accurate as
    these forms forces you into one option which is: Trigger the action right away; even if you didn't want to or needed to.
  10. you can't be serious ..
    Users on this board, please look at both images and tell which is more user friendly ..
    #1
    [Attachment 86943 - Click to enlarge]
    or
    #2
    [Attachment 86944 - Click to enlarge]
    so many !!!
    Background:
  11. @davidt1
    This is a way to look at the FFMPEG code generated by the GUI.
    but it may not work for mux-ing ..
    you could also try posting here:
    How-to-batch-convert-multiplex-any-files-with-ffmpeg
    You can see the generated command line by clicking "To batch" instead of encode.
    Then quit clever FFmpeg-GUI.
    In your target folder you'll find a new file named BT_open.txt.
    Open it with any text editor and you will see the command line and other info regarding the batch operation.
  12. Originally Posted by davidt1 View Post
    ffmpeg -i "input.mkv" -i "sub.srt" -map 0 -map 1 -c copy -c:s srt -metadata:s:s:0 language=eng -disposition:s:0 default "output.mkv"
    -c:s srt
    recodes your srt input to srt; this isn't nedded with mkv as output, because mkv can handle srt, so pure streamcopy is enough.
    If you want mp4 as output, then the srt recode is needed in this way:
    -c:s mov_text
  13. Originally Posted by videoAI View Post
    I have already explained everything to you.
    BTW:
    FFmpeg's cropdetect is more accurate than the manual method you showed.
  14. @ProWo
    Thanks for responding ..
    what you have implemented is called "Auto Crop" .. yet you named the button "Crop", but in hover and in page name you
    called it by functionality "Crop Detection".
    This is crop detection [or Auto Crop]:
    FFmpeg's cropdetect filter automatically identifies the optimal cropping area of a video by analyzing the non-black regions.
    ffmpeg -i input.mp4 -vf cropdetect=24:16:0 output.mp4
    to generate a new video with the recommended [but not user defined] crop settings.
    what I was looking for is a simple Crop function .. something like this:
    ffmpeg -i input.mp4 -vf "crop=w:h:y" output.mp4
    vf indicates the usage of a video filter.
    crop is the name of the filter.
    w:h is the width and height of the output video.
    x:y is the coordinate where the video will be cropped.
    I hope this helps clarify where the confusion came from.
    BTW:
  15. @ProWo
    A gentle reminder, that this issue is still pending ..
    @ ProWo
    I noticed that the "Post a review" link on the main page opens my default browser in light mode (which burns my eyes).
    This is odd because my browser default mode is dark (Dark setting in chrome, no extension or addon).
    If I copy the link (https://www.videohelp.com/softwareaddcomment?id=1799) that opened up in a new instance of the browser (light mode) and paste it manually in a new tab in my already opened default browser (dark mode) .. it shows in dark mode .. white text on black background. which is exactly what I want to happen.
    is it possible to default the link to open in a tab of the default browser (if it is already running) instead of a new browser instance?
    Thx
  16. Originally Posted by videoAI View Post
    No, it's just a web link.
  17. @ ProWo
    Just a few little things:
    Perhaps you could standardize the description in these three places and call everything "Various"?
    [Attachment 87012 - Click to enlarge]
    [Attachment 87013 - Click to enlarge]
    And the title units are in brackets everywhere else:
    [Attachment 87014 - Click to enlarge]
    I haven't noticed anything else so far!
  18. Originally Posted by Findu View Post
    Good idea, will be done.
    Thx for testing
  19. @ ProWo
    I forgot that:
    If a source has multiple video streams and you extract them, you'll be asked whether to extract them as a container or raw file. It is rare, but can the number of the respective stream be displayed in the "Video extraction" window?
    And the unprocessed raw streams don't appear in the list when you exit or start the program. Therefore they are not deleted. Is that intentional?
  20. Originally Posted by Findu View Post
    The stream index is alreday present. The column name is Stream (atm).
    I'll rename it to Idx, to match the other grids.
    Yes, because the raw video streams, as they are, cannot be edited any further.
    They must be added as a new source, the frame rate is queried and a new mp4 video is automatically generated.
    This can then be processed further.
    For this reason, I am leaving the current situation as it is.
  21. Newest beta (v3.4.1.02), online now.
    (Changelog will follow in the next full release).
  22. @ ProWo
    3.4.1.02 Feedback
    The bug showing the source frequency of each audio stream has been fixed.
    And thanks for the minor text changes on the audio/video encoding and stream extraction pages.
    I'm still playing around with your new color space change feature.
  23. @ ProWo
    3.4.1.02 Feedback 2
    No problems found so far with your new color space change feature.
    When I use MediaInfo with my old recordings from different cameras, the sections General, Video and Audio contain
    Encoded date
    Tagged date
    These tags disappear when you write with the app.
    Might be custom metadata informations.
    Wouldn't it make sense to preserve such original information?
  24. cleverNorm filter is greyed out for the 7.1 source (for the eac3 encode option) in the latest version for me.
  25. Originally Posted by mannequin80 View Post
    Tested, doesn't happen here (with 3.4.1 and newer). Could you explain better?
  26. Originally Posted by Findu View Post
    Encoded date
    Tagged date
    This is a problem. I could add -map_metadata 0, but then there are a lot of duplicate tags, e.g. after a conversion from HDR to SDR you will find an original tag (representing the current situation) and a normal tag that was copied in the colorspace information. In other words, ambiguous information.
    For this reason I leave it as it is now.
    If you need this tags for your videos, I can show you a way to get it.
  27. Yes, I understand.
    Please show me how to get the tags.
  28. Originally Posted by Findu View Post
    Yes, I understand.
    Start clever FFmpeg-GUI.
    Load your mp4/mkv (without the tags), click main page, click multiplex, check simple remux, click to batch.
    Close the app and mantain the batch.
    Edit BT-open.txt and insert
    -metadata creation_time="2025-05-27T11:27:04Z"
    (change date and time as you need) before -metadata:g
    Pay attention to have spaces between the single parameters.
    Change the output extention to .mp4 (if not .mp4).
    Save the file and restart clever FFmpeg-GUI.
    Mantain the batch and execute it.
    The output.mp4 should have your tags now.
  29. Originally Posted by ProWo View Post
    [Attachment 87158 - Click to enlarge]
    kinda hard to explain what's happening, as if it doesn't "want" to downmix for cleverNorm.
  30. @ProWo
    FYA ..
    BTW, there is nothing wrong with my environment ..
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
    at System.Collections.ArrayList.get_Item(Int32 index)
    at System.Windows.Forms.DataGridViewRowCollection.Sha redRow(Int32 rowIndex)
    at System.Windows.Forms.DataGridViewRowCollection.get _Item(Int32 index)
    at System.Windows.Forms.DataGridView.get_Item(Int32 columnIndex, Int32 rowIndex)
    at clever_FFmpeg_GUI.Form7.DataGridView1_CellContentC lick(Object sender, DataGridViewCellEventArgs e)
    at System.Windows.Forms.DataGridView.OnCellContentCli ck(DataGridViewCellEventArgs e)
    at System.Windows.Forms.DataGridView.OnCommonCellCont entClick(Int32 columnIndex, Int32 rowIndex, Boolean doubleClick)
    at System.Windows.Forms.DataGridViewCell.OnMouseUpInt ernal(DataGridViewCellMouseEventArgs e)
    at System.Windows.Forms.DataGridView.OnCellMouseUp(Da taGridViewCellMouseEventArgs e)
    at System.Windows.Forms.DataGridView.OnMouseUp(MouseE ventArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9300.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    clever FFmpeg GUI
    Assembly Version: 1.0.0.0
    Win32 Version: 3.4.1.02
    CodeBase: file:///C:/Portable/PortableApps/CleverFFmpegGUI/clever%20FFmpeg%20GUI.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.9032.0 built by: NET481REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.9282.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.8.9297.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.9256.0 built by: NET481REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.9032.0 built by: NET481REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    Win32 Version: 4.8.9214.0 built by: NET481REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    PortableSettingsProvider
    Assembly Version: 0.2.5.0
    Win32 Version: 0.2.5.0
    CodeBase: file:///C:/Portable/PortableApps/CleverFFmpegGUI/PortableSettingsProvider.DLL
    System.Xml.Linq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    System.Web.Extensions
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
    System.Web
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
