Page 58 of 99
FirstFirst ... 8 48 56 57 58 59 60 68 ... LastLast
Results 1,711 to 1,740 of 2947
  1. Originally Posted by davidt1 View Post
    Srt subtitle extracted from EIA 608/708 still retain Closed Captioning format with the "Fontface monospace" stuff. Normal srt subtitles don't have that. During playback, the subtitle stays in the upper left corner and is not adjustable like a normal srt sub. Can you fix it so it behaves like a true srt subtitle? Thanks.
    The subtitles are correctly extracted.
    If you do not like the formatting, remove it in Subtitle edit.
  2. Originally Posted by Findu View Post
    Files with two video streams:
    The video encoding and cup previews always show stream 1, even if stream 0 is selected.
    When you cut/join such a file, both streams are preserved in the cuts/joins, which makes sense.
    The previews in cut search cut points & preview, chapters video and various crop also show only stream 1.
    What about all the "Various" options like crop when the two streams have different resolutions?
    Metadata crop only works for stream 0.
    Metadata rotate for both.
    Maybe a text on the Various page could inform about the limitations of files with multiple video streams!
    Videos with several video tracks are very rare because they are actually unmanageable, unless it is the same content but from different angles, for example.
    If the content is different, how should the audio and subtitle tracks be handled?
    I will still work on handling these video tracks correctly.
  3. Originally Posted by Findu View Post
    @ ProWo
    NEW ffmpeg version 7.1.1
    Would it make sense to offer an automatic install/update (W10/11 64 bit only) for ffmpeg?
    I won't do that because there are too many different builds and I don't want to favor just one provider.
  4. Originally Posted by Findu View Post
    Just an error message at start of the app when the ffmpeg path does not match the entry in portable.config.
    It's not a big problem because you can still adjust the path in the app.
    To do this, the user must intentionally move the ffmpeg folder. But I will add an additional check.
  5. Hi, I can't mux audio files as mp4 by itself. I could do it in older versions.
  6. @ ProWo
    Understand!
    I don't have such files either!
    For testing purposes, I muxed the second stream in grayscale.
    Some older movies have cutted scenes. These cuts do not have the national dubbing from the past.
    In the DVD menu, you can choose between the short national version and the extended version including the cut parts in original video, original audio, and subtitles.
    The DVD may use chapters to skip that scenes for the short version. However, this only requires one video stream.
    But I had an animated movie in which all the scenes with signs or text were in English, German, and Italian.
    I'm not sure how this DVD was structured. Perhaps separate streams or even chapters for that short scenes.
  7. Originally Posted by neptune84 View Post
    You are right. I'll restore this possibility.
  8. Nice tool but doesn't work with ubuntu wine
    See the end of this message for details on invoking \njust-in-time (JIT) debugging instead of this dialog box.\n\n************** Exception Text **************\nSystem.TypeInitializationException : The type initializer for 'System.Web.Script.Serialization.JavaScriptSeriali zer' threw an exception. ---> System.Configuration.ConfigurationErrorsException: Error Initializing the configuration system. ---> System.Configuration.ConfigurationErrorsException: Unrecognized configuration section <System.Windows.Forms.ApplicationConfigurationSect ion> (Z:\root\Documents\clever FFmpeg GUI.exe.config line 6)
  9. Originally Posted by *star* View Post
    You need Net 4.8 installed.
  10. locotus
    May 2011
    Cypress, Tx.
    Just a question, not a requirement. Is not possible to set CRF or variable bitrate in H265-NVenc enconding?
  11. Originally Posted by locotus View Post
    I intentionally stick with CRF because that is the setting recommended by the FFmpeg developers.
    In addition, CRF does not encode everything with the same bitrate, as is wrongly assumed, but the bitrate is automatically adapted to the content by the encoder itself.
    If you watch the FFmpeg line during encoding, you can see this.
  12. Newest beta (v3.3.9.03), online now.
    (Changelog will follow in the next full release).
  13. Image
    [Attachment 86128 - Click to enlarge]
    Is it possible to select “original channels” in the audio encoding section?
  14. Originally Posted by neptune84 View Post
    Will be done.
  15. Hello Prowo.
    Your program is wonderful and is being enriched with new functions thanks to the suggestions of users that you listen to very kindly.
    For me many functions are unknown as I am a neophyte.
    I kindly ask you if in the future you plan to make a tutorial on all the functions for beginners like me.
  16. Hello,
    I think it would be nice if it had CBR options for the x264 avc encoder. I record my videos in CBR.
    Also, the program uses 100% of the CPU. Would be nice if there was a way to limit CPU usage.
    Other than that, pretty good. I spent a couple hours trying to find a program that could convert I444 to I420 with quite literally zero meaningful results, because DaVinci can't process I444 video. Then I found this at last. Very helpful.
  17. Originally Posted by jopavirando View Post
    Hello Prowo.
    I'm glad you like it.
    The program has a lot of functions, most of which are self-explanatory. I have also included many tooltips to help you.
    Probably the most important thing is that, unlike most others, my program handles the different streams separately.
    For example, you can only change the video stream and leave the audio and subtitles as they are.
    I myself use the program daily to reduce the file size, i.e. I recode the video stream and then mux the remaining streams.
    To come back to your question, creating a complete tutorial with all the functions is honestly too much work for me.
    But if you have any questions, ask them here and I will answer them.
  18. getting this pop up with the latest version when trying to encode an audio:
    [Attachment 86147 - Click to enlarge]
  19. Originally Posted by mannequin80 View Post
    Ooops, this is a remnant from a test.
    I will fix it now and put the next beta online within an hour.
  20. Newest beta (v3.3.9.04), online now.
    (fixed bug with remnant test messagebox in audio encoding, thx to mannequin80 for the hint).
  21. @ ProWo
    3.3.9.04 Feedback
    I can confirm that my issues mentioned above have all been resolved.
    Thank you for so many additions for rarely files with more video streams!
    New findings:
    If you cut a source with more than one video stream, “Use Virtualdub for KF search” is grayed out.
    When rotating 90 degrees, some 1280x720 videos don't maintain their aspect ratio in the preview window. The video will be fully expanded in the 16:9 window, as the preview window does not use portrait itself. Other image/preview sizes and the encoding seem to be fine. The metadata seams to be okay! Here's an example:
    General
    Complete name : C:\Users\Findu\Downloads\P1040330.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2007.09.04 (qt /pana)
    File size : 127 MiB
    Duration : 34 s 500 ms
    Overall bit rate : 31.0 Mb/s
    Frame rate : 30.000 FPS
    Encoded date : 2010-10-18 03:49:46 UTC
    Tagged date : 2010-10-18 03:49:46 UTC
    Writing library : pana
    Video
    Format : JPEG
    Codec ID : jpeg
    Bit rate mode : Variable
    Bit rate : 30.7 Mb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 1.111
    Stream size : 126 MiB (99%)
    Language : English
    When you crop and resize a video, it would be nice to use the new crop DAR for resizing. Could the checkbox for "source DAR is retained" switch to "crop DAR is retained" after you set values for cropping?
    It should switch back when you click Cancel Crops.
    I am not abel to enter values for Various -> Crop any longer.
    Can meatdata crop not be set for each video stream?
    Is "Keyframe cut" the only option?
    I can not cut MPG files any longer: Error
    ************** Ausnahmetext **************
    System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
    bei clever_FFmpeg_GUI.Form8.Indexing()
    bei clever_FFmpeg_GUI.Form8.DomainUpDown7_SelectedItem Changed(Object sender, EventArgs e)
    bei System.Windows.Forms.DomainUpDown.OnSelectedItemCh anged(Object source, EventArgs e)
    bei System.Windows.Forms.Control.OnTextChanged(EventAr gs e)
    bei System.Windows.Forms.TextBoxBase.OnTextChanged(Eve ntArgs e)
    bei System.Windows.Forms.Control.set_Text(String value)
    bei System.Windows.Forms.TextBoxBase.set_Text(String value)
    bei System.Windows.Forms.UpDownBase.UpDownEdit.set_Tex t(String value)
    bei System.Windows.Forms.UpDownBase.set_Text(String value)
    bei System.Windows.Forms.DomainUpDown.set_SelectedInde x(Int32 value)
    bei clever_FFmpeg_GUI.Form8.Track_test_V()
    bei clever_FFmpeg_GUI.Form8.Form8_Load(Object sender, EventArgs e)
    bei System.Windows.Forms.Form.OnLoad(EventArgs e)
    bei System.Windows.Forms.Form.OnCreateControl()
    bei System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    bei System.Windows.Forms.Control.CreateControl()
    bei System.Windows.Forms.Control.WmShowWindow(Message& m)
    bei System.Windows.Forms.Control.WndProc(Message& m)
    bei System.Windows.Forms.Form.WmShowWindow(Message& m)
    bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  22. Originally Posted by Findu View Post
    This is ok so, because Virtualdub has no possibility to select the videostream.
    Tested with many 1280x720, 16:9 videos, I can't reproduce that here. Please post a pic.
    Will be done
    You can change the values with the controls. This way is impossible to insert wrong values.
    No, for h264 and hevc only
    Yes at the moment; in my beta I'm testing frame accurate cutting for h264 and hevc.
    This happens with videos with videostream index 1 instead of 0.
    Will be fixed.
  23. Here a pic
    [Attachment 86154 - Click to enlarge]
    And the metadata:
    General
    Complete name : C:\Users\Findu\Downloads\P1040337_cut#1.mov
    Format : MPEG-4
    Codec ID : qt 0000.02 (qt )
    File size : 19.1 MiB
    Duration : 4 s 967 ms
    Overall bit rate : 32.3 Mb/s
    Encoded date : 2010-10-18 04:03:52 UTC
    Tagged date : 2010-10-18 04:03:52 UTC
    major_brand : qt
    minor_version : 537331972
    compatible_brands : qt pana
    creation_time : 2010-10-18T04:03:52.000000Z
    encoding_tool : clever FFmpeg-GUI
    encoder : Lavf61.7.100
    Video
    Format : JPEG
    Codec ID : jpeg
    Bit rate : 32.1 Mb/s
    Height : 720 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 1.159
    Stream size : 19.0 MiB (99%)
    Language : English
  24. I can't drag and drop when the program keeps minimizing/disappearing to the background of a bigger program. It would be so nice to have a "stay on top" capability.
  25. Originally Posted by superballs69 View Post
    Hello,
    CRB encoding is an inefficient encoding because the same bit rate is always used regardless of the content.
    For this reason, I do not use it.
    To get around the 100% cpu problem, you could use an encoder that uses hardware support, e.g. h264_qsv for newer Intel platforms.
    Other encoders with hardware support are h264_amf (AMD hardware) or h264_nvenc (Nvidia hardware).
    Experiment for yourself.
    [Attachment 86157 - Click to enlarge]
  26. Originally Posted by Findu View Post
    Here a pic
    I cannot reproduce this. Try to describe it better.
  27. Try this 2-second example:
    P1040337_2s_cut.mov
    Video encoding, Filter & more, Rotate/Flip, Rotate 90 degrees cw or ccw, Preview...
    The video does not keep the aspect ratio.
  28. Originally Posted by Findu View Post
    Found it, will be fixed.
  29. Newest beta (v3.3.9.05), online now.
  30. @ ProWo
    3.3.9.05 Feedback
    The problematic videos now maintain the aspect ratio when the preview is rotated 90 degrees.
    However, the previous control of the height of the preview window is bypassed by rotating it 90 degrees. Because the rotated preview window is now too large and parts of the W11 menu bar covers it.
    > Cut does not work for files with video stream index 1 instead of 0.
    Error attempting to cut/join more than one parts.
    [Attachment 86183 - Click to enlarge]
