@ ProWo
3.3.7.03 Feedback 2
NEW: Cut page usage
The Preview is playing the last cut. Which is a good function.
But instead of "Clear all cut marks" a "Clear last cut" would make more sense.
As it will keep all good cuts you have checked before and only delete the last one (the one you can preview) if it is a bad one.
Each click will delete the "new/next" last cut, till all cuts have been deleted.
You can also clear all cut marks at once by closing the page and get back.
Question about a change in 3.3.7 for: No drag & drop in batch grid with more than 1 entry.
I for example had no problems while testing. You can change Batch 0 with "Swap tasks" and take over Batch 0, and that as often you like.
The Stream Cut Batch Tasks might be blocked from take over Batch 0!
Results 1,501 to 1,530 of 3439
Will be done.
Interesting idea; i have blocked this so far to prevent too many mistakes. But I can change that.Question about a change in 3.3.7 for: No drag & drop in batch grid with more than 1 entry.
If batch 0 is a stream cut, I will prevent drag & drop.The Stream Cut Batch Tasks might be blocked from take over Batch 0! -
Newest beta (v3.3.7.04), online now.
(Changelog will follow in the next full release). -
@ ProWo
3.3.7.04 Feedback
"Delete last cut mark" works as expected!
Drag & drop is blocked if batch 0 is a stream cut!
Switching Batch 0 replication is working!
Join plus Insert chapters is working with uppercase extensions!
Many thanks for the changes
Could you please show/add a "Clear files" button to the join page when joining files, like the "Clear cuts" button when you join cuts!
Is there a reason why the preview video in Chapters is always 720? -
@ ProWo
3.3.7.04 Feedback 2
Audio encoding page behavior:
When the source has 30 or 60 fps, the lenght & pitch preset show 23,976 -> 25/24
I wouldn't expect that/a preset here!
It would be good to show the source fps & bitrate somewhere at the page!
Especially when it's not the usual for movies.
What about this gui change or similar?
[Attachment 85135 - Click to enlarge]
Some problems with gui elements when you have select a container:
[Attachment 85136 - Click to enlarge]
[Attachment 85137 - Click to enlarge]Last edited by Findu; 27th Jan 2025 at 00:37.
This is intentional, as the vast majority of audiotracks of 29.97, 30, 60 fps videos come unchanged from a 23.976 fps source. The custom setting is available for the others.
I can move the checkbox, but there is no space available for the text.What about this gui change or similar?
This will be fixed.Some problems with gui elements when you have select a container:Last edited by ProWo; 27th Jan 2025 at 04:25.
@ ProWo
3.3.7.04 Feedback 3
If four or five decimal places aren't enough, it might be better to leave the checkbox where it is and write "Calculator" in front of it.
Is it possible to warn (red or yellow background/text color) if the chosen frequency/bitrate is higher than the source value?
Because higher values increase the file size and not so the quality.
At the drop down for Frequency I would expect higher values when you click up and not down. Like for Fade. -
There isn't enough space for it. I'll move the checkbox above for esthetic reasons only.
But the tooltip shows calculator.
I don't think that's necessary. If someone changes the frequency, they know what they are doing.Is it possible to warn (red or yellow background/text color) if the chosen frequency/bitrate is higher than the source value?
You're right, will change this.At the drop down for Frequency I would expect higher values when you click up and not down. Like for Fade. -
Thank you very much for indulging me.
Anyway I really appreciate that you have changed the custom for me so I can manipulate the FROM and TO fps instead of only the factor. It is really the same thing but I find the fps easier since the fps is my starting point when coming from media Tab/info it does not give you the factor. You are also very lucky if you can do a straight fps conversion and things match, never works for my movie cases. They always need extra stretching or shrinking or extensive audacity editing, these are old and rare movies.
I know what it takes to match audio and what a complicated topic it is, but I don't want to loose one of my tools in my arsenal.
I can match any english audio to any russian movie no matter what version or how different they are, I hate reading subtitles. I don't know why the russians always have good video versions with terrible overdubbing and the available English versions are so terrible, why cant they just store separate channels one can delete.
Thanks again. -
@ ProWo
3.3.7.04 Feedback 4
Okay!
Custom values will get the "Length only, Length & pitch, Pitch only" settings too?
You use the following code for:
Length only = atempo=1.04270938
Length & pitch = asetrate=44100*1.04270938
Pitch only = asetrate=44100*1.04270938,atempo=1/1.04270938
It looks like you've mixed up the last two!?
Errors with aac_mf and frequencies 7350, 8000, 12000, 64000, 88200.
Audio ---> aac_mf - Stream ID 1 from?C:\Users\Findu\Downloads\input2.mp4?326728?-y -fflags +genpts -i "C:\Users\Findu\Downloads\input2.mp4" -map 0:1 -c:a aac_mf -b:a 128k -ar 7350 -vn -sn -dn -metadata:g encoding_tool="clever FFmpeg-GUI" ?C:\Users\Findu\Downloads\input2_A1_#2.aac?
cause this error:
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.InvalidOperationException: Die Anforderung kann nicht verarbeitet werden, da der Prozess (15040) beendet wurde.
bei System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited)
bei System.Diagnostics.Process.Kill()
bei clever_FFmpeg_GUI.Module1.VB$StateMachine_150_Mypr oc_Doit.MoveNext()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei System.Runtime.ExceptionServices.ExceptionDispatch Info.Throw()
bei System.Runtime.CompilerServices.TaskAwaiter.Handle NonSuccessAndDebuggerNotification(Task task)
bei clever_FFmpeg_GUI.Form4.VB$StateMachine_396_FFmpeg Async.MoveNext()
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 4.0.0.0.
Win32-Version: 4.8.9290.0 built by: NET481REL1LAST_C.
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
clever FFmpeg GUI
Assembly-Version: 1.0.0.0.
Win32-Version: 3.3.7.04.
CodeBase: file:///C:/Users/Findu/Downloads/Software/mp4/Tools/clever_ffmpeg_gui/clever%20FFmpeg%20GUI.exe.
Microsoft.VisualBasic
Assembly-Version: 10.0.0.0.
Win32-Version: 14.8.9032.0 built by: NET481REL1.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll.
System
Win32-Version: 4.8.9282.0 built by: NET481REL1LAST_C.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Core
Win32-Version: 4.8.9277.0 built by: NET481REL1LAST_B.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Windows.Forms
Win32-Version: 4.8.9256.0 built by: NET481REL1LAST_B.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System.Drawing
Win32-Version: 4.8.9032.0 built by: NET481REL1.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
System.Runtime.Remoting
Win32-Version: 4.8.9214.0 built by: NET481REL1LAST_B.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll.
PortableSettingsProvider
Assembly-Version: 0.2.5.0.
Win32-Version: 0.2.5.0.
CodeBase: file:///C:/Users/Findu/Downloads/Software/mp4/Tools/clever_ffmpeg_gui/PortableSettingsProvider.DLL.
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll.
System.Web.Extensions
Win32-Version: 4.8.9282.0.
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll.
System.Web
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll.
mscorlib.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
System.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.resources.dll.
System.Windows.Forms.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt. -
If factor <>1
No issue, this is correct so.You use the following code for:
Thx for the hint. Will remove this frequencys for aac_mf.Errors with aac_mf and frequencies 7350, 8000, 12000, 64000, 88200. -
@ ProWo
3.3.7.04 Feedback 5
> If factor <>1
Your right! Did'nt try that!
Okay.
Channels, Bitrate, Frequency and Container keep it's settings after close and reopening.
So when you work with different mono, stereo and 5.1 files and want to change only the encoder, you always have to change Channels, Bitrate and Frequency manually, like the original. You have to remember all of that.
What about the idea to add a button to the Audio or Audio encoding page to import that values from the selected source stream? -
Newest beta (v3.3.7.05), online now.
@ ProWo
3.3.7.05 Feedback
This works as expected:
Add "Clear added files" button to the join page.
Preview windows size in Chapters now use general settings.
Moved the audio calculator checkbox.
Problems with gui elements plus audio container.
Switch order in drop down for frequency.
Removed aac_mf frequencies 7350, 8000, 12000, 64000, 88200.
Thank you for developing all of this further
> In the first versions, the values of the source audio were adopted.
In my daily work with it, I have found that I usually use the same settings for encoder, channels, bitrate and frequency.
Hence the change to use the last settings. I leave it like this.
Sure! It remains as it is.
Adopting the source values would be an addition for the ones how need it.
In ancient movies there are a wide variety of audio settings far from today's standard.
NEW: Could you re-sellect all remaining streams after multiplexing?
It looks strange when the lower settings are missing. -
@ ProWo
3.3.7.05 Feedback 2
> Will be done.
Thank you!
NEW: Video stream > Resize
What about a "Keep aspect ratio" option?
It would be helpful when changing the frame size.
Especially when the frame size is not exactly HD, FHD, QHD or UHD.
Changes to the frame width will automatically adjust the height and vice versa.
It could look like that for example:
[Attachment 85159 - Click to enlarge] -
@ ProWo
3.3.7.05 Feedback 3
Did you get the same blue marked text selection when that window appear?
[Attachment 85160 - Click to enlarge]
The number format changes ugly after the first delete of a cut mark.
Last zeros get only deleted at the start time.
[Attachment 85161 - Click to enlarge]
[Attachment 85162 - Click to enlarge]
Questions:
Why do you use two buttons for "clear adde files" and "clear cuts" in the join page?
Why does added files get removed from the multiplex and join tables when you leave them? -
I was trying to change DAR to vp9 video stream using DAR feature in Various but only 'container' allowed me to change there.
Using that result in pc media players did result valid, even media info is showing changed DAR, but using for example samsung smart TVs showed DAR was the original before the 'container' change, that means isn't working.
I wonder if vp9 video stream has some kind of complexity to produce the classic 'container & stream' DAR change that worked before even for the smart TVs but with other kind of video streams nor this vp9 ?Last edited by ingsoc; 28th Jan 2025 at 19:55.
It's a bug, will be fixed.
Will change the formatting.The number format changes ugly after the first delete of a cut mark.
This is because the cuts are also saved separately as a list. However, I will merge the buttons.Questions:
Because there is no reason to keep these entries when you leave the grid.
They can be added again at any time.
BTW
I will re-deselect all remaining streams by default after muxing.
I have noticed that when selecting streams for the next mux, it is easier to make mistakes with many streams if all streams are checked than if you consciously select them.Last edited by ProWo; 29th Jan 2025 at 07:32.
> BTW
Sure!
Please remember that when you open Multiplex for the first time, all streams are checked. And after muxing there are fewer streams left. If you click on None, everything is unmarked. It just looks strange when all the functions below are gone.
It would be enough if the remaining stream 0 and 1 were checked to display the functions. This is intended to help inexperienced users. I personally don't need that.
But first do as you think
I have just amplified the audio track of 18 episodes of a series with DynAudNorm and processed them in batch. I then had to add 17 episodes for muxing (because of the video stream), which results in 54 streams, two of which are muxed and then deleted. That means 18 x unnecessary clicks on none.
Newest beta (v3.3.7.06), online now.
@ ProWo
3.3.7.06 Feedback
Understand!
Can a Batch 0 for Multiplex speed things up like this?
FFplay Player controls is fixed.
Merge buttons "clear adde files" and "clear cuts" works.
New "Remove LCM" button looks good and formatting also.
I'm not sure if that formatting would be good for the junks in the join table?
Keep aspect ratio works good. This is realy helpfull.
Are there rounding errors? See your values in brackets.
UHD 3840x2160 (2158)
QHD 2560x1440 (1438)
FHD 1920x1080 (1078)
HD 1280x720 (okay) -
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 09:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 02:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 11:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 07:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 00:19
