Page 40 of 115
FirstFirst ... 30 38 39 40 41 42 50 90 ... LastLast
Results 1,171 to 1,200 of 3436
  1. @ProWo I'm happy to report that the 5.1 audio track is perfectly in sync throughout the whole duration of the film, does 500ms equate to half a second (0.5s), I thought it would be 50ms? I'm surprised the factor correction proved to be ineffective in this particular instance, thanks so much again for all your help
    Feb 2021
    Romania
    Thanks for the new update !!!
    After using many encoders i found the best one so far Clever FFmpeg-GUI the best .
    After many setting i recommend to leave "-hwaccel auto" because many of us having already Windows 10 or 11 and not many are using windows 7 .
    [Attachment 82835 - Click to enlarge]
    [Attachment 82833 - Click to enlarge]
    [Attachment 82834 - Click to enlarge]
    Few personal suggestions:
    *Clever FFmpeg-GUI does not recognize all movies interlaced so i add "yadif=0:0:0" before scaling in order to deinterlace automatic the interlaced frames with yadif as in my example
    -vf fps=24000/1001,yadif=0:0:0,crop=704:560:2:8,scale=1920:1080, format=p010le
    * adding for fps=24000/1001 "-look_ahead_depth 80 -g:v 240 -bf:v 8 -refs:v 5" the quality of encoded video changes radically to almost bluray quality using 5 frames to encode , 8 Number of B-frames to use instead of 4 for quality boost and a Maximum GOP size of 240 (10 seconds) for the fps 24000/1001
    * adding "-export_side_data film_grain" the encoder keeps the film grain quality of the original
    * adding "-fps_mode cfr" give the encoder the constant frame rate instead of variable frame rate, which some of the player can not play the movie
    * adding "-movflags +faststart" makes the movie fast to play specially when you remux it in mp4 box
    * adding "-map_metadata -1 -map_chapters -1" removes the metadata and chapters of the original encoder
    [Attachment 82836 - Click to enlarge]
    * adding "-profile:v main10 -tier main -level 40 -preset medium" give the encoder the right quality encoding for hevc_qsv
    * using "-global_quality 20" for hevc_qsv and 10 bit picture "format=p010le" i found it right for a good quality over the size and bit rate ( around 2000-2500 K )
    This is the modified BT_open.txt when you choose batch instead of encode so you can modify as you wish
    This is my best personal use so far :
    ====Video ---> hevc_qsv - Stream ID 0 from ?E:\UTORENT\Boy.Culture.2006.DVDRip.x264.mkv?52539 41?-hide_banner -hwaccel auto -loglevel error -stats -y -fflags +genpts -i "E:\UTORENT\Boy.Culture.2006.DVDRip.x264.mkv" -vf fps=24000/1001,yadif=0:0:0,crop=704:560:2:8,scale=1920:1080, format=p010le -map 0:0 -c:v hevc_qsv -profile:v main10 -tier main -level 40 -preset medium -global_quality 20 -look_ahead_depth 80 -g:v 240 -bf:v 8 -refs:v 5 -aspect 1.7777 -color_range tv -export_side_data film_grain -flags +global_header -fps_mode cfr -movflags +faststart -an -sn -dn -map_metadata -1 -map_chapters -1 -metadata:g encoding_tool="clever FFmpeg-GUI" ?C:\Users\Administrator\Videos\Boy.Culture.2006.DV DRip_5.mkv?1 ====
    Disregard the aspect ratio i use "-aspect 1.7777" as this is my way of changing the ratio of the movies , even if some ratio like 2.4 or 2.0 will show a little stretched movie ...
    Thank you for this great encoding tool !!!
  3. Originally Posted by oniiz86 View Post
    The factor correction makes no sense in this case, both videos are the same fps, 25.
    Yes 1000ms are 1 second, so 500ms are a half second.
  4. Originally Posted by Marcellos View Post
    In the next beta hwaccel auto is reintroduced for h264_qsv, h264_nvenc, hevc_qsv, hevc_nvenc and mpeg2_qsv encoders.
    This is not a good idea, using yadif in progressive videos spoils the picture quality.
    ... Maximum GOP size of 240 (10 seconds) for the fps 24000/1001
    This makes video editing more difficult (fewer keyframes).
    Grain is already present in the tune settings of the x264 and hevc encoder.
    clever FFmpeg-GUI always encodes at a constant frame rate.
    Already present in the multiplex grid with mp4 or mov container.
    The optimal tier and level are automatically selected by the encoder itself, changing the profile.
    You can already set both in the video encoding section.
    Feb 2021
    Romania
    Thanks for advices .. i adjusted and WOW ... big change !!!
  6. @ProWo So if "-hwaccel auto" will be reintroduced, the error I was experiencing with Beta v3.3.0.02 will re-emerge again or can it some how be disabled on my end with the "clever FFmpeg GUI.exe.config" file? I thought you had mentioned that it didn't bring much advantage having "-hwaccel auto" implemented? Is this something I can disable on my end via Nvidia Control Panel, I don't understand why this hardware acceleration auto setting is affecting HEVC files when trying to encode them as AVC.
  7. Originally Posted by oniiz86 View Post
    Is reintroduced for h264_qsv, h264_nvenc, hevc_qsv, hevc_nvenc and mpeg2_qsv encoders only.
    In Beta v3.3.0.02 it's active for all encoders.
    BTW
    I think, that the error was not related to Windows 7, but to your nVidia graphics.
    Could you test a new encode from a hevc video to avc, but this time with the h264_nvenc encoder instead of the x264 (avc) encoder?
    Report if there are problems with it.
    I don't have a nVidia card to test, so you can test it for me.
  8. Originally Posted by ProWo View Post
    BTW
    Oh okay that's great, I unfortunately deleted the previous Beta v3.3.0.02, would you be able to give me the link, I too would be curious to know.
  9. Originally Posted by oniiz86 View Post
    I no longer have it myself (I am currently working on 3.3.0.04).
    But you can make the detour via the BT_open.txt file.
    First select a hevc video, go to video encoding, select the h264_nvenc encoder, make your other settings and then click on To batch.
    Then quit the program and edit the BT_open.txt file.
    Add
    -hwaccel auto
    in the command line (before the -i).
    Make sure that a space is inserted before and after.
    Then save the file and restart clever FFmpeg-GUI.
    Execute the batch.
  10. @ProWo I attempted to execute the batch file using the "h264_nvenc" encoder setting but that same issue "error creating an internal frame pool" that I was experiencing happened again.
    [Attachment 82860 - Click to enlarge]
  11. Repeat it without - hwaccel auto and post the BT_open.txt here, please.
  12. @ProWo I had no such luck without "- hwaccel auto", a new error has come up,
    [Attachment 82861 - Click to enlarge]
    Here is the BT_open.txt file,
    Video ---> h264_nvenc - Stream ID 0 from ?C:\Clever ffmpeg GUI\Beetlejuice 1988.mkv?5526396?-hide_banner -loglevel error -stats -y -fflags +genpts -i "C:\Clever ffmpeg GUI\Beetlejuice 1988.mkv" -vf fps=23810/1000 -map 0:0 -c:v h264_nvenc -preset medium -global_quality 25 -an -sn -dn -metadata:g encoding_tool="clever FFmpeg-GUI" ?C:\Clever ffmpeg GUI\Beetlejuice 1988_0_0_h264_nvenc.mkv?1
    Also I don't think the Fix Framerate option corrected this file as it was 23.81 fps & I fixed it to 23.976 fps, the process completed successfully but it still shows as 23.81 fps, MediaInfo reports it as 23.976 (24000/1001).
    [Attachment 82862 - Click to enlarge]
    General
    Unique ID : 67449544971807947297039070518105698190 (0x32BE4F51A6BB15EB186FDF6E1CC56F8E)
    Complete name : C:\Clever ffmpeg GUI\Beetlejuice 1988.mkv
    Format : Matroska
    Format version : Version 4
    File size : 3.63 GiB
    Duration : 1 h 32 min
    Overall bit rate : 5 642 kb/s
    Frame rate : 23.976 FPS
    Writing application : clever FFmpeg-GUI
    Writing library : Lavf61.1.100
    ErrorDetectionType : Per level 1
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main 10@L4@Main
    Codec ID : V_MPEGH/ISO/HEVC
    Bit rate : 4 505 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.091
    Stream size : 2.90 GiB (80%)
    Writing library : x265 3.5+37+12-4e46995bc:[Windows][MSVC 1931][64 bit] 10bit
  13. will this compress the vob files/dvd video files like when you copy a disc you can burn it as the dvd files a folder with files like vob files or iso file would this compress the vob files cos i am after a software that will do that
  14. You must reload the fixed file.
    Retry the encoding with the fixed file.
  15. Originally Posted by barry25 View Post
    You need an DVD authoring software. Try DVDStyler.
  16. @ProWo I just finished encoding the hevc video stream to avc & the framerate is still 23.81 fps.
    [Attachment 82864 - Click to enlarge]
    MediaInfo reports 23.81fps too.
    Unique ID : 192099861693413853953883944104992890552 (0x9085166C9CDDF7CACD99FB87DECADEB8)
    Complete name : C:\Clever ffmpeg GUI\Beetlejuice 1988_muxed_0_0_x264 (avc).mkv
    Format : Matroska
    File size : 2.20 GiB
    Overall bit rate : 3 424 kb/s
    Frame rate : 23.810 FPS
    Video
    Format : AVC
    Format profile : High 10@L4
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate : 3 356 kb/s
    Color space : YUV
    Bit depth : 10 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.068
    Stream size : 2.16 GiB (98%)
    Writing library : x264 core 164 r3191 4613ac3
  17. Originally Posted by oniiz86 View Post
    You have encoded the wrong file with the wrong encoder.
    I asked you to fix the 23.81 fps file to 23.976 fps and try to encode the fixed file with the h264_nvenc encoder.
  18. Originally Posted by ProWo View Post
    It was actually the fixed file to 23.976 fps & I used x264 avc for the example above as I had no such luck using the h264_nvenc encoder as you can see below, also the fixed 23.976 fps file mentions 23.81 fps in the top left corner as well which is strange.
    [Attachment 82906 - Click to enlarge]
    [Attachment 82905 - Click to enlarge]
  19. Originally Posted by oniiz86 View Post
    Could you retry with this?
    Video ---> h264_nvenc - Stream ID 0 from?C:\Clever ffmpeg GUI\Beetlejuice 1988.mkv?5526396?-hide_banner -loglevel error -stats -y -fflags +genpts -i "C:\Clever ffmpeg GUI\Beetlejuice 1988.mkv" -map 0:0 -c:v h264_nvenc -cq 25 -an -sn -dn -metadata:g encoding_tool="clever FFmpeg-GUI"?C:\Clever ffmpeg GUI\Beetlejuice 1988_0_0_h264_nvenc.mkv?1
    Create a new BT_open.txt in your target folder.
    Copy and past the code above, save the file.
    Start clever FFmpeg-GUI and execute the batch.
    Any errors?
  20. Originally Posted by ProWo View Post
    Any errors?
    When I attempted to use the settings you posted above, I was given a "Index was outside the array" error when restarting Clever FFmpeg-GUI
    [Attachment 82909 - Click to enlarge]
    Okay I've had a look at your command line again & compared it to the BT_open.txt file & the reason it was throwing this error above is because you forgot to put a space after from & the ? mark, I put a space there, then I could get to the batch tasks screen but then when I went to execute the batch task, the following error happened.
    [Attachment 82910 - Click to enlarge]
  21. OK maybe this one:
    Video ---> h264_nvenc - Stream ID 0 from ?C:\Clever ffmpeg GUI\Beetlejuice 1988.mkv?5526396?-hide_banner -loglevel error -stats -y -fflags +genpts -i "C:\Clever ffmpeg GUI\Beetlejuice 1988.mkv" -map 0:0 -c:v h264_nvenc -cq 25 -an -sn -dn -metadata:g encoding_tool="clever FFmpeg-GUI" ?C:\Clever ffmpeg GUI\Beetlejuice 1988_0_0_h264_nvenc.mkv?1
  22. Unfortunately no such luck, a previous error I experienced has now returned.
    [Attachment 82918 - Click to enlarge]
  23. Originally Posted by oniiz86 View Post
    I think the fault lies with this movie (unusual FPS).
    Thank you for your tests, but at this point we are not doing any more tests.
    I will wait until a user posts a working command line for nVidia hardware support and then adjust the program.
  24. @oniiz86
    You can check here, if your nVidia GPU is supported for hardware acceleration.
    https://developer.nvidia.com/video-encode-and-decode-gpu-support-matrix-new
  25. @ProWo Thanks for that, perhaps I should have mentioned that I have a Geforce GTX680 that is from 2012 so it absolutely predates support for nvenc encoding, sorry for all the troubleshooting, one thing I'd like to ask is how "Fix Framerate" & "Change Framerate" under the "Various" settings on the Main page differ with the resulting file? The file that I have with 23.81 fps may have to use the "Change Framerate" setting or must I manually have to alter the setting on the "Video Encoding" screen in the top left corner in the "Frames p/s (fps)" box to 23.976 for the already "fixed" framerate file that I already processed from 23.81 to 23.976 using the "Fix Framerate" setting, in the below screen you can see the already fixed file from 23.81 to 23.976 still displaying 23.81 in the top left corner, if I change that to 23.976 will it only then be corrected?
    [Attachment 82957 - Click to enlarge]
  26. Originally Posted by oniiz86 View Post
    ...one thing I'd like to ask is how "Fix Framerate" & "Change Framerate" under the "Various" settings on the Main page differ with the resulting file? The file that I have with 23.81 fps may have to use the "Change Framerate" setting or must I manually have to alter the setting on the "Video Encoding" screen in the top left corner in the "Frames p/s (fps)" box to 23.976 for the already "fixed" framerate file that I already processed from 23.81 to 23.976 using the "Fix Framerate" setting, in the below screen you can see the already fixed file from 23.81 to 23.976 still displaying 23.81 in the top left corner, if I change that to 23.976 will it only then be corrected?
    Fix framerate and Change framerate (under various) has nothing to do with the normal video encoding settings.
    Fix framerate will fix a video with variable FPS near a known FPS value (23.976, 24, 25, 29.97 fps aso).
    So a video showing in mediainfo g.e. 3 different fps values (min, max, average) or a variable framratee near known values will fixed to constant FPS.
    In your case the 23.81 fps video will be fixed to 23.976, if you set the fps value to 23.976. Fix framerate processes the whole video, included audio and subs.
    Please note that other values (g.e. 25 in this case) will not work.
    With change framerate you can change the framerate from any h264 (avc) or h265 (hevc) video to any other framerate, without recoding.
    Note that the resulting video will be shorter or longer then the source video. Change framerate processes the videostream only. Audio must be changed separately.
    Both processes are indipendent from normal video encoding.
  27. Newest beta (v3.3.0.04), online now.
    Added:
    Chapters creating: automatic insertion of start chapter at starttime 0 (video start), so that chapter 1 is now reached by the player commands.
    Output file names check.
    h264_amf and hevc_amf hardware accelerated encoding.
    webvtt subs muxing in 3gp,mp4,mov.
    Fixed:
    Bug in chapters naming.
    Bugs in output file naming.
    Bug in forms positioning.
    Bug in audio channels remap.
    Bug in batch file handling.
    Bug in crops handling.
    Changed:
    Output file naming.
    Commandline for nvenc hardware encoding.
    Resumed:
    Hardware decoder, for supported hardware accelerated videoencoder only (The hw_accel decoder can be deactivated in the encoder settings).
  28. @ProWo I've done a bit more further testing with the "Fix Framerate" option & with my file that has a 23.81 fps it effectively does nothing to that file, remains at 23.81 fps, so it must be like you had said where certain mp4 file encodes that have a min, avg, max framerate, the "Fix Framerate" is most effective for those mp4 encoded files, I'm not sure why mp4 encodes turn out that way, it should always be a constant framerate like mkv & other file container formats.
    On the Video Encoding screen, I simply change the fps in the top left corner box from 23.81 fps to 23.976 fps & the video stream encode is correct at 23.976 (24000/1001) now as you can see below.
    [Attachment 83021 - Click to enlarge]
  29. Originally Posted by oniiz86 View Post
    @ProWo I've done a bit more further testing with the "Fix Framerate" option & with my file that has a 23.81 fps it effectively does nothing to that file, remains at 23.81 fps.
    I have retested the fix framerate (various) with your sample from post #1149.
    I've inserted 23.976 into the FPS field and clicked fix. It worked as aspected.
    [Attachment 83022 - Click to enlarge]
    This is obvious as you recode with new FPS.
  30. I have retested the fix framerate (various) with your sample from post #1149.
    That is strange that the short sample works as expected for you, I see you're on to the next Beta with v3.3.0.05. I tried with the latest Beta 3.3.0.04 & it still reports 23.81 fps but MediaInfo reports 23.976 (24000/1001) so a bit confused on this one.
    [Attachment 83030 - Click to enlarge]
    Also the fix framerate file didn't go to my target output folder C:\Clever ffmpeg GUI it went to the Clever FFmpeg-GUI program folder using Beta v3.3.0.04.
