This are the options for aac codec (aac_at, libfdk_aac not not available for licensing reasons).
So the most I can insert vbr as an option, with worse quality.Code:Native FFmpeg AAC Encoder (aac) The native FFmpeg AAC encoder. This is currently the second highest-quality AAC encoder available in FFmpeg and does not require an external library like the other AAC encoders described here. This is the default AAC encoder. By default, the native encoder produces AAC-LC, which is a "low complexity" profile of baseline AAC. It actually supports the more powerful "main" and "long-term prediction" profiles (documentation), but these are less tested. Examples Constant bit rate using -b:a: ffmpeg -i input.wav -c:a aac -b:a 160k output.m4a Variable bit rate using -q:a: ffmpeg -i input.wav -c:a aac -q:a 2 output.m4a Effective range for -q:a is around 0.1-2. This VBR is experimental and likely to get even worse results than the CBR. Native FFmpeg AAC Encoder does not do CBR audio encoding.
I will not implement this for several reasons
Results 691 to 720 of 3445
October 22, 2023 release version 3.1.5.
Fixed: bug in fix timestamps, bug in video encoding with LUTs, bug in HDR10 handling with smpte2084 files without HDR10 metadada, typos.
Added: automatic return to UI after audio filter selection, automatic selection of colorspace and colorrange if this info is missing from the source.
Improved: video filter handling, cutting code. -
I didn't implement this on purpose, because I don't think mass processing multiple videos with the same settings makes sense.Review by undercash
Sounds interesting but no possibility of batch encoding (like a whole folder for example).
But if it is desired, there are other GUI's that offer this.
btw
Value for money: 7/10, for a free program, really?Last edited by ProWo; 22nd Oct 2023 at 09:48.
Newest beta (v3.1.5.01), online now.
Fixed: little bug in output folder selection.
Added: output folder info and quit button on start screen.
Changed: button symbol (after encode audiostream), automatic return to select source screen after multiplex, cut and join. -
Hi ProWo
When importing a file for demuxing, I can only choose 1 stream at a time, if I'm not mistaken.
Is it possible to include extracting more than one track (or all, if need be) in one same run? Particularly for P7 Dolby Vision dualtrack-duallayer MP4 files I'd be happy with. -
Newest beta (v3.1.5.02), online now.
Added: You can now select the streams to extract.
@ Ennio
Try it -
Ho Prowo
Thanks for quick response. FYI this is MediaInfo on my source mp4
I'm wondering what to think of clever FFmpeg's extract window:Code:Video #1 ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 2 h 7 min Bit rate : 77.1 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.388 Stream size : 68.6 GiB (99%) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Menus : 4 Codec configuration box : hvcC Video #2 ID : 2 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 2 h 7 min Bit rate : 76.6 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.002 Stream size : 69.8 MiB (0%) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Codec configuration box : hvcC+dvcC Audio ID : 3 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : ac-3 Duration : 2 h 7 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 583 MiB (1%) Title : English (eac3 5.1) Language : English Service kind : Complete Main Default : Yes Alternate group : 1 Menu ID : 4 Format : Timed Text Codec ID : text Duration : 2 h 7 min Encoded date : 2023-10-04 18:34:14 UTC Tagged date : 2023-10-04 18:41:49 UTC Menu For : 1 Source duration : 7642134 Source frame count : 12 Source stream size : 279 Stream size : 279 00:00:00.000 : Chapter 1 00:12:39.383 : Chapter 2 00:22:44.696 : Chapter 3 00:35:04.769 : Chapter 4 00:48:36.038 : Chapter 5 00:59:11.506 : Chapter 6 01:10:34.271 : Chapter 7 01:24:45.413 : Chapter 8 01:34:49.141 : Chapter 9 01:41:50.812 : Chapter 10 01:51:18.296 : Chapter 11 02:00:19.378 : Chapter 12
[Attachment 74566 - Click to enlarge]
Is this proper? I'd at least expect the two videostreams being listed. Mind that it's a dualtrack-dual layer file where BL and EL+RPU are muxed in separate hevc streams. Also wondering what the numbers in the "Stream" column would represent. As for output result I can't tell you yet as I'm demuxing at the very moment.
Though still demuxing all tracks, I took a look in output folder. Which shows two videostreams being built and a chapters.txt file.
No sign of audio whatsoever - yet.Last edited by Ennio; 27th Oct 2023 at 06:12.
I don't have video files with multiple videostreams.
Could you cut 30 sec of your source file and post it here.
So i can have a look. -
Extraction complete. I have to correct myself. Initially thinking two videostreams being demuxed (because of .mp4 extension) it turns out the second mp4 stream is the audiotrack.
So endresult is baselayer.mp4, audiostream.mp4 and chapters.txt.
EL+RPU was not extracted.
I'll be happy to do so, if you can show me how to take a small part from such a mp4. I know how to do it for mkv with MKVToolNix, but as you undoubtedly know in matroska container P7 DoVi always has BL and EL+RPU interleaved in one hevc stream. -
Had a quick tour-de-force on how to convert STDL mkv to DTDL mp4
Here you go, hope it's not too big.Last edited by Ennio; 27th Oct 2023 at 08:54.
Newest beta (v3.1.5.03), online now.
Fixed: little bugs.
Added: can now handle multiple videostreams in one file, sample video encoding.Last edited by ProWo; 28th Oct 2023 at 03:44.
Hi Prowo
Selecting & extracting multiple streams seem good so far. One thing: can you add back the possibility to choose between output in container and elementary streams?
Thanks for your work. -
i have a slightly off-topic question but perhaps with your knowledge of ffmpeg you might know the answer:
is there a way to modify the header of a raw stream x265/hevc hdr file without re-encoding? there're (slightly) confusing discussions regarding this topic across the internet (including ffmpeg board) that go back years but i can't find any answer or proper tools to do just that. i know that ffmpeg utilizes "hevc_metadata" to modify certain x264 metadata but it's not clear if they ever got around to properly support x265/hdr matadata regardless of many related tickets listed on the ffmpeg board. there was an attempt at a tool that does just that (https://github.com/SK-Hardwired/nv_hevc_hdr_patcher) but it seems to be unfinished/outdated as it breaks the header entirely instead when used. i'm interested in modifying things like Mastering display data (--master-display), Maximum content light level/Maximum frame average light level (--max-cll), Color primaries (--colorprim) which are supported by x265-params but only for encoding/re-encoding. wondering if it's possible at all. thanks! -
i'm experimenting with injecting hdr10plus metadata to (same) hdr10 only content. those are the values that don't get transferred because they are not part of the hdr10plus json but of the hevc header. to properly match the way content is going to be treated by various devices those values need to be matched to the original values. modifying them without re-encoding seems to be issue for now.
mainly to learn new things but, arguably, hdr10plus provides better hdr due to utilizing dynamic metadata (vs hdr10 static metadata) which allow the devices to set up tone mapping and brightness levels frame by frame (or scene by scene), just like Dolby Vision. as a result, the appearance of the content is optimized for the capabilities of the screen.
Sorry for jumping in and asking, but do elementary hevc streams carry headers in the first place? Or is HDR metadata written in the frame packets? Where I know that DoVi's RPU binaries are written as SEI messages, I can imagine same for HDR/HDR10+.
yes, a proper name for it would be something like SEI-headers/messages stored in hevc_metadata so, essentially, they can be modified at the bitstream filter level. multiple patches to address just that were introduced at ffmpeg project but it seems like none of them made it (as far as i can see) because no agreement was made on it's nomenclature.
November 1, 2023 release version 3.1.6.
New:
Possibility to extract single or all streams.
Possibility to reorder the streams in the muxing grid.
Unsharp filter in video encoding.
The confirmation after successful task execution has been removed.
Automatic return to start screen after multiplexing.
Sample video encoding.
Can now handle multiple video streams in one file.
Output folder info on start screen.
Quit button on start screen.
Fixed:
Bug in output folder selection.
Other little bugs.
Improved:
The complete streams analysis recoded.
Changed:
Welcome screen.
Eia 607/708 captions extraction.
Background colors.
Multiple track extracting working like a charm for both container and elementary outputs.
Thanks a bunch, ProWo
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 09:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 02:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 11:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 07:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 00:19
