Page 21 of 115
FirstFirst ... 11 19 20 21 22 23 31 71 ... LastLast
Results 601 to 630 of 3445
    Mar 2008
    Question - should the frame accurate cut work if the H.264 source is I and P frames only ?
    Yes.
    I was playing around with it, encountered this problem of a bad join.
  2. Thanks davexnet for the files.
    Will investigate on this tomorrow.
  3. Prowo,sorry if I take advantage of your kindness.
    Is it possible when multiplexing files to put subtitles permanently in the video?
  4. Originally Posted by jopavirando View Post
    Not with multiplexing, but with the burn in function in the encode videostream section.
  5. Originally Posted by ProWo View Post
    Thanks.
  6. Newest beta (v3.1.0.05), online now.
    Changed: Cut section again.
  7. Originally Posted by jopavirando View Post
    Thanks.
    Hi Prowo,
    When I select the subtitles to integrate into the video, do I also have to check the avisynth box? Because otherwise when I do the multiplexing the subtitles are external to the video. I would like them integrated into the video. Thank you.
  8. Originally Posted by jopavirando;2688619Hi Prowo,
    When I select the subtitles to integrate into the video, do I also have to check the [url=https://www.videohelp.com/software/Avisynth
    avisynth[/url] box? Because otherwise when I do the multiplexing the subtitles are external to the video. I would like them integrated into the video. Thank you.
    No, the avisynth checkbox doesn't matter.
    Load your video, click main, click encode videostream, make your settings and set burn in subtitle.
    A small window opens and here make your settings like in the picture (embedded text subtitle assumed, otherwise select accordingly).
    The margin, fontsize, background settings are avaiable for text subtitles only.
    Then click encode.
    If done, when multiplexing, deselect the subtitle that was just burned in.
    [Attachment 70696 - Click to enlarge]
  9. Originally Posted by ProWo View Post
    Then click encode.
    Thanks, I try.
  10. Hi Prowo,
    When I select burn, this window opens and takes me to where the subtitles I found and loaded onto the PC are
  11. Originally Posted by jopavirando View Post
    Hi Prowo,
    If you burn in a subtitle you can choose a subtitle already present in the video as subtitle stream, or an external subtitle file.
    In the example above I've shown you how to use an already present subtitle stream in the video.
    Here i show you how to use an external subtitle file.
    [Attachment 70699 - Click to enlarge]
  12. Ok Prowo.
    My mistake.
    I was using the old 3.0 version, I hadn't updated to 3.1 yet.
    Sorry again and congratulations for the software improvements.
  13. Newest beta (v3.1.0.06), online now.
    Fixed: Keep HDR metadata on recoding HDR Video with H.265
    Added: HDR to SDR with tonemap and desaturation settings, with any avaiable video codec.
  14. Newest beta (v3.1.0.07), online now.
    Fixed: Bugs in HDR10 commandline.
  15. wrong post, please delete.
  16. May 12, 2023 release version 3.1.1.
    Fixed: missing variable reset bug, x265 profile settings bug, Bugs in HDR10 commandline.
    Added: Keep section open checkbox (for audio encoding ,video encoding, cut section), switch background color button, Keep HDR metadata on recoding HDR Video with H.265, HDR to SDR with tonemap and desaturation settings for any avaiable video codec.
    Changed: seeking approach in cut section, cosmetics on many forms.
  17. Newest beta (v3.1.1.01), online now.
    Improved: DVD Rip imports all streams now.
    Added:Info link for tonemap and desat (HDR10 to SDR).
  18. Image
    [Attachment 71187 - Click to enlarge]
    [Attachment 71188 - Click to enlarge]
    [Attachment 71189 - Click to enlarge]
    Sorry Prowo if I bother you again.
    I like the software but I have yet to learn it well.
    I would like to burn subtitles into the video and your software does that. I followed your instructions but sometimes I get it wrong.
    In the multiplex screen which streams are to be muxed? The green ones are the ones to convert and the white ones to be multiplexed or am I wrong? Because maybe I select the wrong ones. I am attaching my screenshots.
  19. The green ones are the previous processed streams (extracted or encoded).
    To burn in subtitle you don't have to use multiplex, but encode video.
    Check the burn in subtitle checkbox, select the wanted subtitle stream or an external subtitle file and click encode.
  20. I did exactly as you had already answered me in a previous post.
    But after that the two audio and video streams (video with mastered subtitles) don't have to be muxed in the multiplex section?
    Which boxes should I check in the multiplex section?
  21. You must check the new created videostream (in green) and all other streams except the videostream in blue and the subtitle you have already burned in.
    In your first picture are shown two preprocessed videostreams, but only one is the right one.
    you have to play them first to find the right one.
  22. Everything OK.
    I understand.
    Sorry again.
  23. You don't need to apologize.
    It's good if you ask. Did you succeed?
  24. Yes please.
    I was getting confused with the multiplex boxes.
    I wasn't clear which boxes to tick.
    Now it's clear:
    I need to find the video with subtitles burned and select it.
    Then I have to deselect the subtitles in both green and white and multiplex the selected streams.
  25. Member
    May 2023
    Calne, Wilts, UK
    Hi, just getting to grips with the gui, think there are a few bugs, but i have a question is there a way to get ffmpeg to output uncompressed AVI video or PNG still frames, i want to pass the out put to a jpeg2000 encoder. Also how does one set the compression ratio/bit rate? i presume fastest setting is lowest bitrate, poor quality?
  26. Originally Posted by Cineman View Post
    You can create an uncompressed video with the x264 encoder and crf 0 and mux it into an avi container.
    The jpeg2000 encoder (an old and little used codex) is not implemented in clever FFmpeg-GUI, nor the single pictures output.
    The tool is designed for video, audio and subtitle editing. Anyway you can use the ffmpeg commandline for your purposes.
    The video quality is controlled with the settings of the respective codec. For x264 it is controlled with the CRF value.
    The lower the value, the higher the bitrate and quality.
    Read this:
    https://trac.ffmpeg.org/wiki/Encode/H.264
    Here is also explained the choice of presets.
  27. Member
    May 2023
    Calne, Wilts, UK
    Hi ProWo, I had a bit more experimentation last night and found the function of CFR, tried an encode with a setting of 0 and it generated weird encoding artifacts white flashes on sharp edges and a low bit rate look in textures, limited colour space, like a highly compressed jpg image. I'm using it to add burned in subtitles as part of the process of making DCP's, I’m already using ffmpeg to spit out png from mp4 input files to feed into image magic to covert to xyz colour space before passing the image files to an open jpeg2000 codec.
    when i created my gui i don't think ffmpeg could render subtitles, perhaps it time to add a few more features.
  28. Will do a few tests and come back to you soon.
    btw: to burn in subtitles there is a checkbox, in the encode videostream section.
