Page 124 of 124
FirstFirst ... 24 74 114 122 123 124
Results 3,691 to 3,707 of 3707
  1. @ProWo Thanks so much again for finding a fix for this issue so quickly, it's oh so greatly appreciated.
  2. @ProWo I just thought it was worth a mention, I noticed a speed difference between the initial 3.5.9.06 beta dated (20/10/2026 11:59PM) you provided via PM in that the 64.2 GB file loads instantaneously when importing into clever compared to the latest 3.5.9.06 beta dated (23/10/2026 3:55AM) you posted here https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.zip which takes between 3-5 seconds longer to load the same file, is it possible to optimise the code further during the file analysis so it behaves just as quick as the initial 3.5.9.06 beta?
  3. Originally Posted by oniiz86 View Post
    This is because the first fix skips the scan type detection after the first error, but gives no scan type result.
    [Attachment 94117 - Click to enlarge]
    The final fix ínstead does the correct scan type detection and this takes a little time.
    [Attachment 94118 - Click to enlarge]
  4. @ProWo I noticed that the link for the info for the tonemapping filters is broken the clickable "here" doesn't appear to do anything at all, I believe it was working at some point but the official v3.5.9 & latest 3.5.9.06 beta release no longer work.
    [Attachment 94141 - Click to enlarge]
  5. Originally Posted by oniiz86 View Post
    Thx, you're right, I will fix it.
  6. ----------------------------------------------------------------------------------
    November 02, 2026 release version 3.6.0
    Added:
    Bufsize for mpeg2, h264, hevc encoders
    HDR streams handling in videos with multiple videostreams
    Indexing counter on indexing window
    Mount ISO file and dismount it when closing
    Dolby vision profile in streams info
    Missing colorspace info is now detected as unknown
    Automatic colorspace info insertion for DV profile 5
    Form closing inhibition for subforms
    Missing video duration calculation from number of frames
    Fixed:
    Bug with video encode all streams with attachments
    Bug with double source file analysis with source file already loaded
    Bug in stream duration detection
    Bug with preview with multiple videostreams
    Bug with index with multiple videostreams in source
    Bug with lossless colorspace conversion
    Bug in change colorspace commandline
    Bug with wrong analyzeduration in multiplex section
    Bug with missing source streams in multiplex section
    Bug with analyzing video with dvdsub picture size 0x0
    Bug with missing show cmdl in cut section
    Bug with interlaced recognition
    Bug with linklabel disalignment start form
    Bug with loudnorm 2 pass filter
    Bug with missing batch tasks section closing (if selected)
    Bug with inactive link
    Bug with extracting coverart
    Improved:
    Interlaced source handling
    Extraction handling in batch tasks
    Interlaced detection
    Ffmpeg process execution
    HDR metadata in side_data detection
    AVS encoding (avisynth support)
    Changed:
    Video index recognition with multiple videostreams in source file centralized now
    Scan for errors handling
    Cut help pages handling
    Indexing process is async now
    Colorspace items names
  7. @ProWo
    3.6.0 feedback
    Scan for errors does not add HWA decoding in the ffmpeg code like:
    FFmpeg.exe -hwaccel amf -hwaccel_output_format amf -i "C:\input.mkv" -f null -
    It always use:
    FFmpeg.exe -i "C:\input.mkv" -f null -
  8. @ProWo
    3.6.0 feedback 2
    - The source file & path does not get add to the ffmpeg preview code for video encoding and video adjustments.
    FFplay.exe -ss 112 -vst 0 -ast 1 -vf fps=24000/1000,scale=854:480,drawtext=text='%{pts\:hms}:font file=C\:/Windows/Fonts/segoeui.ttf:fontsize=18:box=1:x=(w-tw)/2:y=h-(2*lh)' -sn ""
    - The cut page does not save FFplay as your default player for search any longer when you reopen the page.
    And the help page does not have additional infos for Frame accurate cut in combination with virtualdub.
    - The grid scroll bar arrow has background colour other than white.
    [Attachment 94202 - Click to enlarge]
    [Attachment 94203 - Click to enlarge]
    [Attachment 94204 - Click to enlarge]
    EDIT: - How about switching position of Video encoding, Deinterlace and Interlaced, which is more common and to remove the gap in the list?
  9. Originally Posted by Findu View Post
    Thx. Can you confirm that -hwaccel amf -hwaccel_output_format amf is faster than -hwaccel amf only on your system?
    Here with me the error scan is faster without the hw accelerated decoding (99x vs 71.5x).
  10. Originally Posted by Findu View Post
    FFplay.exe -ss 112 -vst 0 -ast 1 -vf fps=24000/1000,scale=854:480,drawtext=text='%{pts\:hms}:font file=C\:/Windows/Fonts/segoeui.ttf:fontsize=18:box=1=(w-tw)/2:y=h-(2*lh)' -sn ""
    Thx, will be fixed.
    I changed it that way on purpose; I've found that VirtualDub 2 is more accurate when it comes to keyframe detection.
    Thx, will be fixed.
    I can't reproduce that here. Tested with different DPI settings (100%, 125%, 150%).
    I think that most users want progressive output, and that's why deinterlacing interlaced sources takes priority here.
  11. Originally Posted by ProWo View Post
    On my system, -hwaccel amf -hwaccel_output_format amf is as fast as -hwaccel amf.
    And the error scan is faster without the hw accelerated decoding (32.8x vs 19.7x).
    But my AMD Ryzen 5 7530U has a slow Vega 7.
  12. The grid scroll bar arrow has background colour other than white.
    Okay. To clarify. I mean the black background next to (or below) the arrow key.
    [Attachment 94214 - Click to enlarge]
    I’ve got that on the Intel system as well.
    In older versions, a grey background was used.
    I also have grey and green.
    [Attachment 94215 - Click to enlarge]
    But it’s no big deal. I just noticed it.
  13. Originally Posted by Findu View Post
    Here with me, scaling to 150%
    [Attachment 94216 - Click to enlarge]
    Maybe you need to update your Microsoft Visual C++ Redistributable package.
  14. Originally Posted by ProWo View Post
    Done. Update please to 3.5.9.05. Test it.
    Info:
    Select or drag the iso. You get a message if is sucessfully mounted.
    Then select your m2ts file for further processing.
    Closing clever, the mounted ISO is automatically dismounted.
    Just tested. Clever always asks to execute PowerShell, but not sure if the process is working. I think I'll keep using MakeMKV, I guess additional software is required for the GUI Thanks anyway.
  15. Originally Posted by AlanFord54 View Post
    Clever uses a PowerShell command to mount and dismount the ISO.
    PowerShell is not additional software, but rather a part of the Windows operating system.
  16. Originally Posted by ProWo View Post
    Thx. The C++ Redists are up to date. But a restart fixed the problem!
  17. @ProWo
    3.6.0.01 feedback
    Thanks for your latest corrections and changes.
    The items mentioned are now working and looking good.
    Restarting my Intel system also fixed the problem with the size of the arrow keys on the scrollbar!?
