Use the special 5.1 to 2 channels set only.
Results 331 to 360 of 3443
April 05, 2022 update to version 2.9.6.
Added: Info Label for processed streams, new duration info on video or audio length change.
Improved: Crop detection.
Changed: Automatic change to Bt709, framerate commandline from -r to -vf fps, av1 encoder descriptions, new logo and color changes. -
Please post here in the future.Originally Posted by tvviewer (from reviews)
clever FFmpeg-GUI doesn't contain any virus, it's a false positive.
Download the newest beta here:
https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.7z
(The new versions work both on 32bit and 64bit systems)
Delete this folder first:
C:\Users\xxx\AppData\Local\clever_FFmpeg_GUI
(where xxx is your username)
Then start the new downloaded clever FFmpeg GUI.exe. -
Windows Defender and Opera also say its a virus/trojan
webfile: C:\Users\...\Desktop\clever_ffmpeg_gui_296.7z
Trojan:Script/Oneeva.A!ml
This program is dangerous and executes commands from an attacker.
May 02, 2022 update to version 2.9.7.
Fixed: dnxhr encoding, dnxhr muxing to mov and mxf, svt-av1 and rav1e encoding prevented with 32bit os, interlaced mpeg2 and avc encoding, av1 encoder selection on 32 bit OS.
Changed: Button positions in crop UI.
Improved: AC3 5.1 patch (fully recoded).Last edited by ProWo; 3rd May 2022 at 03:15. Reason: typo
Hi
I ran into one problem related to closed subtitles and tried to extract them. Unfortunately, no program sees them. (the player sees them) And I was wondering if it's possible to make it so that the smart FFmpeg-GUI can see them (and, of course, process them)? -
General
Complete name : F:\Video\TTC - Language and the Mind\1623 - Language and the Mind.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/avc1/mp42)
File size : 10.7 MiB
Duration : 1 min 11 s
Overall bit rate : 1 261 kb/s
Encoded date : UTC 2020-03-20 15:45:18
Tagged date : UTC 2020-03-20 15:45:18
Video
Format : AVC
Format profile : Baseline@L3.1
Format settings : 3 Ref Frames
Format settings, CABAC : No
Format settings, ReFrames : 3 frames
Codec ID : avc1
Bit rate mode : Constant
Bit rate : 1 154 kb/s
Maximum bit rate : 2 765 kb/s
Width : 854 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.094
Stream size : 9.84 MiB (92%)
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 96.0 kb/s
Maximum bit rate : 101 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 836 KiB (8%)
Language : English
Text #1
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Encoded stream size : 0.00 Byte (0%)
CaptionServiceName : CC1
Text #2
Format : EIA-708
Encoded stream size : 0.00 Byte (0%) -
If you load the 1623 - Language and the Mind.mp4 video into clever FFmpeg-GUI the caption streams are shown?
Could you upload the entire file here? -
no, subtitle streams are not displayed in clever FFmpeg-GUI.
here is the file: -
C:\Users\Artur\PortProg\ffmpeg-4.2-win64-static\bin>ffmpeg -f lavfi -i movie="1623
- Language and the Mind.mp4"[out+subcc] -map 0:1 output.srt
ffmpeg version 4.3.2-2021-02-27-full_build-www.gyan.dev Copyright (c) 2000-2021
the FFmpeg developers
built with gcc 10.2.0 (Rev6, Built by MSYS2 project)
configuration: --enable-gpl --enable-version3 --enable-static --disable-w32thr
eads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --e
nable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enab
le-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray -
-enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav
1e --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-
libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --en
able-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enab
le-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --e
nable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --ena
ble-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-lib
opencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable
-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-li
bopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-l
adspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberba
nd --enable-libsoxr --enable-chromaprint
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
Input #0, lavfi, from 'movie=1623 - Language and the Mind.mp4[out+subcc]':
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 854x480 [SAR 1:1
DAR 427:240], 29.97 fps, 29.97 tbr, 30k tbn, 30k tbc
Stream #0:1: Subtitle: eia_608
Output #0, srt, to 'output.srt':
Metadata:
encoder : Lavf58.45.100
Stream #0:0: Subtitle: subrip (srt)
Metadata:
encoder : Lavc58.91.100 srt
Stream mapping:
Stream #0:1 -> #0:0 (eia_608 (cc_dec) -> subrip (srt))
Press [q] to stop, [?] for help
[Parsed_movie_0 @ 000000000041fb40] EOF timestamp not reliable.19x
size= 2kB time=00:00:20.81 bitrate= 1.0kbits/s speed=5.17x
video:0kB audio:0kB subtitle:2kB other streams:0kB global headers:0kB muxing ove
rhead: 38.261353%
C:\Users\Artur\PortProg\ffmpeg-4.2-win64-static\bin> -
Your ffmpeg (ffmpeg version 4.3.2-2021-02-27) is outdated.
Get a newer one and retry.
You could also try the newest beta of clever FFmpeg-GUI.
I've implemented a simple captions EIA-608/708 extraction.
The captions aren't shown in streams, but will be extracted and converted to srt, if exists.Last edited by ProWo; 3rd May 2022 at 10:47.
Yes, the cause of the wrong timing is outdated ffmpeg. The files (.srt) themselves are identical except for the timings. I tried your new BETA clever FFmpeg-GUI and EIA-608/708 extraction works like a charm! Thanks a lot!
I rated it,
although there is one file among others which is a hard nut.
It looks like the program does not see captions at all, but it rapports - 'done' in no time. -
There is problem in lavfi filter of ffmpeg.
It seems to ignore long filenames.
Rename your file to test.mp4, then it should work.
PS.
Did further research.
The error is not the name length, but the comma.
Lavfi does not accept a comma in the movie name. This is a bug in FFmpeg.Last edited by ProWo; 5th May 2022 at 15:02. Reason: further research
May 06 2022 Added: Color range setting in video encoding section (in the newest beta, v2.9.7.07).
Try it and report issues here. -
Why can't I convert FPS audio now?
When I set the desired value, the convert button disappears.Last edited by hevron; 8th May 2022 at 07:05.
Select one of the options (pitch only/pitch & length/length only).
May 09 2022 Added: Video wmv encoding, mux to flv and wmv, extract atrac3 audio stream (in the newest beta, v2.9.7.08).
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 09:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 02:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 11:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 07:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 00:19
