Results 3,151 to 3,180 of 3436
@ ProWo
v3.4.9.01 feedback
FIXED: Processed video streams does not appear in the mux grid!
> Bottom left.
Sorry, operational blindness!Last edited by Findu; 26th Nov 2025 at 09:23.
TRY THIS
ffmpeg -i input.mp4 ^
-map 0 ^
-c copy ^
-movflags use_metadata_tags ^
-movflags +faststart ^
-bsf:a aac_adtstoasc ^
-avoid_negative_ts make_zero ^
-fflags +bitexact ^
output.mp4
With Chapters (IMPORT) ;FFMETADATA1
-i chapters.txt ^
-map 0 ^
-c copy ^
-fflags +bitexact ^
-map_chapters 1 ^
output.mp4
With Chapters (IMPORT) ;FFMETADATA1 and Without Subs
-i chapters.txt ^
-map 0:v ^
-map 0:a ^
-c copy ^
-fflags +bitexact ^
-map_chapters 1 ^
output.mp4 -
@OFLU
Tried. What's the diffrence. Clever..also does the same thing. I always do my work encoding/muxing with CFFmpeg GUI and finally a touch up of the mux with MP4Box. That's it...you get the perfect MP4. Who uses command lines if you have the GUI to do all the work !TRY THIS -
@OFLU
Improved FFmpeg Command
Key ImprovementsCode:ffmpeg -hide_banner -i input.mp4 ` -i chapters.txt ` -map 0:v ` -map 0:a ` -c:v libx264 -preset medium -crf 23 ` -c:a aac -b:a 192k ` -map_chapters 1 ` -movflags +faststart ` -fflags +bitexact ` -avoid_negative_ts make_zero ` -bsf:a aac_adtstoasc ` -filter_complex "[0:v][0:a]strip=remove_gps=1,strip=remove_tmcd=1[v][a]" ` -map "[v]" -map "[a]" ` output.mp4
- Added stream stripping to remove GPS and TMCD metadata
- Added -hide_banner for cleaner output
- Explicit video and audio codec settings
- Used filter_complex to remove unwanted metadata streams
Optimization Breakdown
Metadata:
- Removes GPS and TMCD streams
- Preserves chapter information -
In the mux grid, hitting the Enter key moves the focus down. You can do that with the down arrow key. Can you make it so that hitting the Enter key checks/unchecks the boxes? Thanks.
@ ProWo
v3.4.9.01 feedback
I noticed that with 3.4.9.01, the construction of the Mux grid has slowed down. You can now see the automatic column width adjustment for a short moment.
[Attachment 89952 - Click to enlarge]
[Attachment 89953 - Click to enlarge]
EDIT:
It also looks as if the entire app window increases in size by 5% when the app image is rendered.
EDIT2:
The slow down has nothing to do with windows scaling or animation effects.Last edited by Findu; 27th Nov 2025 at 01:31.
@videoAI
My commands are for muxing purpose only. No encoding/reencoding. Anyway's I do agree with @sam12345 that FFmpeg does not deal AAC audio with ADTS (Audio Data Transport Stream) headers properly and MP4box does it well.ffmpeg -hide_banner -i input.mp4 `
-i chapters.txt `
-map 0:v `
-map 0:a `
-map_chapters 1 `
-fflags +bitexact `
output.mp4 -
@ ProWo
Minor text things:
The tooltips for Chapters, Automatic creation are not entirely correct.
How about changing the button text "Detect" into "Next detection" at the Crop detection page?
Also in the short description on the page.
Tooltip text change for Video encoding, HWA decoding:
Hardware-accelerated decoding options.
Beware that crop and scale options may
not work as expected.
Selecting none or auto should always work.
Could the text Select and Cancel be at the same level?
[Attachment 89958 - Click to enlarge]
The word file is missing on the Main page:
[Attachment 89956 - Click to enlarge]
[Attachment 89957 - Click to enlarge] -
@ ProWo
I can not mux more than 1 video stream into mp4 containers any longer!
[Attachment 89969 - Click to enlarge]
If you look closely, you can see that on the Main page, the space between the buttons marked in red is one pixel higher than all the other spaces between the buttons.
And the text position of “Toggel destination” is one pixel higher on the button than on all other buttons.
[Attachment 89971 - Click to enlarge] -
Bug caused by the hvc1 tag for the hevc stream. Will fix it.
Code checked, the spaces between the buttons are all the same.If you look closely, you can see that on the Main page, the space between the buttons marked in red is one pixel higher than all the other spaces between the buttons.
Will be fixed.And the text position of “Toggel destination” is one pixel higher on the button than on all other buttons. -
@ ProWo
v3.4.9.02 feedback
Thank you for the last fix and all the text changes.
Here a closer look at the Main page:
When you copy and move the content of the red frame to the new position, you see that it does not fit.
[Attachment 89977 - Click to enlarge]
[Attachment 89978 - Click to enlarge] -
@ ProWo
With $_V, $_A, $_S and $_ as separators/expansion for processed and extracted streams, the Mux page recognizes that these are different file names and offers "Mux whole grid" when you unselect one source stream.
Can the processed streams be excluded from this?
[Attachment 89979 - Click to enlarge] -
The situation is as follows:
For example, you only change the audio stream of the source file because you want to replace it with stereo sound.
If you now deactivate the source audio stream for muxing and accidentally select Mux whole grid, the option disappears and cannot be deselected. However, this is possible with added files.
You then have to leave the Mux page to deactivate Mux whole grid or click None and All and make your new stream selections.
This is not a big deal, but it can be confusing for beginners because it would result in a file with two audio streams. -
I just noticed that mux whole grid also appears when only the source file is in the mux grid and any stream is deactivated. If you click Mux whole grid, the option disappears. It would make sense for the option to remain visible after activating so that it can be deactivated again.
@ProWo
v3.4.9.02
Most programs I use offer to backup settings/configuration.
None offer to backup the whole program. simply because a
program can be re-downloaded, but settings, if not backed
up, have to be re-created from scratch.
Clever, on the other hand, offers to backup the App, but not
the config files [the settings]. That is good for testers
[regression testing] but not so much for the average user.
I hope a future version would remedy this deficiency, and
offer backup for config/settings.
Have a nice weekend guys .. -
@ ProWo
v3.4.9.03
How about expanding the tooltip for Container DAR, Set to values:
1,33 = 4:3
1,78 = 16:9
1,85 = Cinema
2,39 = Cinemascope -
Hi ProWo, thanks for your amazing video utility program, how you provide so much functionality in such a small package is almost beyond belief.
Are you aware of this 'anomaly' - which still happens in the latest build ?
AAC Audio files output from Premiere have an MP4 extension – it needs changing or adding a suffix of "AAC"
Otherwise Clever FFmpeg GUI adds in a second Video track (duplicated?) and no audio, leaving the audio file in the grid after muxing
Changing the audio file's extension to AAC makes it work as normal.
Thanks again for your efforts in providing such a useful program to the many grateful users out there... -
Why?
What do you want to do with the aac audio stream (in the mp4 container)?Otherwise Clever adds in a second Video track (duplicated?) and no audio, leaving the audio file in the grid after muxing
Do you want to add it somewhere?
Please explain exactly, step by step. -
Hi ProWo – to explain further…bear with me, hope this makes some sense…
I sometimes use Premiere’s Essential Sound to improve a video file’s audio dialog – saving just the audio is much quicker if I don’t need to process the entire video. Premiere saves the AAC audio with an *.mp4 extension which I figured shouldn’t be a problem.
Then I multiplex Premiere’s *.mp4 (AAC) audio file with the original MP4 video stream to an MP4 container, avoiding reprocessing the entire video - Clever FFmpeg GUI is just so damn fast :-}
Note: Before muxing, I deselect the video file’s audio stream and select the new MP4 (AAC) audio stream and it shows ‘To Mux: 2’
With *.AAC files there’s no problem but with Premiere’s AAC files having an MP4 extension, the resultant multiplexed file has 2 video streams and no audio with a consequential almost doubling of the file size (which first alerted me to the problem).
The *.MP4 (AAC) audio file remains alone in the grid after multiplexing removed the others.
Changing the audio file’s MP4 extension to AAC before multiplexing to MP4 solves the problem.
It’s a minor issue with an easy work-around but I thought you might like to be aware of it.
P.S.I tested the same mux with MKV and MOV containers and it worked with Premiere’s *.MP4 (AAC) audio file without problems.
Using the 349 build and ffmpeg 8.0.1
Interestingly, I also tested Shutter Encoder’s Replace Audio function with Premiere’s *.MP4 audio file but if I don’t use the Convert to AAC option it fails with a bunch of errors like this:
[vist#0:0/h264 @ 00000129ee273c80] [dec:h264 @ 00000129ee27d580] Error submitting packet to decoder: Invalid data found when processing input.
Again, after changing the MP4 extension to AAC, it works ok without needing the Convert option.
Both these programs use ffmpeg so maybe it doesn’t like the mismatch between the *.MP4 extension and the AAC LC content in an MP4 container (simplistic, I know)?
Curiouser and Curiouser
Regards… -
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 09:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 02:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 11:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 07:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 00:19
