Results 3,061 to 3,090 of 3347
Just tested; it works as aspected.
With NO, the cuts are done, but not added to the join list. With YES, they're added.
If you cut a video with chapters in 3 parts, the chapters are copied in all 3 cut chunks, but if you join them, the chapters are removed.Can something be done along with chapters?
If you check the chapters checkbox at joining, new chaperts are written at the join timestamps.Last edited by ProWo; 18th Nov 2025 at 12:47.
add audio file, say NO, and on exit it will be added to the muxing list. It is happening since all the last betas and past version.
@ ProWo
v3.4.7.11
Strange DVD-Rip behavior with a single VTS_01_1.VOB file:
When you start the app, click "Select Source File" select the only VOB file from your HD/SD folder such as VTS_01_1.VOB, you will see the "Possible DVD source" window. If you click Yes, the DVD-Rip page opens. If you click Rip, you will return to a Main page with deactivated options and the "Possible DVD source" window will reappear. If you click Yes, you will see a mixed page consisting of the DVD-Rip and Main pages!
DVD-Rip page NEW:
[Attachment 89784 - Click to enlarge]
Main page with deactivated options:
[Attachment 89785 - Click to enlarge]
When you click Main page you are back at the usual Main page. Good.
But when you open the same vob file again via "Select source file", you get the "Possible DVD source" window, when you click Yes the DVD-Rip page appear, this time with "Rip in progress...", but nothing happens.
DVD-Rip/Main page combination:
[Attachment 89786 - Click to enlarge]
When you click on "Rip in progress..." you get the "Possible DVD source" window, when you click Yes, the DVD-Rip/Main page combination opens.
DVD-Rip page NEW:
[Attachment 89787 - Click to enlarge]
Experienced users certainly don't do what as described. But beginners won't get anywhere with it.
Info window "Possible DVD source", proposal for a text amendment for improved readability:
This file could be part of a DVD movie.
Yes, rip the entire movie.
No, use only this file. -
Could you at least consider adding this simple way to copy the command line output? Unfortunately, the existing options are all time-consuming and have drawbacks.
[Attachment 89790 - Click to enlarge]
1. `<cmd_l>1</cmd_l>`
This shows a MessageBox for every action, but copying from it always includes extra text such as the window title and the OK/Cancel, etc.
2. `BT_open.tx`
This closes Clever and opens a text file, which interrupts the workflow and isn’t practical for quick command-line checks.
3. Batch tasks
This requires adding an action to the batch list even when you only want to view the command line. Returning to previous windows can reset some settings, interrupting the workflow, and the item must remain in Row 1 to display the correct command. This forces users to repeatedly clear and re-add items just to check another command. Even if other rows are added, the process remains inefficient—especially for users who don’t regularly work with batch tasks.
Right now, my workaround is to use a heavy process-monitoring tool or the Event Viewer to capture the command line. I’d really prefer not to rely on that, but it’s still faster than the built-in methods above.
A simple “mouse2 copy” function would solve all of this. -
Most modern apps expose ffmpeg commands these days ..
Here is an example:
[Attachment 89792 - Click to enlarge]
As I already said, there will be no further command line support.
I don't want users messing around with the command line. -
@ ProWo
v3.4.7.12 feedback
Thanks for the latest fixes and changes.
The fixes are working well so far.
Suggestion:
Could the "Process aborted" window appear only once, as long as the Video/Audio encoding page stay open?
Once you've read and clicked OK, you'll know what happens next time when you abort at this open page!
Minor text change idea:
Video encoding aborted.
The unfinished file will be deleted. -
It has been saved for a long time.
Still to be done.[*]post2786194
Zero file check to all extracts [including srt]
I will not make these changes.[*]post2786386
Save default settings for:
1- After Mux Action [Dropdown Selection]
2- Title [Checkmark]
-----------------[*]post2786330
Batch Remove tmcd stream
-----------------[*]post2785921
Output Folder
Replacing the label with the actual toggle button -
@ ProWo
v3.4.7.12 feedback
The lossless crop "preview" is experiencing issues.
Just button cropping does not get displayed.
Just left cropping get displayed right.
Just right cropping get displayed at the button.
The source file is mkv.
All files processed with cropped metadata are displayed correctly. Only the lossless crop "preview" has problems. -
@ProWo
v3.4.7.12 feedback
Edit #1
duplicated the issue again .. it is a bug.
FYI, Video stream shows in sub dropdown ..
is that supposed to happen?
[Attachment 89803 - Click to enlarge]Last edited by videoAI; 20th Nov 2025 at 09:40.
@ProWo I was wondering if you've confirmed if this is a bug, if so has it been or will it be addressed?
I was also wondering if you could tell me why my HDR-SDR conversion video size is so small, the original video stream is 40GB and after the SDR conversion it's just 3GB in size, Encoder settings were CRF 23, Preset "medium", Tune "auto",Profile "auto" & bicubic for the SDR processing, why such a large discrepancy?Last edited by oniiz86; 20th Nov 2025 at 06:35.
Add where? I'm not a clairvoyant, please provide more details.
You reduced the resolution, probably to 1920x1080.I was also wondering if you could tell me why my HDR-SDR conversion video size is so small, the original video stream is 40GB and after the SDR conversion it's just 3GB in size, Encoder settings were CRF 23, Preset "medium", Tune "auto",Profile "auto" & bicubic for the SDR processing, why such a large discrepancy?
Are you satisfied with the quality? If so, why do you want a larger file?
The file size is determined by the compression factor, in this case CRF. Use 18 instead of 23 and you will get a larger file. -
Attached ..
Edit #1: added a json file of the source, might help in testing.
I can parse the source, read it, play it, & generate its Metadata just fine as shown
[Attachment 89812 - Click to enlarge]
@ProWo
v3.4.7.12 feedback
FYI, Scan for errors, batch scan, Right click on action column, CRASH
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
Parameter name: text
at System.Windows.Forms.Clipboard.SetText(String text, TextDataFormat format)
at clever_FFmpeg_GUI.Form38.DGV1_CellMouseClick(Objec t sender, DataGridViewCellMouseEventArgs e)
at System.Windows.Forms.DataGridView.OnCellMouseClick (DataGridViewCellMouseEventArgs e)
at System.Windows.Forms.DataGridView.OnMouseClick(Mou seEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
[Attachment 89808 - Click to enlarge]Last edited by videoAI; 20th Nov 2025 at 09:29.
@ ProWo
How about moving the button "Detect" and change the color?
[Attachment 89809 - Click to enlarge]
Tooltip Mux, Chapters:
A space is missing between text "activate, deactivate"
Tooltip Video encoding, HWA-decoding:
Suggested text:
Hardware-accelerated decoding options
none and auto work with scale and crop.
Other selections depend on the hardware
and may not work. -
Just tested with your file; the issue cannot be replicated here with me.
You can change only from 3 to 7, no way go get av1 as streams 4.
[Attachment 89810 - Click to enlarge] -
@ProWo I know you're not clairvoyant, this was @ingsoc's bug, sorry if I wasn't clear on that, I just noticed you hadn't addressed his post, I too am having trouble trying to replicate this bug actually, in the "Multiplex" screen if I click "add file" to add an audio track there isn't any "No" to select, it simply adds the audio track to the muxing grid, I guess @ingsoc should have provided clearer detailed steps on how to encounter this bug.
In regards to my HDR-SDR conversion, yes it is 1920 x 1080 resolution, I understand about the CRF setting, I typically do use a CRF of 18 but it generally doesn't offer that much more of a larger file size & takes considerably longer, this took me almost 3 hours using CRF of 23, I was merely curious as to why it is so much smaller after removing the HDR metadata & using the much more inefficient codec avc compared to hevc, I just thought me using the "medium" Preset and the "auto" settings for Tune & Profile played some part in the significantly smaller file size & was concerned about it being overly compressed, hopefully it will be just fine.
Found it, it happens with audio file only as source; if you convert it (convert or to batch), there is the option to add the output to the mux list or not.
If you choose to batch, then you can replicate the batch with other audio files. Your prior choice to add or not is replicated too and applied to the output files. Just tested, it works as aspected (add or not add to mux list).
The compression has nothing to do with the HDR to SDR conversion, it depends only from CRF and preset. Medium gives you a little smaller file than fast.In regards to my HDR-SDR conversion, yes it is 1920 x 1080 resolution, I understand about the CRF setting, I typically do use a CRF of 18 but it generally doesn't offer that much more of a larger file size & takes considerably longer, this took me almost 3 hours using CRF of 23, I was merely curious as to why it is so much smaller after removing the HDR metadata & using the much more inefficient codec avc compared to hevc, I just thought me using the "medium" Preset and the "auto" settings for Tune & Profile played some part in the significantly smaller file size & was concerned about it being overly compressed, hopefully it will be just fine.
@ProWo Oh okay thanks for that, regarding the Preset options, is that correct, as I thought Medium would result in a larger file size as it takes much longer to encode than Fast, well that is what it sounds like according to the FFmpeg documentation?
[Attachment 89816 - Click to enlarge] -
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 10:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 03:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 12:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 08:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 01:19
