Page 100 of 115
FirstFirst ... 50 90 98 99 100 101 102 110 ... LastLast
Results 2,971 to 3,000 of 3436
  1. Originally Posted by Findu View Post
    PLS. test the 25 fps sample. Check Interlace, uncheck it and IVTC appear.
    When you mux into mkv container, the info text "Attachments: No" disappear.
    It should be visible as long as the container is mkv. Regardless of whether the grid is still filled or empty after muxing, or if you add new files.
    Should all be fixed now. Update please.
  2. @ ProWo
    v3.4.7.06 feedback
    The IVTC visibility has been fixed.
    Ctrl a for the global title also works well.
    Wrong audio codec name has been fixed.
    Mux Attachments & Chapters behavior:
    The info text "Attachments: xyz" and "Chapters: xyz" is permanently visible. Good.
    If no stream is selected and you check only subtitle or audio streams, Container DAR does not appear.
    But it appear active or inactive when you change container.
    It also appear when you check a video stream.
    If no stream is selected and you check only subtitle streams, the Attachments button apper. Active for mkv container, inactive for all other containers. Good.
    But in that case, the Chapters button does not appear inactive. Is that intentional?
    I would show the inactive Chapters button.
    When you select an audio or video stream, the Attachments and the Chapters button appear, active or inactive. Good.
    When you creat chapters and go back to Multiplex and change container, the chapters get permanently deactivated when you jump over an container which does not support chapters. Which makes no sense as you can switch between mkv, mov and mp4, but not between or to 3gp or webm.
    Chapters also get permanently deactivated when you check any additional stream.
    "Chapters: Yes" switch between "Chapters: No" for containers which support or do not support chapters. Good.
    But "Attachmens: Image and/or Font" does not switch to "Attachmens: No" when you change container.
    The green info text for attachments/chapters should only be visible if there are available attachments/chapters and supported containers.
    If there are available attachments/chapters, you could use red or yellow colour and/or "No" to indicate unsupported containers.
    Audio encoding text "Channels (change. split. join)" still use periods instead of commas.
  3. @ProWo
    v3.4.7.06 feedback
    FYI, when no streams are selected, the batch button should not be visible.
    [Attachment 89648 - Click to enlarge]
    Originally Posted by sam12345 View Post
    Sometimes you need batch extraction if you have 22 episodes in a season
    For what?
  4. @ProWo
    v3.4.7.06 feedback
    Edit #1
    Same crash encountered again ..
    [Attachment 89668 - Click to enlarge]
    Validation [jpg]
    Drag n Drop any jpg file, attachment = yes, !! Crash !!
    ************** Exception Text **************
    System.IndexOutOfRangeException: Index was outside the bounds of the array.
    at clever_FFmpeg_GUI.Module1.Single_sdi()
    at clever_FFmpeg_GUI.Form1.After_input()
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    [Attachment 89649 - Click to enlarge]
  5. @ ProWo
    Since v3.4.7.02, the Cut page can not open the buggy file (link removed) any longer.
    You see a white or black app window that does not respond.
    EDIT:
    Further note: The mkv source file from the buggy cut can no longer be loaded into cut either.
    But if you remove all subtitles, it works.
  6. @ ProWo
    v3.4.7.06 feedback
    The new drop-down menu for the “Join” grid works well. Thank you for adding that.
    How about moving Join "Remove selected" next to "None/All"?
    This way, all grid-related elements are located above the grid, as in Multiplex.
    Join drop-down is using:
    Remove & delete jointed cuts, Remove jointed rows, Keep jointed rows.
    Is it intentional to use “jointed” instead of “joined”?
    Join is not only cut related. You can also join multiple pure audio files such as MP3 files or complete video files or clips.
    So it should better read "Remove & delete joined files".
    EDIT: But joining only delete cuts, no other files, so it is okay as it is!
  7. Edit #1
    it seems that clever can't cut the file when the number of streams exceeds 8.
    Clever loads file OK, but freezes [hangs] when cut button is clicked.
    Issue confirmed.
    ISO Base Media File Format (MP4, MOV, HEIF, etc.) with 00 00 00 24 66 74 79 70 Hex marker {ftyp = 24}
    @ ProWo
    Since v3.4.7.02, the Cut page can not open the buggy file https://forum.videohelp.com/attachment.php?attachmentid=89352&d=1761166746 any longer. You see a white or black app window that does not respond.
  8. @ ProWo
    Mux grid drop-down is using:
    Remove muxed streams, Clear grid after muxing.
    And the checkbox!
    How about removing the checkbox and use:
    Remove muxed streams, Clear grid after muxing, Keep muxed streams.
    The last entry has the same function as when the checkbox is not selected.
  9. AV1_QSV encoding fails. Won't even start.
    [Attachment 89650 - Click to enlarge]
  10. Originally Posted by ProWo View Post
    Originally Posted by oniiz86 View Post
    @ProWo That's disappointing to hear, has this issue been reported to the ffmpeg team, perhaps you could report it to them?
    No need to report. Have found a way. Update to the last nightly 3.4.7.06
    @ProWo I can happily confirm that you've fixed this issue with the latest nightly 3.4.7.06, for curiosity sake I tried the sample provided by @dave11 here https://limewire.com/d/Pj8TJ#GsrRBJirZ7 with the official v3.4.7 release & it was terribly out of sync along with the first subtitle line being omitted, don't know how you fixed it but thanks so very much again.
  11. @davidt1
    Does your hardware support AV1 hardware encoding?
    https://en.wikipedia.org/wiki/Intel_Quick_Sync_Video
  12. @ ProWo
    The "Unused processed files" page display the new Join grid dropdown!
    [Attachment 89653 - Click to enlarge]
  13. @ ProWo
    When you open Video encoding, the frame title is "Options".
    When you click "Fade" it is "Fade (seconds)".
    When you click "Close fade" it is "Various".
    Suggestion:
    The "Crop" button should always be active.
    Why not using the name "Options" instead of "Close fade" button?
    And once the setting remains, everyone can display whatever suits them best permanently, Options or Fade.
    How about swap Interlaced and IVTC?
    [Attachment 89664 - Click to enlarge]
  14. Originally Posted by Findu View Post
    @davidt1
    I don't know. 265_qsv works. CPU is i3-1220p.
  15. @davidt1
    Your Alder Lake does not support AV1 hardware encoding!
  16. @ ProWo
    The video encoders ffvhuff and huffyuv do not display any encoder settings.
  17. @ProWo
    Where is jobque of multiple files in multiplex like you have in mkv tool nix gui. Job Queue ? File are being pushed to job queue in multiplex and by running the job they are done in queueImage
    [Attachment 89675 - Click to enlarge]
    one by one.
  18. Originally Posted by sam12345 View Post
    Check the mux whole grid checkbox and click multiplex.
    But beware: hide all irrelevant streams before.
    [Attachment 89676 - Click to enlarge]
  19. @ProWo
    v3.4.7.07 feedback
    Please add a zero file check to all extracts, including srt.
    [Attachment 89677 - Click to enlarge]
    and possibly a color change to differentiate Mux From Batch ..
    [Attachment 89680 - Click to enlarge]
  20. Originally Posted by ProWo View Post
    Ok thanks and what's the procedure for chapters creation on scene detection in those multiple files which are placed in the multiplex grid ?
  21. Originally Posted by sam12345 View Post
    Chapters creation doesn't work in batch mode.
  22. Originally Posted by ProWo View Post
    Ok. Then what's the workaround to export them manually and encoding them by selecting as external file in batch mode.
  23. Originally Posted by sam12345 View Post
    No chapters in batch mode, unless they are already included in the source file; in that case, they are retained.
  24. Originally Posted by ProWo View Post
    Thanks for info. I will make them by my own batch method and then will bring them into multiplex.
  25. @ ProWo
    v3.4.7.07 feedback
    Thank you very much for the latest changes. All of the points mentioned have been corrected.
    However, I noticed the following:
    Mux behaviour:
    Attachment retain till you remove them or close Mux. Good for multible mkv muxing.
    But when you have attachment, you can not mux into other containers.
    Message: There was an error. The task failed.
    That surely happens only rarely. But can it be avoided?
    Chapters only get removed when the last video stream is unchecked or you close Mux or you deactivat chapters.
    Let's wait and see how this works in practice when the grid also contains other video streams.
    Join, Add files button does not load/display the selected file. The grid seams empty. And you get warning messages adding other files that way.
    Can the Join column title name "Filename" be left-aligned as with Mux?
  26. @ ProWo
    Old MPG recordings cause this error opening Video encoding and Cut.
    System.IndexOutOfRangeException: Der Index war außerhalb des Arraybereichs.
    bei clever_FFmpeg_GUI.Form6.Display()
    bei clever_FFmpeg_GUI.Form6.Form6_Load(Object sender, EventArgs e)
    bei System.Windows.Forms.Form.OnLoad(EventArgs e)
    bei System.Windows.Forms.Form.OnCreateControl()
    bei System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    bei System.Windows.Forms.Control.CreateControl()
    bei System.Windows.Forms.Control.WmShowWindow(Message& m)
    bei System.Windows.Forms.Control.WndProc(Message& m)
    bei System.Windows.Forms.Form.WmShowWindow(Message& m)
    bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Cause is that stream 0,0 is audio and 0,1 video.
    [Attachment 89681 - Click to enlarge]
    General
    Complete name : C:\xxx.MPG
    Format : MPEG-PS
    File size : 50.5 MiB
    Duration : 40 s 500 ms
    Overall bit rate : 10.5 Mb/s
    Frame rate : 30.000 FPS
    Video
    Format : MPEG Video
    Format version : Version 1
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : N=1
    Bit rate mode : Variable
    Bit rate : 10.2 Mb/s
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 1.105
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 49.2 MiB (97%)
    Audio
    Format : MPEG Audio
    Format profile : Layer 2
    Bit rate mode : Constant
    Bit rate : 64.0 kb/s
    Channel(s) : 1 channel
    Sampling rate : 32.0 kHz
    Frame rate : 27.778 FPS (1152 SPF)
    Stream size : 316 KiB (1%)
    EDIT:
    v3.4.6 has no problem with old MPG files.
  27. Originally Posted by Findu View Post
    Thx, will be fixed.
    Should work, I've tested that.
    Just tested, not here with me. It works as aspected.
    Will be done.
  28. >> Join, Add files button does not load/display the selected file. The grid seams empty. And you get warning messages adding other files that way.
    Further tests performed: for example, I cannot add any .webm file with VP9/Opus streams.
    EDIT:
    When you cut parts of webm files and let them be added to the join list, you get an error:
    System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
    bei clever_FFmpeg_GUI.Form9.Stream_analyze()
    bei clever_FFmpeg_GUI.Form9.Add_video()
    bei clever_FFmpeg_GUI.Form9.Add_cutted_files()
    bei clever_FFmpeg_GUI.Form9.Form9_Load(Object sender, EventArgs e)
    EDIT 2:
    v3.4.6 has no problem with webm files.
    Also some mkv files are affected.
  29. How about moving the Delete button above or next to the Quit button at the Unused processed files page?
    In most cases, you would select Delete or Quit, and you always come from the Main page clicking the Quit button. So there is less mouse movement to reach Delete.
    Could you please standardize the spacing between the individual options at the Video encoding page? Currently, the horizontal checkbox spacing is 8, 9, 10, and 11 pixels.
    [Attachment 89689 - Click to enlarge]
    Can you please reduce the width of the Encode and To batch button for Audio encoding and Extract streams, so that they are the same size as on the other pages?
  30. We just reached 3,000 posts ..
