Cant mux to mp4
Heya all,
Got an AVI I have encoded and need it as an .mp4
Tried with the latest version of cleverFFmpeg on Windows10 but it just outputs a zero file size mp4. I tested outputting to mkv and that works fine.
Anyone know whats wrong please as I have all 3 FFmpeg components in the same folder.
much thanks
				Results 151 to 180 of 2890
	Thanks ProWo...
 Format : AVI
 File size : 693 MiB
 Duration : 9 min 9 s
 Overall bit rate : 10.6 Mb/s
 Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
 Writing library : VirtualDubMod build 2540/release
 Video
 Format : AVC
 Format profile : High 4:4:4 Predictive@L4.1
 Format settings : CABAC / 3 Ref Frames
 Format settings, CABAC : Yes
 Format settings, Reference : 3 frames
 Codec ID : h264
 Bit rate : 9 000 kb/s
 Width : 1 920 pixels
 Height : 1 080 pixels
 Display aspect ratio : 16:9
 Frame rate : 30.000 FPS
 Color space : RGB
 Bit depth : 8 bits
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.145
 Stream size : 592 MiB (85%)
 Writing library : x264 core 152 r2851bm ba24899
 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=2 / lookahead_threads=2 / sliced_threads=1 / slices=2 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=abr / mbtree=0 / bitrate=9000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
 Color range : Full
 Matrix coefficients : Identity
 Audio
 Format : PCM
 Format settings : Little / Signed
 Codec ID : 1
 Bit rate mode : Constant
 Bit rate : 1 536 kb/s
 Channel(s) : 2 channels
 Sampling rate : 48.0 kHz
 Bit depth : 16 bits
 Stream size : 101 MiB (15%)
 Alignment : Aligned on interleaves
 Interleave, duration : 33 ms (1.00 video frame)
 Interleave, preload duratio : 500 ms
	Try with the newest beta
 https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.7z
 Load your avi, click on main, click multiplex, videotrack and audiotrack are already selected, click on target file, accept the proposed name, set mp4 as container, click multiplex. Done.Last edited by ProWo; 3rd Feb 2021 at 11:36.
	Hey ProWo,
 Thanks for the reply. Yeah, the original video muxed in your great program but with AAC audio does work and outputs an mp4.
 My problem is that extracting the audio and converting from PCM to AAC in audacity and then using that to mux is yet another step and I'm trying to minmize the workflow.
 I'm editing in Premiere PRO CS3 and using debugmode frameserver to serve the video to virtualdubmod and then Clever to mux into MP4.
 The problem is that the frameserver only serves PCM from premiere pro CS3.
 If anyone has any idea of a better workflow I'd appreciate it please.
 Much thanks
	Load your avi with pcm audio in clever Ffmpeg-GUI, click on Audio conversion, continue, set aac as output, click on convert. After this click on multiplex, your new created aac is already selected, click on video track, accept your avi, click on target file, accept the proposed name, set mp4 as container, click multiplex. Done!
	Much thanks ProWo. I'll certainly use that workflow. Thanks for the great app and all your help
	February 08, 2021 update to version 2.7.2.
 Fixed: Small bugs.
 Added: VP8 encoding, multiplex to webm.
 Added: Video merge (concat demuxer).
 Added: Support for Avisynth. A basic Avisynth script is created that you can customize, modify, test and then encode with the desired encoder.
 Removed: Inverse Telecine (IVTC), QTGMC deinterlacing. You can use your own scripts now.
 Improved: Many fine tunings.
	Buongiorno Prowo.
 Ti chiedevo se era possibile convertendo in VOB visualizzare quale dimensione avrebbe il file convertito, affinchè si possa regolare il bitrate fino a
 raggiungere 4.38 giga massima dimensione per fare un DVD. Per avere maggiore qualità video. Stessa cosa con M2TS per i Blu-Ray.
	TrueHD 7.1 to eac3 (5.1) conversion and 5.1 (6ch) and 7.1(8ch) to single wav's (pcm) conversion implemented in latest beta version (v2.7.3_05_Beta).
 Try it and report here.
	I am very happy to use your super clever FFmpeg-GUI , but it will be more powerful if i can use my own settings to adjust some of the basic ones . Cause i want to take full advantage of my hevc_qsv video processor like i do it using this commands directly to ffmpeg and the results are way better and with a speed of 4 to 6 using 90 % of my GPU and only 40 to 60 % of mu CPU
 -map 0 -c:v hevc_qsv -preset:v 1 -profile:v 0 -load_plugin hevc_hw -pix_fmt nv12 -global_quality 18 -b_strategy 1 -compression_level 7 -qcomp 0.80 -rdo 1 -g:v 250 -bf:v 3 -refs:v 5 -bitrate_limit 1 -vf "scale=1920:1080:flags=lanczos,format=nv12,yadif=2 " -aspect 1.7777 -color_primaries bt709 -color_trc bt709 -colorspace bt709 -c:a aac -b:a 128k -ac 2 -ar 48000
 hope it will be possible to use our personal script in your guide in the future ...
	My program is intentionally kept simple and designed for normal users so they don't lose track and (very likely) make mistakes and make wrong entries. This should also remain so. For this reason I will not implement any change to the command lines.
	i respect what you made with this GUI , it was just a suggestion , or maybe if it is possible to add the support for hevc_qsv as selected video preset or the possibility to use hardware acceleration where it is possible !!!
 Thanks again
	Hello, I was attempting to try to use this program to try to (easy as possible w FFMPEG) convert PAL to NTSC DVDs.
 I have this program in its own folder and downloaded the correct 4.3.2 FFMPEG (Windows 64) files.
 Everything goes fine upon starting, locating the FFMPEG folder, then I select a VTS VOB file to open, the program asks me if I would like to open the entire movie I select 'yes' again all seems fine until I try to 'Rip' the movie - at that point I get an 'Unhandled Exception' error. If you click continue nothing happens so it must be closed. I read through this thread where it is suggested to try to use the Beta build if this error show so I did but I get the same error.
	Is this a vts_99_9.vob file on a DVD (where 9 stands for numbers, g.e. vts_01_1.vob) or a single file on your harddisk? In this second case you must respond No. Last edited by ProWo; 25th Feb 2021 at 19:14.
	Thank you for the reply, yes this is a VTS__.VOB files.
 Specifically I tried 2 PAL unprotected DVDs that are on hard disk; I opened 'VTS_01_0' it is related to 'VTS_01_1,2,3 & 4' as the complete main movie - As I believed this to be ok I got the message if I would like to open the main movie for it and I believe I read that this is how to import a DVD for CleverFFMPEG here on VideoHelp.
 I could join all the .VOB from main movie into 1 file and\or 1 .mpg file if that is what is needed instead?
	Ok, some more testing for the above post. Originally I had placed the downloaded 4.3.2 FFMPEG files into the parent directory of 'cleverFFMPEG' and selected that as the source directory but for me anyway once I placed all those files inside the 'x64folder' it is all working ok now - I also used a 'joined.vob' just to be sure.
	I suggest to use a CCleaner before opening CleverFFmpeg, adding una tantum a new Include statement:
 Click the Options icon at left > Include button > Add > File >
 C:\Users\[User_Name]\AppData\Local\clever_FFmpeg_GUI\clever_FFmpeg_GUI .exe_Url_fokpm05yenrhb5scwzlvslghqdh03okg\1.0.0.0\ user.configLast edited by parvares; 27th Feb 2021 at 15:39.
	March 01, 2021 update to version 2.7.3.
 Fixed: Small bugs.
 Added: Multiplex to mov.
 Added: Profile selection (x264 and x265).
 Improved: Duration detection, Multiplex logic, many fine tunings.
	clever FFmpeg-GUI tells you the incompatible codec (video, audio or subtitle).
 Post a pic of the wmv stream detection here (see example below).Last edited by ProWo; 5th Mar 2021 at 05:04.
	I have a problem ripping a DVD, I point to VIDEO_TS, VTS_01_0 and VTS_01_1, none seem to work, I get an empty 0,00 kb rip file.
  GUI for ffmpeg x265 encoderBy david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 10:15
  New small GUI for FFmpegBy ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 03:06
  Best GUI for ffmpeg encodingBy usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 12:23
  GUI for FFMpeg amf?By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 08:45
  dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUIBy mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 01:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
