November 16, 2020 update to version 2.6.8.
Improved: Crop detection, AC3 6ch patch.
Fixed: Many small bugs, Target file/folder issue.
Added: HDR10 encoding (x265 only) with previous analysis. Prerequisite is a HDR10 source video.
Results 121 to 150 of 2656
Hi ProWo,
With reference to this post in another - old - thread: https://forum.videohelp.com/threads/389376-Changing-frame-rate-of-HEVC-MKVs#post2522592
I am not really a command-line hero, but I did manage to change the mentioned code, so I could change the framerate from a hevc video from 24 to 23.976 (24000/1001) fps.
Is it possible to change the framerate of an elementary videostream without recoding in your GUI? In the "Video Conversion" window of your tool I can set desired framerate, but I don't see an option how to disable re-encoding.
Another thing is that the ffmpeg.exe seems to output a mkv with the same container-framerate of the input: 24fps in my case. Can you confirm this is the case, or am I wrong here?
If so, wouldn't it make more sense to mux the output container with the same framerate as the elementary videostream?
Cheers -
Hello ProWo,
there is an audio problem for me (on Win7 32Bit): fps conversation with single audio file works fine, but if you use DRC at the same time, the file is cut off at the end about 30 Seconds (I think) missed against normal fps change. If drc and fps change option is used one by another, nothing will be cut at the end of file. It seems, cleverFFmpeg does not support trueHD core + mlp data as input. Your GUI crash. (Only 1+2 channel trueHD to wav was tested). Is there a chance to fix this and for trueHD as input...sometimes ?
Thank YouLast edited by Amiga; 1st Dec 2020 at 14:48. Reason: Typo
@ Amiga
trueHD encoding is supported in the newest beta.
Concerning trueHD+mlp as input, I will see what is doable.
Can you upload a small trueHD+mlp sample here? -
December 4, 2020 update to version 2.6.9.
Fixed: Many small bugs.
Added: Audio encode to trueHD, tune on x265 encoder.
Improved: Better information about the source file, when multiplexing, automatic takeover of previously edited video and audio streams, automatic stream control (only a video file can be used as a video source, only an audio file as an audio source and only a subtitle file as a subtitle source). -
I have analyzed the problem. This happens with files that have no duration info. In the latest beta this is solved by automatically copying the stream into an mp4 container (creating the missing duration info) and then reloading the mp4 automatically. This way further processing is possible without any problems.
The newest beta is temporarily unavailable until Monday December 14. I'm sorry.
If you have problems loading video files like here:
then try the newest beta.You find the link in the first post. -
Added Inverse Telecine (IVTC) for 29.97, 30, 59.94, 60 FPS Sources in the newest beta.
December 30, 2020 update to version 2.7.0.
Fixed: Small bugs.
Added: Audio delay info, Inverse Telecine (IVTC) for 29.97, 30, 59.94, 60 FPS Sources.
Improved: Many fine tunings. -
January 19, 2021 update to version 2.7.1.
Added: DnxHR encoding, multiplex to mfx.
Improved: Many fine tunings, new Windows 10 design, new logo, new icon. -
When modifying a video stream changing the fps value the length option does not have any effect
I confirm the bug; tomorrow i will investigate. -
A volte convertendo file in xvid o mkv con audio AC3 6 canali, in file VOB sempre con audio AC3 l'audio non è ben sincronizzato con il video.
La conversione lascia un'eventuale audio delay invariato. Controlla il file originale (prima della conversione) con Mediainfo. Se c'è un'audio delay prendine nota e fai il multiplexing con questo valore.
Nella versione recente clever FFmpeg-GUI ne tiene conto. -
OK. In un file mi dice ritardo audio 700 ms. Nell'altro file mi dice ritardo audio 523 ms. Devo inserire questi valori in audio delay?
Grazie. -
Grazie Prowo.
Perfetto.
Sempre gentile e disponible.
In bocca al lupo per il software. -
The bug has been fixed, both in the 2.7.1 release and in the latest beta. -
Added Video merge (concat demuxer) into the newest beta (experimental).
Test it and report bugs here.Last edited by ProWo; 23rd Jan 2021 at 04:42.
Added Avisynth support (only for the video track) into the newest beta (2.7.2_05_Beta).
On request, the loaded video will be imported into an Avisynth script. This script can then be customized and modified as desired. The script can then be tested with virtualdub. If it works as desired, it is encoded in clever FFmpeg-GUI with the desired codec.
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 09:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 02:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 11:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 07:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 00:19
