Page 3 of 75
FirstFirst 1 2 3 4 5 13 53 ... LastLast
Results 61 to 90 of 2224
    Jul 2020
    Ukraine
    July 31 2020 update to version 2.5.5.
    Improved: Many fine tunings.
    Fixed: minor bugs.
    👌 Thanks a lot! 👍
  2. Originally Posted by ProWo View Post
    Originally Posted by mazinz View Post
    Could you add an option to save a 5.1 as 6 separate waves?
    Use BeHappy for this.
    You could also try:
    ffmpeg -i in.ac3 -filter_complex "channelsplit=channel_layout=5.1[FL][FR][FC][LFE][BL][BR]" -map "[FL]" front_left.wav -map "[FR]" front_right.wav -map "[FC]" front_center.wav -map "[LFE]" lfe.wav -map "[BL]" back_left.wav -map "[BR]" back_right.wav
    Thanks! Had no idea something was made to truly replace BeSweet. Been using ea3c to extract since its a very short command, but I hate dealing with command lines and moving/renaming files on the pc to make the command easier
  3. Please add support for WebM.
  4. Support for webm as input is already available. Webm as output is not planned.
  5. August 06 2020 update to version 2.5.6.
    Improved: Detection of ffmpeg.exe, ffprobe.exe, ffplay.exe.
    Improved. Error handling.
    Fixed: minor bugs.
  6. August 18 2020 update to version 2.5.7.
    Improved: Deinterlacing (Yadif: frame/frame, field/frame, interlaced marked frames only).
    Added: Encode interlaced video as interlaced.
    Fixed: minor bugs.
  7. With version 2.6.0 (the newest beta) it is possible to use the QTGMC deinterlacer.
    You need an working Avisynth installation with the necessary plugins.
    Last edited by ProWo; 24th Aug 2020 at 04:21. Reason: Virtualdub is no longer needed
  8. August 24 2020 update to version 2.6.0.
    Changed: Deinterlacing.
    Improved: Error handling.
    Added: QTGMC deinterlacer (simple mode, but editable; You need an working Avisynth installation with the necessary plugins to use it).
    Fixed: Minor bugs.
  9. August 25 2020 update to version 2.6.1.
  10. August 31 2020 update to version 2.6.2.
    Added: New welcome frame at first start.
    Improved: Video analysis, Audio volume detection.
    Fixed: Some bugs.
  11. September 15 2020 update to version 2.6.3.
    Added: Audio output: flac, mp2, opus, vorbis
    Added: Video encoder mpeg2
    Added: Multiplex container: avi, mpg, ts, vob
    Improved: Video crop detection.
    Fixed: Some bugs.
  12. September 25 2020 update to version 2.6.4.
    Improved: Many small improvements.
    Fixed: Some bugs.
  13. Wonder if a tutorial on how to install the program is possible
  14. No install needed. Extract the exe for your pc (x64 or x86) and start it. Follow the indications. That's all.
  15. Ho dei problemi ad aprire il programma. Devo caricare le cartelle ffmpeg ?
    I'm having trouble opening the program. Do I need to upload the ffmpeg folders?
  16. Originally Posted by jopavirando View Post
    Scarica ffmpeg statico per il tuo sistema (x86 o x64) dal link che trovi sotto software. Estrai ffmpeg.exe, ffplay.exe e ffprobe.exe in una cartella di tuo piacere. Dopo esegui clever Ffmpeg-GUI. Al primo lancio ti chiede di navigare alla cartella con ffmpeg.exe. Dopo questo il programma funziona regolarmente.
  17. Thanks. I will.
    Grazie. Lo farō.
  18. Ottimo programma.
    Una volta che si č imparato ad usarlo č meraviglioso e veloce.
    Peccato per le poche possibilitā di conversione video.
  19. Originally Posted by jopavirando View Post
    Great program.
    Wonderful and fast.
    it would be nice to have even more video conversion possibilities
    like vob or m2ts etc .. to process DVDs and Bluray.
    VOB is already included. See at Multiplex, Container.
    Vob č giā compreso. Controlla nella sezione Multiplex, Container.
  20. Added support for m2ts container as output in the newest beta https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.7z
  21. DVD movie rip implemented (unprotected DVD's only). Point to the desired VOB and the entire movie will be ripped and imported.
    I'm curious whether you are simply concatenating the vob files of a group of vobs of whether there is some more logic behind it, which would allow the selection of a specific DVD title.
    Main draw back for me with ffmpeg is it's inability to handle DVDs in a proper way, so I'm curious to know whether you build a workaround for this.
  22. Image
    [Attachment 55359 - Click to enlarge]
    That selected source file contain a codec that is incompatible with the selected container-
    Please select another container or other source files.
    Quando uso multiplex mi esce questa scritta.
  23. Originally Posted by jopavirando View Post
    Che video e audio codici vuoi mettere nel m2ts? Per quanto mi risulta m2ts accetta soltanto come video mpeg2 o h264 (avc) e come audio ac3, dts e lpcm.
    Leggi: https://en.wikipedia.org/wiki/Comparison_of_video_container_formats
  24. Originally Posted by Selur View Post
    Before ffmpeg is used, the individual vobs are merged with type: (windows, commandline)
    g.e.
    type "fullpath\VTS_02_1.VOB" "fullpath\VTS_02_2.VOB" > output.vob
  25. ah okay, thanks for the info.
  26. I file VOB hanno il video in Mpeg2 e l'audio in Mpeg2 o ac3.
    Io volevo convertire un file avi (xvid + mp3) in file vob per elaborare un DVD.
  27. Originally Posted by jopavirando View Post
    Pertanto devi prima convertire il video in mpeg2 e l'audio in mp2 oppure ac3.
    (xvid + mp3) non va nel vob.
  28. Cosė ho fatto. Ho convertito l'audio in ac3, ma per il video il tuo programma non converte in mpeg2 ma in h262- mpeg2 e non me lo multiplexa nel container vob.
  29. Originally Posted by jopavirando View Post
    Il mpeg2 va bene cosė.
    Ho controllato ed ho trovato un bug che impedisce il multiplexing.
    E' stato corretto nell'ultimo beta. Provalo.
  30. Perfetto. Adesso funziona.
    Solo che il VOB per i DVD deve avere Mpeg2 a risoluzione 720 x 576 pixel per il sistema PAL
    e 720 x 480 per NTSC, mentre l'audio a 48000 hz.
