Newest beta (v3.0.9.05), online now.
Changed: cutting code again.
Added: ffmpeg version info on start screen.
Results 571 to 600 of 2645
Hi ProWo -
did you ever take a look at why the "play video" from the cut screen is not working?Last edited by davexnet; 21st Mar 2023 at 19:27.
Newest beta (v3.0.9.07), online now.
Changed: ffmpeg to FFmpeg, typos corrected, offset approach in cut section.
Fixed: Bugs in cut section.
Improved: Keyframe search in cut section.
Added: Keyframe info in cut section.
Recommended: Delete the following folder before the first start:
C:\Users\xxx\AppData\Local\clever_FFmpeg_GUI (where xxx=your user name on windows). -
I just tried the last beta (.07). The GUI is not stable. For example: if I start an audio conversion and after few seconds I stop it I got the message "Audio conversion aborted". But the GUI is still running (ffmpeg.exe). Even if I close the GUI ffmpeg.exe is still running (I must use Windows task managet to stop it). In the last stable version 3.0.9 this problem don't exist.
Found this is the Windows eventlog re: the error related to the inability to play the video from the cut screen
@davexnet
I am currently working on this error and have already found the reason for it.
Next week a new release will be released in which this bug is fixed. -
March 27, 2023 release version 3.1.0.
Added: Tooltips on many controls, keyframe info in cut section (with no video delay), LoudNorm Filter pass label, actual FFmpeg version info on start screen.
Changed: cutting section, cosmetics in many forms, HDR profile to level, video offset approach in cut section.
Fixed: typos, incorrect process termination, bug in DVD Rip, bugs in cut section.
Improved: command sequence for a faster start, keyframe search in cut section, First Start screen with detailed info now. -
Newest beta (v3.1.0.01), online now.
Added: Keep section open checkbox (for audio and video encoding section). -
Originally Posted by JustMe63 (from review)
Originally Posted by JustMe63 (from review) -
Newest beta (v3.1.0.02), online now.
Added: Keep section open checkbox (for cut section), switch background color (with color button on start screen). -
Hi ProWo,
Thank you so much for this amazing GUI tool!
Are there any plans for in the future to add or at least preserve Dolby Vision and HDR10+ metadata streams during the passthrough multiplex process to container .mp4 or m2ts/ts ?
Below an example of the result post passthrough multiplex process
Video
ID : Original source > MKV file
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : 36
Duration : 1 h 42 min
Bit rate : 24.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.123
Stream size : 17.5 GiB (94%)
Language : English
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 469 cd/m2
Maximum Frame-Average Light Level : 151 cd/m2
Audio
Menu ID : 1 (0x1)
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : 132
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 470 MiB (2%)
Language : English
Service kind : Complete Main
Video
ID : Post passthrough multiplex process - MP4 File
Format : HEVC
HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 24.3 Mb/s
Frame rate mode : Variable
Minimum frame rate : 23.564 FPS
Maximum frame rate : 24.390 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.122
Stream size : 17.4 GiB (97%)
Language : English
Menus : 3
mdhd_Duration : 6157150
Codec configuration box : hvcC
Audio
Format : E-AC-3
Codec ID : ec-3
Bit rate : 640 kb/s
Stream size : 470 MiB (3%)
Language : English
Default : Yes
Alternate group : 1
Menus : 3 -
new ver have unicode bug
D:\\kpop\\22撟廄\100\\230107.JTBC 2.GOLDEN DISC AWARDS 2023.(G)I-DLE INTRO+VILLAIN DIES+TOMBOY.1080p.H264.AAC-?寤?貐?ts",
is
D:\kpop\22年\100\230107.JTBC 2.GOLDEN DISC AWARDS 2023.(G)I-DLE INTRO+VILLAIN DIES+TOMBOY.1080p.H264.AAC-녹화병.ts
如需叫用 Just-In-Time (JIT) 偵錯的詳細資料,
請參閱本訊息結尾處 (而非這個對話方塊) 的資訊。
************** 例外狀況文字 **************
System.ArgumentException: 無法辨認逸出序列。 (3628): {
"streams": [
"index": 0,
"codec_name": "h264",
"codec_long_name": "H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10",
"profile": "High",
"codec_type": "video",
"codec_tag_string": "[27][0][0][0]",
"codec_tag": "0x001b",
"width": 1920,
"height": 1080,
"coded_width": 1920,
"coded_height": 1080,
"closed_captions": 0,
"film_grain": 0,
"has_b_frames": 2,
"sample_aspect_ratio": "1:1",
"display_aspect_ratio": "16:9",
"pix_fmt": "yuv420p",
"level": 42,
"color_range": "tv",
"color_space": "bt709",
"color_transfer": "bt709",
"color_primaries": "bt709",
"chroma_location": "left",
"field_order": "progressive",
"refs": 1,
"is_avc": "false",
"nal_length_size": "0",
"id": "0x100",
"r_frame_rate": "60/1",
"avg_frame_rate": "60/1",
"time_base": "1/90000",
"start_pts": 28501,
"start_time": "0.316678",
"duration_ts": 38494500,
"duration": "427.716667",
"bits_per_raw_sample": "8",
"extradata_size": 41,
"disposition": {
"default": 0,
"dub": 0,
"original": 0,
"comment": 0,
"lyrics": 0,
"karaoke": 0,
"forced": 0,
"hearing_impaired": 0,
"visual_impaired": 0,
"clean_effects": 0,
"attached_pic": 0,
"timed_thumbnails": 0,
"captions": 0,
"descriptions": 0,
"metadata": 0,
"dependent": 0,
"still_image": 0
"index": 1,
"codec_name": "aac",
"codec_long_name": "AAC (Advanced Audio Coding)",
"profile": "LC",
"codec_type": "audio",
"codec_tag_string": "[15][0][0][0]",
"codec_tag": "0x000f",
"sample_fmt": "fltp",
"sample_rate": "48000",
"channels": 2,
"channel_layout": "stereo",
"bits_per_sample": 0,
"initial_padding": 0,
"id": "0x101",
"r_frame_rate": "0/0",
"avg_frame_rate": "0/0",
"start_pts": 28501,
"duration_ts": 38494080,
"duration": "427.712000",
"bit_rate": "343879",
"disposition": {
"default": 0,
"dub": 0,
"original": 0,
"comment": 0,
"lyrics": 0,
"karaoke": 0,
"forced": 0,
"clean_effects": 0,
"attached_pic": 0,
"captions": 0,
"descriptions": 0,
"metadata": 0,
"dependent": 0,
"still_image": 0
"tags": {
"language": "eng"
"chapters": [
"format": {
"filename": "D:\\kpop\\22撟廄\100\\230107.JTBC 2.GOLDEN DISC AWARDS 2023.(G)I-DLE INTRO+VILLAIN DIES+TOMBOY.1080p.H264.AAC-?寤?貐?ts",
"nb_streams": 2,
"nb_programs": 1,
"format_name": "mpegts",
"format_long_name": "MPEG-TS (MPEG-2 Transport Stream)",
"size": "1007137432",
"bit_rate": "18837469",
"probe_score": 50
於 System.Web.Script.Serialization.JavaScriptObjectDe serializer.AppendCharToBuilder(Nullable`1 c, StringBuilder sb)
於 System.Web.Script.Serialization.JavaScriptObjectDe serializer.DeserializeString()
於 System.Web.Script.Serialization.JavaScriptObjectDe serializer.DeserializeInternal(Int32 depth)
於 System.Web.Script.Serialization.JavaScriptObjectDe serializer.DeserializeDictionary(Int32 depth)
於 System.Web.Script.Serialization.JavaScriptObjectDe serializer.BasicDeserialize(String input, Int32 depthLimit, JavaScriptSerializer serializer)
於 System.Web.Script.Serialization.JavaScriptSerializ er.Deserialize(JavaScriptSerializer serializer, String input, Type type, Int32 depthLimit)
於 System.Web.Script.Serialization.JavaScriptSerializ er.Deserialize[T](String input)
於 clever_FFmpeg_GUI.Module1.ShowVideoTracks()
於 clever_FFmpeg_GUI.Form2.Show_Tracks()
於 clever_FFmpeg_GUI.Form2.New_inputfile()
於 clever_FFmpeg_GUI.Form2.Button2_Click(Object sender, EventArgs e)
於 System.Windows.Forms.Control.OnClick(EventArgs e)
於 System.Windows.Forms.Button.OnClick(EventArgs e)
於 System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
於 System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
於 System.Windows.Forms.Control.WndProc(Message& m)
於 System.Windows.Forms.ButtonBase.WndProc(Message& m)
於 System.Windows.Forms.Button.WndProc(Message& m)
於 System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
於 System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
於 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** 已載入的組件 **************
mscorlib
組件版本: 4.0.0.0
Win32 版本: 4.8.4614.0 built by: NET48REL1LAST_B
程式碼庫: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
clever FFmpeg GUI
組件版本: 1.0.0.0
Win32 版本: 3.1.0.02
程式碼庫: file:///C:/Users/godmd5/Desktop/bbback/clever%20FFmpeg%20GUI.exe
Microsoft.VisualBasic
組件版本: 10.0.0.0
Win32 版本: 14.8.4084.0 built by: NET48REL1
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
組件版本: 4.0.0.0
Win32 版本: 4.8.4550.0 built by: NET48REL1LAST_C
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
組件版本: 4.0.0.0
Win32 版本: 4.8.4605.0 built by: NET48REL1LAST_C
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
組件版本: 4.0.0.0
Win32 版本: 4.8.4390.0 built by: NET48REL1LAST_C
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
組件版本: 4.0.0.0
Win32 版本: 4.8.4190.0 built by: NET48REL1LAST_B
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
組件版本: 4.0.0.0
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
組件版本: 4.0.0.0
Win32 版本: 4.8.4084.0 built by: NET48REL1
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
組件版本: 4.0.0.0
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Runtime.Remoting
組件版本: 4.0.0.0
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Web.Extensions
組件版本: 4.0.0.0
Win32 版本: 4.8.4494.0
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions/v4.0_4.0.0.0__31bf3856ad364e35/System.Web.Extensions.dll
System.Web
組件版本: 4.0.0.0
Win32 版本: 4.8.4494.0 built by: NET48REL1LAST_B
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Web.Extensions.resources
組件版本: 4.0.0.0
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Extensions.resources/v4.0_4.0.0.0_zh-Hant_31bf3856ad364e35/System.Web.Extensions.resources.dll
System.Windows.Forms.resources
組件版本: 4.0.0.0
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_zh-Hant_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
組件版本: 4.0.0.0
程式碼庫: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_zh-Hant_b77a5c561934e089/mscorlib.resources.dll
************** JIT 偵錯 **************
若要啟用 Just-In-Time (JIT) 偵錯功能,則必須在
此應用程式或電腦的 .config 檔案中,設定
system.windows.forms 區段內的 jitDebugging 值。
且該應用程式也必須在啟用偵錯的狀態下進行
編譯。
例如:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
當 JIT 偵錯功能啟用後,會將所有未處理的例外狀況
傳送給電腦上已註冊的 JIT 偵錯工具進行處
理,而不是使用這個對話方塊來處理。 -
Hi Prowo
I have a movie with AVC video track, DTS audio track and Italian UTF8 and PGS subtitles.
The program does not extract the subtitles for me.
Thank you. -
Hi guys!
Is there a possibility to encode Prores 4:2:2 10 bit ---> hevc/265 4:2:2 10bit with this program?
I have not managed to do this in my Handbrake.
Thanks for any advice!
Edit: sorry guys, i found it, i needed to update the program.Last edited by Mike_B; 7th Apr 2023 at 17:19.
- Do it is possible to add amr and 3gp audio encoder?
- Do it is possible to view and edit the command line generated before or run it?
- Do it is possible to do exe full portable avoiding setting in
%LOCALAPPDATA%\clever_FFmpeg_GUI\clever_FFmpeg_GUI .exe_Url_xxxx\1.0.0.0\user.config
and put user.config in exe folder?Last edited by xast; 11th Apr 2023 at 10:25.
Newest beta (v3.1.0.03), online now.
Fixed: missing variable reset bug.
Changed: seeking approach in cut section, cosmetics on many forms.
Added: Virtualdub2 as viewer in cut section. -
Question - should the frame accurate cut work if the H.264 source is I and P frames only ?
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 09:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 02:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 11:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 07:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 00:19
