06 May 2020 update to version 2.3.9.
The crash without file selection is corrected.
The command line can be displayed.
Forms have changed from Font to DPI
Results 31 to 60 of 3065
Hello!
I recently tried to split the m4b file into chapters. You know that for this there are several scripts written in bash, piton and powershall. It would be nice to include one of them in your program for future use. And not only for m4a or m4b files, but also for all files with chapters. You may notice that I'm focusing on chapters, because there really aren't enough programs that can split audio and video files into chapters. For example, mkvtoolnix can, but only mkv files, AAX Audio Converter can, but only AAX files, and no program can split m4a \ b files into chapters. -
25 May 2020 update to version 2.4.2.
Fixed some bugs.
Many small improvements. -
08 June 2020 update to version 2.4.5.
Added: mp3 output in audio conversion.
Fixed some bugs. -
June 30 2020 update to version 2.4.8.
Added: Audio conversion section: You can set 2 channels output.
Added: Multiplex section: Checkbox to remove language code from Videostream.
Many cosmetic and code fine tunings. -
If someone has troubles with the program, he can try the latest beta version:
https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.7z
NB. Is regularly updatedLast edited by ProWo; 6th Jul 2020 at 08:44.
I think this GUI is way better, no offence but being using it for few days it works like a champ:
https://forum.videohelp.com/threads/386028-FFmpeg-Batch-for-Windows -
https://files.videohelp.com/u/292773...newest_beta.7z
doesn't work that good. -
The link in your first post doesn't work.
https://files.videohelp.com/u/292773...newest_beta.7z (404 error) -
July 14 2020 update to version 2.5.2.
Added: DVD movie rip implemented (unprotected DVD's only). Point to the desired VTS and the entire movie will be ripped and imported.
Read the HowTo.txt -
July 16 2020 update to version 2.5.3.
Fixed: A major bug when loading videos without duration information.
Hi, prowo,
can i change the skin of your software to black , so i could see easily, a kind of dark mode. given review on download page -
Hi, you could add black skin with yellow letters that would help easing eye strain , instead of whilte. it is only my request
when the downloaded file has opus audio, it accepts and processes, but i do not find the created mp3 file in the source folder.
is here anything missing on my part.Last edited by jraju; 18th Jul 2020 at 10:07. Reason: just add something
Hi, prowo, good program, but if I want to change the FPS of an audio file (DTS core, DTS-HD) there is only a choice of AAC, MP3, AС3 or WAV format, but I don't need quality loss. If you encode to WAV format and back to DTS, there will be quality loss as well. Thanks.
Implemented in the newest beta. Try it.
https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.7z -
July 27 2020 update to version 2.5.4.
Added: Audio Stream Language Info on Audio conversion.
Added: Audio DTS Output.
Improved: Video Stream Interlacing Detection.
Fixed: minor bugs. -
Use BeHappy for this.
You could also try:
ffmpeg -i in.ac3 -filter_complex "channelsplit=channel_layout=5.1[FL][FR][FC][LFE][BL][BR]" -map "[FL]" front_left.wav -map "[FR]" front_right.wav -map "[FC]" front_center.wav -map "[LFE]" lfe.wav -map "[BL]" back_left.wav -map "[BR]" back_right.wav -
Which video file, which error? Have you read the HowTo.txt?Originally Posted by Zero-11
Just by the way; a rating Value for money: 1/10 for a free program says a lot about the person who gave the rating. -
July 31 2020 update to version 2.5.5.
Improved: Many fine tunings.
Fixed: minor bugs.
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 10:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 03:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 12:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 08:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 01:19
Corrected now. Thank You.
