Results 271 to 300 of 3344
September 28, 2021 update to version 2.8.8.
Fixed: A major bug in multiplex mapping,
pcm codec selection not executed,
bug in audio length & pitch change.
Solved: Missing pkt_pts_time in newer ffprobe releases.
Improved: Multiplex section.Last edited by ProWo; 18th Oct 2021 at 15:03. Reason: typo
You're right. This annoying typo happened unfortunately and should be fixed now. Thanks for the hint.Originally Posted by Jack(review)
- How do you mux the audio with the video in this?
- And there any differences between the x86 and x64 version that should know about? Or are they both the same?
For muxing: Load your video, click main, click multiplexing, the videostream (and other streams into the main video) is already loaded.
If you want other streams, click on the Add button and add them.
Make your changes on the single streams (ge language tag). Then select the output container you want (ge mkv, mp4, avi).
If you want, you can change the output filename. Finally click multiplex.
Choose the version for you system. If your Windows os is 64bit than choose x64, otherwise choose x86.
The ffmpeg binaries have to be the same (x64 ffmpeg for x64 clever Ffmpeg-GUI).
x64 is recommed. -
October 26, 2021 update to version 2.8.9.
Fixed: 0file bug, delete language tag bug, add files bug in multiplex section, aborted check bug
Added: Ability to extract raw h264/h265 videostreams, mux dvb_subtitle into m2ts
Removed: Mux hdmv_pgs_subtitle into m2ts, mkv, ts (not working)
Changed: Output filenames, keyframe check from I to IDR -
https://www.virustotal.com/gui/file/e4de1f3affe2c2981c3d8692bfff74fd59c946babc032b924e...98c-1635242140
Several Gen:Variant.Bulz.790615 warnings -
@Baldrick
False alarm. No idea where the scanner detects the signatures.
Clever FFmpeg-GUI has no connections to the Internet (except the embedded download links for ffmpeg), nor to the host system itself, except the .net framework.
The result of the uncompressed exe (64bit):
https://www.virustotal.com/gui/file/0b033c30563a37303b695ff6494df5ee6bdd0d14bb0c26c12f...8fdf?nocache=1 -
It's false alarm. Get it with another browser here:
https://files.videohelp.com/u/292773/clever_ffmpeg_gui_289.7z -
OK. Grazie. Lo devo inserire da Vlc.
Ma non esiste un altro modp per inserire i sottotitoli in un contenitore
come Vob o M2ts per elabprare i Dvd e Blu ray senza ricorrere a dei software di authoring a pagamento?
E la spunta nella casella "forced" con quale formato di multiplex va usata?
Grazie. -
November 26, 2021 update to version 2.9.0.
Fixed: minor bug (29.97fps recognition), bug in default+forced tags in subtitles, bug in subtitle track test
Added: Multiplex to 3gp, Ability to show source info (clicking on source file)
Improved: Change language tag
Changed: .net 4.6 to 4.8 -
December 21, 2021 update to version 2.9.1.
Fixed: ac3 decoder drc on/off, minor bugs on info labels, bug in cut section for source without videostream.
Added: ac3 mux in mpg, missing video codec and video language info,
set default audiostream tag, selected streams counter and sum in multiplex section, homepage link. -
December 30, 2021, added: encode to AV1, with libaom-av1 (AOMedia), libsvtav1 (Intel x86-64) and librav1e (Xiph) support, in the newest beta 2.9.1.04.
https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.7z
Is unfortunately incredibly slow (except the Intel x86-64 version).
Try it. -
Very nice&useful GUI @ProWo !
As already suggested to Chris Griffith (the FastFlix author), what about adding "features" from GMJCZP's Arsenal ?
Hope that inspires ! -
OK, but how to add Coding to DVD with FFMPEG script ?
(nota: sei italiano/a ?) -
Come ho già scritto, carica il tuo video in clever FFmpeg-GUI, clicca main, clicca convert video stream, clicca continue (o fai i crop desiderati), spilla Avisynth, clicca create script, clicca edit script, ti fa vedere lo script, qui aggiungi in fondo il code di 'coding to dvd with ffmpeg'. Ovviamente lo script dev'essere consistente e logico, ma se già usi avisynth sai come dev'essere composto un script. Infine puoi testare lo script cliccando Test script, che ti apre virtualdub2, indicizza il video e te lo fa vedere. Se lo script è consistente e funziona, allora puoi convertirlo con il codec selezionato, cliccanco convert.
Alla tua seconda domanda: No, non sono italiano, ma me la cavo abbastanza con la lingua. -
Hello ProWo,there might be problems with pcm (wav) converting. Only 20 bytes written, thats all. In rare situations it works. Or that is my fault with 32 Bit Windows. No luck with newest ffmpeg 32 Bit builds and older Versions from GitHub. Other Codecs seems to work fine. (Related AC3/DTS convert to WAV. FLAC works great, but your gui will not read FLAC -(
Just tested it. Everything works as desired, conversion to pcm (wav) in 16 and 24 bit, from wav to flac, from flac to wav, from flac to ac3, from wav to ac3 and so on.
I use a 64bit computer, so I can't test the 32bit variant.
Try this ffmpeg build:
https://www.videohelp.com/download/ffmpeg-4.3.1-win32-static.zip -
Thank you for your test. I have no idea, what happens. So i did test some clever ffmpeg-gui 32 bit versions with several ffmpeg versions, including 4.3.1 as you suggested. This results in the following experience: Version 2.8.6/32 Bit was the last version, that handles wav (pcm) conversion absolut correctly. All versions after 2.8.6/32 Bit can't handle wav (pcm) conversion on my 32 Bit PC, no matter wich ffmpeg version is used. But all versions can handle other audio codecs (like trueHD, aac...and so on). For me as a simple user this is a bit crazy, because other codecs are much more complicated to encode. No problem, I will use 2.8.6/32 Bit for ac3/dts to pcm encoding. I am curious whether the problem will solve itself in the future...
Thanks a lot for the important and useful clever ffmpeg-gui. -
@Amiga
Try to convert this sample
with this codeCode:ffmpeg.exe -i "sample.mp2" -c:a pcm_s16le -ac 2 -ar 48000 "sample.wav"
@ProWo
Thanks for the sample. Your sample work as it should. A second ac3 sample work too. Please notice the logs from console:
[Attachment 62951 - Click to enlarge] and
[Attachment 62952 - Click to enlarge]
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 15Last Post: 11th May 2025, 10:15 -
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 29Last Post: 24th Feb 2024, 03:06 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 12:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 08:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 01:19
