Just an information: the last ffmpeg x86 build has been releasead on April 2023 (3 months ago), right? Is it correct ? Am I missing something ?
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
Results 661 to 690 of 757
The latest is from May, 29.
https://github.com/sudo-nautilus/FFmpeg-Builds-Win32/releases/download/latest/ffmpeg-m...gpl-shared.zip -
Thanks ProWo. Is the link on GUI interface outdated (the last build is from April) ?
https://venomissimo.notion.site/venomissimo/FFmpeg-86-3b484982448b485eaed6b687b2f67047 -
Newest beta (v3.1.3.03), online now.
Added: Set bitdepth with HDR10 to SDR, set encoding matrix with mpeg2, mjpeg muxing to asf/avi/mkv/mp4.
Improved: mpeg1 and mpeg2 encoding quality, HDR recognition.
Fixed: Bug in color_transfer recognition. -
Hi, prowo, could we be able to normalize the video take of television and other media,where audio captures will be low. By nature, when we take the video, audio is also captured but not exactly as it is derived from the original source.
When normally we open source, this shows video and audio , but will normalize work in these kind of audios.
Because, the video sound is slow when you take a video
do i miss something.
i do not put it in forum posts as some do not understand the need of the user or capture the query mode.
Moreover, if i do not update correctly,the program never opens . Thanks -
Hi jraju,
Load your video in clever FFmpeg-GUI, click main, click encode audiostream, select the audio stream (if there are several), click volume detection. When that is finished, click got to the encoder.
To adjust the audio volume, there are now several options.
1) Accept the detected value (in volume dB) and ckick encode.
2) If this is not enough, check the LoudNorm checkbox, 1 pass is suggested, accept that, click OK and click encode.
3) If this is still not enough, check the checkbox DynAudNorm instead of LoudNorm and click encode.
What exactly do you mean by that? -
Newest beta (v3.1.3.04), online now.
Added: change video properties (contrast, brightness,saturation, croma), preview video with selected filters.
Improved: after volume detection goes directly to the encoder, video filter chain handling.
Changed: cut section. -
Newest beta (v3.1.3.05), online now.
Added: eia_608, eia_708,hdmv_pgs_subtitle extraction, eia_608, eia_708 conversion, eia_608, eia_708, hdmv_pgs_subtitle burn in, preview for HDR10 to SDR and LUT's.
Fixed: bug in subtitle selection for burn in, bug in HDR/SDR selection with HDR10 source, tooltip in HDR10 settings. -
September 1, 2023 release version 3.1.4.
Fixed: encode button visible after encoding start in audioencoding, automatic 8 Bit bitdepth selection for videostreams without bitdepth info, HDR to SDR with h265 bug, Bug in color_transfer recognition, bug in subtitle selection for burn in, bug in HDR/SDR selection with HDR10 source, tooltip in HDR10 settings.
Changed: start screen again, loading hevc video without scan type info presuming progressive, audiostream selection with multiple audiostreams, filterchain in videoencoding, HDR to SDR encoding with all avaiable videocodecs (not only hevc), moved HDR settings to various, cut section.
Improved: mpeg1 and mpeg2 encoding quality, HDR recognition, after volume detection goes directly to the encoder, video filter chain handling.
Added: automatic DAR selection with DVD resolutions, dvd_subtitle (vobsub) mux to mp4, Set bitdepth with HDR10 to SDR, set encoding matrix with mpeg2, mjpeg muxing to asf/avi/mkv/mp4, change video properties (contrast, brightness,saturation, croma), preview video with selected filters, eia_608, eia_708,hdmv_pgs_subtitle extraction, eia_608, eia_708 conversion, eia_608, eia_708, hdmv_pgs_subtitle burn in, preview for HDR10 to SDR and LUT's. -
Hi ProWo,
In the option Encode, Audio Stream, DynAudNorm, would it be possible to add the option "coupling, n"?
This is because many times the 6 channels are very unbalanced and even using DynAudNorm some channels have low levels.
Thanks -
Newest beta (v3.1.4.01), online now.
Added: coupling switch for DynAudNorm (on request by JOAOP). -
Newest beta (v3.1.4.02), online now.
Improved: dynaudnorm settings, Inverse telecine.
Added: indexing videostream for keyframe cutting, v210 codec can be muxed now in admitted containers.
Fixed: missing variable reset.
Changed: whole cut code. -
great little software!
i would like to suggest some filters to consider:
https://ffmpeg.org/ffmpeg-filters.html#speechnorm
https://ffmpeg.org/ffmpeg-filters.html#compand
(some discussion on these filters here: https://www.reddit.com/r/ffmpeg/comments/15kiucp/ffmpeg_how_to_add_dialog_normalization_to_ac3_file/)
since "compand" doesn't require re-encoding, i'm not sure if it's possible to include certain presets/values oriented on dialogue normalization. -
Newest beta (v3.1.4.03), online now.
Changed: audio filter handling, video cut code again.
Added: speechnorm filter, compand filter, choice to handle missing audio channels (omit, downmix) if audio channels reduction occours.Last edited by ProWo; 29th Sep 2023 at 12:13.
i'm not seeing this option (selecting 5.1 for a 7.1 source still shows the same mapping setting with 2 channels greyed out).
unless, selecting 7.1 option for a 7.1 source produces a 5.1 encode with those channels mapped automatically?
edit: tried encoding a 7.1 source into eac3 with 7.1 channels selected and it produced a 5.1 file. is this the correct outcome?Last edited by mannequin80; 30th Sep 2023 at 10:19.
If you use Remap, this function is not available, because you assign the individual channels manually. Therefore you can only assign 6 channels out of 8.
If you don't use remap, the option is offered before encoding.
I'll have to check that out.Last edited by ProWo; 30th Sep 2023 at 10:53.
Newest beta (v3.1.4.04), online now.
Fixed: Bug in 2nd pass on loudnorm filter, removed 7.1 channels option for eac3 encoder. -
Thanks again for excellent software!
One feature request: add more AAC options such as type of bitrate encoding (TVBR, CVBR, ABR, CBR).
One suggestion: add ability to view command line parameters being used. Would be helpful for anyone interested in exact commands being used after deciding on all the options in the GUI.
New small GUI for FFmpeg
By ProWo in forum Video ConversionReplies: 27Last Post: 24th Feb 2021, 08:18 -
Best GUI for ffmpeg encoding
By usta in forum Video ConversionReplies: 25Last Post: 17th Jan 2019, 12:23 -
GUI for FFMpeg amf?
By Micky in forum Video ConversionReplies: 0Last Post: 14th Jan 2018, 08:45 -
dmMediaEncoder v1.8.0 - crossplatform FFMPEG GUI
By mdalacu in forum Video ConversionReplies: 38Last Post: 29th Sep 2015, 01:19 -
GUI for ffmpeg x265 encoder
By david55 in forum Video ConversionReplies: 13Last Post: 25th Jul 2015, 01:13
