Hello.
I was recentely dumping miniDV tapes with two audio tracks, Scenalyzer outputs stereo AVI and second audio track as WAV, so I thought of using ffmpeg to merge them:
And theCode:ffmpeg -i input_video_with_audio.avi -i new_audio.wav -map 0 -map 1 -codec copy output_video.avisomehow changes the interlaced video type to progressive, as inspected in mediainfo.Code:-codec copy
Below the info from the original file:
And here is the output:Code:Video ID : 0 Format : DV Commercial name : DVCPRO Codec ID : dvsd Codec ID/Hint : Sony Duration : 7 min 10 s Bit rate mode : Constant Bit rate : 24.4 Mb/s Encoded bit rate : 28.8 Mb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Time code of first frame : 00:00:00:01 Time code source : Subcode time code Stream size : 1.44 GiB (96%) Encoding settings : wb mode= / white balance= / fcm=auto focus
Why is the scan type changed?Code:Video ID : 0 Format : DV Commercial name : DVCPRO Codec ID : dvsd Codec ID/Hint : Sony Duration : 7 min 10 s Bit rate mode : Constant Bit rate : 24.4 Mb/s Encoded bit rate : 28.8 Mb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Original scan type : Interlaced Original scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Time code of first frame : 00:00:00:01 Time code source : Subcode time code Stream size : 1.44 GiB (93%) Encoding settings : wb mode= / white balance= / fcm=auto focus
And how to get ffmpeg to simply add the second audio stream without changing any parameter of the video and audio streams?
Results 1 to 13 of 13
haven't done this in a while, but iirc you need to add:
for bff signalingCode:-top 0
see: https://www.ffmpeg.org/ffmpeg-all.html#Advanced-Video-optionusers currently on my ignore list: deadrats, Stears555, marcorocchini -
thank you, but that didn't change anything.
While i'm at it maybe i should change sample aspect ratio fro default and incorrect 16:15 to proper 128/117, ut i'd need to go through all the other tapes as well...
From what i can see it affects the input video:
https://www.ffmpeg.org/ffmpeg-all.html#toc-Options-1
I think I'm one step closer, the optionmight be the solution, but for bottom field first there is a switch where bff is encoded first and tff is encoded first, i would assume it's the bottom showed and encoded first, right?Code:field_order field_order (video)
you can try if:
helps.Code:-flags +ildct+ilme
Cu Selur
Ps.: if you share a short sample of the source I can reproduce and try to check the flags myself.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Not an option. like I said, it must be the one I mentioned before, but the question is it's either bottom shown first and encoded first, or bottom whoed first, but top encoded first. And I cannot find any information which one is encoded first in DV specification.Code:
Filtergraph ''interlace=scan=tff:lowpass=complex'' was defined for video output stream 0:0 but codec copy was selected. Filtering and streamcopy cannot be used together.
I found the solution. It's the avi muxer from FFmpeg that sets the progressive flag. You have to use the mkv muxer instead like this:
ffmpeg -i input_video_with_audio.avi -i new_audio.wav -map 0 -map 1 -codec copy output_video.mkv
Then use mkvcleaver to extract the avi file. -
I compared the output of a DV AVI created by VirtualDub, AviDemux, and ffmpeg. MediaInfo reports
for the VirtualDub, AviDemux, and ffmpeg with -field_order bb videos. But with -field_order tb it reports:Code:Scan type : Interlaced Scan order : Bottom Field First
All the files played properly in the media players I tried. Even ffmpeg created videos with -field_order tt and bt (which are definitely wrong). The players were all set up to display 30i video at 59.94 fps.Code:Scan type : Interlaced Scan order : Top Field First Original scan order : Bottom Field First
I looked a little more closely at what ffmpeg does that's different than the other programs: Ffmpeg adds an ODML 2.0 vprp chunk with the field order flags. The other editors don't. This is the first time I've seen an AVI file with a vprp chunk. I don't think many programs create or pay any attention to vprp chunks.
By the way, to get ffmpeg to include all audio streams when it remuxes use -map 0. If your second audio stream is from a second source file use -map file:stream to indicate which streams you want to include. Something like -map 0:0 -map 0:1 -map 1:1 (include streams 0 and 1 of the first input file, stream 1 of the second input file).
https://github.com/stoyanovgeorge/ffmpeg/wiki/How-to-Map-Streams-in-FFMPEG -
This answers my question, so the bb switch is correct, and the tb in tis case is incorrect.
In my case -map 0 -map 1 will suffice, The first file is DV+audio, the othwe is second stereo track in separate WAV, so no need to specify streams inside files, as i want to mx everything together.
Thank you for the information, so the whole comman will look like this:
I've just oticed that in media info in the general info there is a new line:Code:ffmpeg -i input_video_with_audio.avi -i new_audio.wav -map 0 -map 1 -codec copy -field_order bb output_video.avi
What is it and why it suddenly appears is beyond me. Any switch to disable it?Code:Format profile : OpenDML
Mixed progressive and interlaced source
By gamjerr in forum Video ConversionReplies: 2Last Post: 4th May 2018, 21:59 -
interlaced or progressive scan
By devdev in forum Video ConversionReplies: 8Last Post: 11th Nov 2017, 12:09 -
Interlaced Content to Progressive
By TE16 in forum Video ConversionReplies: 2Last Post: 14th Jan 2017, 16:38 -
interlaced or progressive: where are the flags?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 30th Mar 2016, 11:23 -
how do i use ffmpeg to see if a video is interlaced or progressive ??
By oduodui in forum EditingReplies: 3Last Post: 30th Jun 2015, 06:33
