Hi
Please suggestion to me a converter app or a solution for convert any video format to AVi Container with DV Video format.
(AVi as container and DV as video CODEC)
Like this example:
Format : AVI
Commercial name : DV
Format profile : OpenDML
File size : 4.43 GiB
Duration : 21 min 22 s
Overall bit rate mode : Constant
Overall bit rate : 29.7 Mb/s
Video
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Bit rate mode : Constant
Bit rate : 24.4 Mb/s
Encoded bit rate : 28.8 Mb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:00:00:00
Time code source : Subcode time code
Stream size : 4.30 GiB (97%)
this file converted(Rendered) with Magix Vegas but video bitrate very high and file size 4 time greater than the original vob file.
DV uses a fixed bitrate so any video you convert to DV will end up around 4 GB per 20 minutes, or 200 MB/min -- no matter what program you use. Why do you want to convert everything to DV? You're only going to reduce the quality.
thanks man
i'm using Nuendo (version 4.3.0 Build 371) on win 7 64bit for sound mixing a short film.
Nuendo has 3 optional video playback method:
1.DirectShow
2.DirectX
3.QuickTime
best option for me import DV-AVi Video and use DirectShow to play video.
other options (2.DirectX 3.QuickTime) and other format have lag,non-sync,low quality and puse video during the mixing.
my pc motherboard and video card info:
motherboard:Intel DH57DD
video card:Intel HD Graphics-Intel Havendale/Clarkdale Processor - Integrated Graphics Controller -
sorenson squeeze
XmediaRecode
TotalCode studio
VirtualDubModLast edited by zizouillette; 27th Mar 2020 at 12:41.
Best codec and container format for specific need (home video)
By nckhrs in forum Video ConversionReplies: 35Last Post: 30th Dec 2018, 00:20 -
Batch convert animated GIFs to video? (Any format: AVI, MP4, etc.)
By vidyanoob in forum Video ConversionReplies: 3Last Post: 31st May 2018, 09:04 -
Choosing a container, file format, etc. that includes metadata & subtitles?
By jmthomas in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2017, 14:11 -
AVI File with Codec: MPEG-4 Video (FMP4) and Format: Planar 4:2:0 YUV
By MediaKorbi in forum Video ConversionReplies: 7Last Post: 13th Feb 2017, 03:29 -
Can a video Blu-Ray be created with lots of DVD-format video files?
By Calidore in forum Newbie / General discussionsReplies: 15Last Post: 17th Nov 2016, 08:40
