So I finally spent 17Euros on the latest DivX Pro, my last owned version being 6.8.2. I went to encode my latest creation from Lagarith to Divx, but in my codec list in VirtualDub I still have DivX 6.8.2, no sign of any DivX 10. Is this correct ?
I tried using the DivX converter, but it seems to have only presets available, no unconstrained bit rate/frame rate options ?
Results 1 to 14 of 14
I just installed the 64bit version of VirtualDub, no DivX codecs showing up
"Programmers are human-shaped machines that transform alcohol into bugs."
Greetings
, Earthlings ...
I'm back ... after an absence of half-a-dozen or so years ...
I've (also) been wondering about NOT seeing the DivX codec
show up (anymore) in VirtualDub options ...
Previously I was using WinXPx86 ...
Now I have W7x64 & W10x64 ...
I have my previous/old(er) x86 VirtualDub "installs"
and also the x64 VirtualDub release ...
Could/Would someone "elaborate" for (not only) my benefit
what this thread implies about DivX & VirtualDub
Virtualdub probably looking for VFW codecs. The older versions of Divx/Xvid certainly installed one, but I don't know
about your particular release. Look in the registry to see if you can see them.
https://forum.videohelp.com/threads/389362-batch-that-verify-if-a-VFW-codec-is-install...ws#post2522494 -
Thanx ... for the reply
This WeekEnd I found/made time to "checkout" VirtualDub2 ...
When/While poking around,
I came across the following (under Xvid Options):
[Attachment 60143 - Click to enlarge]
which seems to be an INDIRECT way (for me) to encode with the DivX codec ???
Perhaps the DivX-VFWcodec only installs with the Pro package ???
Interested in "hearing" any thoughts/insights about this
Indirect yes, you will be using the Xvid codec but encoding to DivX standard for devices.
Which may be better, since the latest Xvid is "newer" than the last .avi type DivX codec, if this is what you wanted.
Any reason why DivX though?Last edited by blud7; 9th Aug 2021 at 04:00.
Installing Divx compression codec in Virtualdub
By jseo13579 in forum EditingReplies: 0Last Post: 20th Oct 2018, 07:59 -
advice - latest (best) audio codec to use in MP4 files for chromecast
By hydra3333 in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2016, 19:22 -
can Virtualdub use a 64 bit directshow codec?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2015, 03:48 -
what is the latest ffmpeg input driver 64 bit for virtualdub-64bit?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2015, 16:24 -
Virtualdub ERROR CODE 512 ACMERR_NOTPOSSIBLE - DivX to Xvid in Virtualdub
By kurtky in forum Video ConversionReplies: 6Last Post: 4th May 2015, 13:26
