I've bought a cheapy easycap off e-bay, connected PC to my ancient Technika vhs/dvd player and for an hour it worked reasonably well having connected the audio and video sockets using equally ancient audio cables. However changed video tape and now all I can get is a sort of four frame split image-thinking my tapes were damaging the head on the player or the tracking was out I tried the DVD output and that has the same issue. Have I blown the output of my technika with excessive resistance using the audio leads or couold it be another issue?
The answer to the Q. you raised in your topic title is a simple NO !
But to test if your cables are at fault you change them and connect direct to a tv. But a cheap easycrap could still be the problem if all works fine at that point.
Capturing Scart with VHS/DVD combo player
By SJ-M- in forum Capturing and VCRReplies: 29Last Post: 19th Feb 2020, 11:40 -
Some questions about vhs tapes, VCRs & damage caused between them.
By streetsofrage47 in forum MediaReplies: 17Last Post: 17th Nov 2019, 17:54 -
Which is easier to edit? DVD MPEG-2 or H.264 MP4?
By digicube in forum Video ConversionReplies: 9Last Post: 5th Jun 2017, 15:12 -
Where can I find WIN 7 Driver for EASIER CAP USB Capture adaptor ?
By Robert-G in forum Capturing and VCRReplies: 18Last Post: 13th Apr 2016, 06:43 -
Help connecting DVD combi to external VHS player and TV
By hols21 in forum Newbie / General discussionsReplies: 5Last Post: 18th Apr 2015, 01:04
