If you're creating ina interlaced video you have to encode interlaced. Enter --tff in the extra options box.
Results 31 to 40 of 40
I believe the default is Automatic -- it will pick the the renderer itself depending on OS version, hardware, etc. I don't know how you can determine which renderer it's using but I believe it will normally use one of the D3D or DX devices. I don't think any player since the W98 days would use Windows GDI by default.
Im really thankful for helping me out
Will render it with ttf flag. Btw. with such a settings as previous screen is enough to get video without quality loss? Or should I change Ratefactor to left (better quality)? -
CRF 23 is a bit low. For HD material I usually use 20, 18 for SD. The slow preset is a good compromise of speed and quality. But a lot depends on your particular requirements: things like playback restrictions, upload issues, archival vs. just for watching, personal taste, etc.
I did render even in loseless format, but somehow at the end of project there is a phase between sound and video. ;/
Can it be because some of source files are in 25 fps and other ones are 29 fps? If yes, how can force decrease 29 to 25?
Basically I figure it out bout quantizer etc. but each x264 render video starts about 1 second after audio.
Is this some known issue? -
The delay is not caused by h.264 encoding. Your source probably has a 1 second delay. The audio and video don't have to start or end at the same time. Nor do they have to have the same length. To advance the audio by 1 second set the audio delay to -1 second.
But why the same project rendered via MainConcept AVC/AAC is okay then? Oh, and I saw that video rendered via h.264 has some "corrupted blocks" randomly.
Audio drop outs, metallic noises, and pixelated artifacts during playback
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 19th Aug 2023, 08:05 -
Artifacts while playback mp4
By Darret in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2020, 15:01 -
Artifacts in Video Playback after Importing from miniDV
By moto377 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2017, 11:55 -
Avermedia Game Capture HD II showing interlacing artifacts on playback
By Fadedown in forum Capturing and VCRReplies: 6Last Post: 22nd Aug 2015, 17:57 -
Weird artifacts when converting from MKV to MP4 in Handbrake/Mediacoder
By fighuass in forum Video ConversionReplies: 4Last Post: 1st Apr 2015, 01:01
