I have a problem. I have a DVD rip of a movie and whenever I try to convert it with TMPGEnc to an MPEG-1 for VCD use, it always stops responding and takes forever to convert (it will convert 1.8 minutes of video for every HOUR in real time sometimes). I wanna know if there is a way to just convert half of a video file to an MPEG-1. E-mail me at PS2guy525@yahoo.com if you have any answers to my problem. I also want to know it movies converted with TMPGEnc and burned with Nero work well on a Napa-DAV 311? Thanks for your time.
under settings, advanced, you should find a "source range" option.Originally Posted by Goteraper
you can select how much and which part of the movie to convert
converting the audio part of a video (for xbox)
By vidm in forum Video ConversionReplies: 6Last Post: 28th May 2010, 23:16 -
Want part of DVD to one file
By neworldman in forum Video ConversionReplies: 1Last Post: 30th Apr 2010, 19:38 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 01:07 -
Extract part of an audio file into a new file without rencoding?
By therock003 in forum AudioReplies: 4Last Post: 19th Oct 2007, 17:32
