Hello everyone,
I have a problem multiplexing .m1v and .mp2 files into an .mpg file with Tmpgenc. After multiplexing, I often get the following error: "Warning - xxxx packets cause buffer underflow. Mpeg file may cause error when it played". Does anybody know what this error message means ? The resulting mpeg file seems to play anyway (on the PC), but can I still use it to create a VCD ? Will it work on the VCD player ? Or is there a way to fix the error ? Thanks very much to everybody,
Flavio
Search the forum for "VBV buffer" or post your encoder settings.
I encoded the .mp2 file from a .wav file using Toolame (224 kbps stereo) and created the .m1v file demultiplexing many .mpg files and then joining the .m1v files that I had obtained. The original .mpg files were created from uncompressed .avi files with Tmpgenc using the standard VideoCD PAL template. Unfortunately, I no longer have the original .wav or .mpg files (they took so much hard disk space I had to delete them - the PC I am using is not so powerful), I only have the .m1v and .mp2 I created. Any ideas ?
Thanks again,
Flavio -
I have the same message often after tweaking the sound track under Soundforge5 but file is ok to play.
Usually , its because the file size ,after tweaking, is smaller a bit because of the clean-up...
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo
Multiplexing error using the film machine
By adidas36 in forum Video ConversionReplies: 4Last Post: 16th Nov 2010, 16:55 -
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 21:00 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
