Hello everyone.
I haven't been here in a few years. I recently have been attempting to watch DVDs that I haven't ripped yet, and was driven nuts by the huge discrepancy in music versus dialogue. I use Kodi predominately to watch my shows and movies on my Android box, and since Kodi has a setting to adjust dynamic range compression, I figured I would attempt to rip and convert again. Sadly I forgot the settings I used, as well as the program I used to do it. I tried MakeMKV yesterday, and was amazed at how fast it ripped Avatar, the DVD edition. The file size is about 6-7gb, just too big for my taste. I was looking through the posts here and was looking into Vidcoder. Some of the posts recommended I use the high profile setting, but I can't find it. Since the posts were a few years old, I was curious if there was new setting they have created that would be the same. If it is there, if someone wouldn't mind pointing it out to me, it would be much appreciated!
Thanks!
Results 1 to 10 of 10
Okay, Since there was no true default setting, I went into Android 720 setting, went to video encoding, and set it to automatic as suggested. I also changed it from mp4 to mkv, and the surround from stereo to surround pro logic II. I will try this today. Thanks for your suggestion. It is more difficult when they give you too many options for settings! LOL
Visible settings are basic, but the esoteric stuff is mostly hidden. The settings related to profile/level may affect your
encode because they limit resolution and bitrate - that's why I suggest auto
For quality adjustments see these two. Set "constant quality" and start at about 18. As you move it to the left,
bitrate increases, file gets bigger and you may see an improvement up to a certain point.
For the second adjustment, encoder settings, medium is the default and a good place to start. The encoder uses various techniques
and as you move it to the right or left, you slow down/speed up the run time as more/less things are done to improve the quality -
Thanks for the screenshot! I'm a visual learner, so now I see we are using the same version of Vidcoder. I found those settings in the screenshot. I left the constant quality at 21, and the other setting at Medium. Now it dropped down to 2.19 gb! Video plays well, looks close to the same quality! Thanks for your help. I may fiddle around with the settings to see if I can get it down to a 1gb!
To target a specific size, don't use constant quality, use target size/2-pass
Would you recommend a target size? I am debating to do this since I have read when you do this it can give bad results, such as poor dvd rips.
No I would not. Most of us use CRF (constant quality) because the file size it not the main objective, it's just going to sit on the HDD.
It's you who stated you were hoping to achieve a certain size. Why don't you try it and see if the final quality suits
your need?Last edited by davexnet; 25th Mar 2020 at 15:14.
I can be indecisive.
I may try that tonight. Thanks for your input.
I tend to use CRF 18 to 20 for SD encodes and 19 to 22 for HD ones. (I do usually author to disc using MultiAVCHD, so I like to have a little more leeway on the file size than if I was just keeping them on a HDD. If size is critical then I'd use two-pass target size.)
"Well, my days of not taking you seriously are certainly coming to a middle." - Captain Malcolm Reynolds
Setting up the correct (or safe) Video Procs (Brightness, Contrast..)
By zerowalker in forum Capturing and VCRReplies: 7Last Post: 19th May 2018, 03:53 -
How to determine correct parity setting for Yadif deinterlace?
By Bencuri in forum Video ConversionReplies: 23Last Post: 1st Sep 2017, 09:53 -
FULL color setting in Handbrake and Vidcoder?
By ConverterCrazy in forum Newbie / General discussionsReplies: 31Last Post: 19th Jan 2017, 03:07 -
Acrok rip setting for best video and audio quality?
By kjih03 in forum Blu-ray RippingReplies: 2Last Post: 12th Mar 2016, 11:44 -
Handbrake: Quality setting is being overridden some how? help please
By stringpickin in forum Video ConversionReplies: 4Last Post: 10th May 2015, 23:24
