Hello! I recently found a Sony Hi8 CCD-TRV98 in my basement and I wanted to start shooting with it. The camcorder still works fine, but I don't know how to transfer the video to a computer. I've seen several S-Video to USB adapters online, but people seem to have issues getting them to work with Windows 10. Dazzle Video Capture allegedly works, but I don't have a CD-ROM drive so I wouldn't be able to get the software onto my computer (this laptop also only has one USB 3 port, so even if I got an external drive, I wouldn't have another port to connect the actual device to my computer). I was wondering about the following:
1) If Dazzle is the way to go, could Dazzle and a CD-ROM drive still work through a USB hub?
2) Are there any other options apart from what I have seen so far?
3) Is this a hopeless endeavor with my current computer?
1) Pinnacle devices come in two types, the ones that are built in MPEG-2 encoder and the ones that rely on computer CPU to do the encoding process, You want the latter to capture lossless and encode to MPEG-4 later. But it may not work with Wind10, Support stopped @ Wind7, I was able to make the Pinnacle 500-USB work with wind10 using the Crossbar Thingy to switch between composite and S-Video and Vdub for capturing.
2) Yes, an old good SDI capture device and a modern SDI to USB adapter, Bullet proof, lossless, no frames dropped, But expensive for a laptop, pretty affordable on a desktop.
3) Not hopeless but brand name manufacturers stopped making capture devices for consumer video sources all what you can get is Chinese half assed cheap devices.
Lost frames/packets when transferring HDV footage from MiniDV via Firewire
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 4th Mar 2019, 02:55 -
Oversaturation when transferring to VHS to DVD, TV Only computer looks fine
By guayabito in forum Capturing and VCRReplies: 7Last Post: 21st Oct 2018, 12:11 -
Transferring Super 8mm to Digital with Telecine box
By VSz in forum Capturing and VCRReplies: 3Last Post: 20th Apr 2018, 05:09 -
Walkman or Cassette Deck to capture audio on computer?
By digicube in forum AudioReplies: 11Last Post: 26th Aug 2016, 22:28 -
Converting cassette tapes for a client. Cassette reel ripped.
By SyncroScales in forum AudioReplies: 8Last Post: 14th Apr 2015, 10:10
