I'm having a problem where subtitles in .mkv files are always displayed in MPC-BE, even when they're not set to Default or Forced.
My LAV Splitter settings are:
If I play an .mkv file containing the below subtitle track, the subtitles are displayed even though Default and Forced are both set to No.
I have both MPC-BE and MPC-HT portable editions set up using the same version of LAV Filters, and this problem is only happening in MPC-BE. MPC-HT behaves as expected and only displays subtitles if they're set to Default or Forced. I've messed around with MPC-BE for ages but I still can't see why it's behaving this way.Code:Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 29 min Bit rate : 66 b/s Count of elements : 1363 Stream size : 43.6 KiB (0%) Language : English Default : No Forced : No
Any ideas what might be wrong?
Cannot deinterlace certain videos with mpc-be + madvr + LAV filters.
By streetsofrage47 in forum Software PlayingReplies: 0Last Post: 4th Aug 2019, 16:45 -
[NEW] LAV Splitter - subtitles issue
By Dreamer in forum Software PlayingReplies: 13Last Post: 9th Mar 2019, 16:04 -
Trying to make LAV splitter rules for subtitles work with PotPlayer
By AsadAlrafidain in forum Software PlayingReplies: 4Last Post: 23rd Jan 2019, 22:45 -
does exist a LAV-installer package that install the splitter only?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 8th Jul 2018, 02:59 -
How to manually update LAV filters in MPC-HC?
By IndyKid in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jul 2018, 06:07
